Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Philips Model 42TA648BX/F7 won't turn on/stay on. Red light in lower right corner blinks 2 fast blinks and one long steady blink.
I've changed power source, unplugged tv and waited overnight and it still won't stay on but continues to blink.
  • 4 Answers
SOURCE: Blinking Red Lights
Sound like an error code 14 (Audio supply) is beeing blinked...
You probably would want a qualified technician to take a look at it.
Posted on Jan 24, 2009
SOURCE: tv red blink no start42 plasma philips
Thank you for the help. I actually changed the whole main power supply board and it still did not fix the problem. When I put the new one in, I had the tv on for about 3 hours and then I shut it off. No sooner did I get it back up on the wall and the problem started all over again.When I pulled the original board, the caps all looked fine so I am not even sure the board is bad. Problem is there is no one around me to test it. I am not going back to the same shop that already told me that it was a bad main power supply board. Any other suggestions?
Posted on Jun 25, 2009
SOURCE: tv wont turn on and automatically shuts down
I'm having the same issues with my phillips flat panel. I downloaded the firmware update from phillips and that helped...but only once. I'm back to the same issue this morning. But you might try this download...it may work for you.
Posted on Sep 07, 2009
  • 8457 Answers
SOURCE: my plasma philips tv dosent turn on and red light blinks 6 times
Power supply board have dead capacitors.U know how to solder?Replaced these capacitors that bulge up,puff up or burst open.Should get ur power back.Or replaced a whole power refurbish power supply buy it at Shopjimmy.com,Ebay.com.
Posted on Feb 06, 2010
  • 86 Answers
SOURCE: UPON TURNING TV ON RED BLINKING LIGHT COMES
you have a problem in the power supply module more then likely their a caps blown they will be obvious tops blown off or busted open youll have to take back off look on module in the middle
Posted on May 06, 2010
Magnavox model 32me303v/f7 power on red light blinks then flashes the screen then just black screen but red light is still on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips & Magnavox TVs are entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
See the sites in Magazine view.
Jul 03, 2016 | Magnavox 32ME303V/F7 32" LED TV 1366x768,...
?when I turn TV on I get a red light blinks 1 time then 2 times
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
May 17, 2016 | Philips 42PFL7403D/F7 42-Inch 1920 x 1080p...
I have a Philips 42pf5321d/37 that won't turn on.
send me a email sonny@tvcircuitboards.com and I can assist you with troubleshooting it to determine whats happening with the set.
Aug 07, 2012 | Televison & Video
My right rear turn signal stays solid, won't blink, in the vehicle the right blinker light blinks excessively fast, I have a 1999 surburban
Sounds like a bad ground to me, although i am no expert.
i would be checkinh all connections and take it from there, a little wd40 might just solve it short term.
Nov 26, 2011 | 1999 GMC Suburban
Tv will not come on. Red light blinking on bottom left front. Red light blinks 7 times
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.comj
Nov 01, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
92 dodge dakota 5.2 4x4 won't stay running, hard
What fault codes do you have? to check for fault codes using the check engine light blink method do the following, turn the key to run and then off, then to run and then off, then to run and watch the check engine light, count the blinks, there will be a pause and then more blinks, that is the code(s) So lets say it blinks 2 times and then 5 times, that is code 25. Google the code or codes under the heading: "Dodge OBD1 fault codes"
Mar 28, 2017 | 1992 Dodge Dakota
I cannot get it to turn on. in the lower right
The flashing light indicates a failure with-in the tv, the amount of blinks will coincide with a particular fault scenario. Tell me how many times the light blinks and I can tell you the problem. However, the tv will need servicing from your local shop. This tv is too complex to walk you through fixing this problem with Philips plasma tvs.
Dec 28, 2009 | Philips 42PF7220A 42 in. Plasma Television
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
408 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
