Question about Samsung WF203ANW Front Load Washer
I want to now if u can helpme my washer when its on a full wash it keeps going on to 8e evern when u put it on a spin it dose the same thing and iv tryed everything i can think off turning it off unpluging the pipes turning the water off and resetting it but still doing the same thing and the washer is only 1 and hafeyears old
When my washer is on full wash it makes a loud noise when it turns
Posted on Apr 02, 2009
Troubleshooting kenmore elite model 592-49496 Signal 8E comes up
check main board (PCB ) look at the components , if you find any blackish thing or worn , check it with multimeter upload images , that would help us to guide .
Regards
Dec 31, 2014 | Kenmore Washing Machines
Frigidaire FEX831FS2 stack washer/dryer; it washes, but when it goes into spin cycle it does not spin and you can smell something "funny" burning up like a motor or something. This is what the...
well, The transmission hears turns 2 ways. One way to wash (which causing the agitator turn) and the other to spin. The motor also turns 2 way. If you say it washes fine and in spin cycle is where you get burning smell, maybe of many things: Bad transmission locking up motor causing the burning smell. Possible bad motor trying to start (bad start winding or capacitor). Maybe something simple as something getting stuck in between outer tub and inner basket. Something you can do to check the motor mechanically is disconnect the belt from the transmission pulley and put the time on spin cycle. If the motor shaft/pulley spins on start up then the next thing to look into is the transmission or something catching it from spinning. Check the inside of the washer, if the basket is the type with small holes, make sure there is nothing stuck in any of the whole. Iv seen small screws getting lodged in there and preventing the basket from spinning. You can start by doing simple checks like this to start narrowing down things. Open the front panel form the washer and see if you have access to the belt, if not then you have to tilt the unit to get under it. if you have money and dont want to bother dealing with the unit then replace it. But i like investigating things first. go with whirl pool if you replace it. let me know if what you find if you do make these checks.
Sep 10, 2011 | Washing Machines
My Frigidare front load clothes washer will not spin dry the load effectively. At the end of a normal wash cycle, the clothes are dripping wet. This was not the case when the washer was new. Please...
A number of things could be wrong but the first thing to check if it pumps out all the water before it starts spinning. If possible, lay the drain hose down, wait until no more water comes out, then put it in spin. If it spins full speed then check if something is inside the pump.
May 08, 2011 | Washing Machines
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
Problem washing pillows. They get full of water and washer won't spin the water out.
You can remove the pillows and squeeze most of the water out and then put them back in to spin the rest. Washers weren't really made to wash pillows and pillows werent really made to be washed in a washer. Get new pillows and put hypoallergenic covers to keep the funk out. Wash the covers as necessary.
Alternatively heating and tumbling them in the dryer might get rid of whatever aspect you were trying to neutralize or wash out of the pillows.
May 14, 2009 | Frigidaire Washing Machines
My washer wont drain but will spin in the spin cycle
That means that the water pump or the pump it self is going to go in it my washer did the same
thing we had to get a new pump or compressor. Dose it make a squeeky sound or a funny sound?
Mar 26, 2009 | Kenmore 24032\24036 Top Load Washer
Wash cycle dose not work
There is a small white micro switch mounted near the lid switch. This is a called a check switch. Replace it.d023fa4.jpg
Jan 08, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Install in tub spin part
iam been smart put it dose take years of partice, keep at it there is no easy way to tell you how, it would have been easy with the the tub out. best of luck
Nov 02, 2007 | GE WSXH208A Front Load Washer
Samsung WF203ANW Front Load Washer Logo
139 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
