Question about Amazon Kindle 3G
I do i find the cord for my istereo ip915
Fm antenna
How can I use the FM radio in mySamsung Galaxy Tab A 9.7?
The Galaxy Tab A 9.7 does not have a functional FM radio, however it does have the functionality. It is typically disabled by your provider. You can try to get past this by downloading the NextRadio app, which can be found here: https://play.google.com/store/apps/details?id=com.nextradioapp.nextradio
Dec 29, 2016 | Tablets & eReaders
I have a 6 year old Kindle 3G and the cord is frayed. I know that newer models are easier to read (more light) but can I transfer everything on my old one to a new one? Can I just buy a new cord?
I assume you're referring to the USB cord. Certainly you can buy a new cord at just about any department, electronics, or office-supply store. I have multiple cords (and chargers) all over the house so I can use my Kindle in any room and keep it charged. Naturally, there's another cord by the computer.
Nov 16, 2016 | Amazon Kindle 3G
Wifi antenna is in the halway and when i enter my room SWOOSH WIFI IS GONE
There are multiple fixes for this...but the easiest is an extension antenna.
May 11, 2016 | Dragon Touch Touch R10 10.1 Google Android...
Where would the antenna be on my RCA 7 inch tablet?
It is on the back along one of the edges, likely. There does not seem to be any listing that shows the component locations. If you download a Wi-Fi signal sniffer you may be able to twist the tablet around while pointing it at your ripper to determine which angle gets the best signal.
Dec 27, 2014 | Tablets & eReaders
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
I have bought a patch lead to connect my ipad to an external antennae. The patch lead has a stick on base to attach to the ipad. What would be the best location on the ipad to attach the base? Thanks for...
To be perfectly honest, I'm pretty sure you can't just fix an antennae onto an iPad and expect to get better signal. RF antenna are highly complicated things that are finely tuned. The iPads' WiFi antenna is behind it's black Apple logo, and if you have a 3G iPad the 3G antenna is inside the little black bar at the top of the back of the iPad. You could have a go at attaching your cable on there, but I very much doubt it's going to have much of an effect.
Hope that helps, good luck!
Feb 07, 2011 | Apple iPad 32 GB WiFi Tablet PC
The kindle's signal strength is not strong once I leave the room where the wireless router is. Shouldn't I be able to use this device in other rooms of my house?
Wireless reception can be negatively affected by a number of circumstances. I can give you a list of things to look out for but no definite solution without having more information about your wireless router, the set up of your house and other factors.
  • Place your wireless router in an elevated position and have the antenna stand upright. Keep it at distance from other machinery, metal decoration or containers filled with water. Metal scatters the radio signal of the router, water absorbs it, both is most unwanted.
  • Drywall (aka plasterboard or gypsum board) is used in house interior as wall covers. Despite its name, it contains plenty of chemically bound water. Therefore, drywall is notorious for blocking the WiFi radio waves. The same applies to armed concrete walls.
  • Some electrical appliances (e.g. many microwave ovens) knock out WiFi signals in their vicinity. The kitchen therefore is no good place for a router.
  • Modern wireless routers use MIMO antenna set-ups, greatly extending range and signal quality. If your router has one antenna only, consider exchanging it for a model with three or more antennas (Netgear RangeMax or Linksys SRX models, for example).
Please add a comment to this solution if you do not feel any of the above applies to you, give some more information and I'll try to fill you in more.
Jan 07, 2011 | Amazon Kindle Wireless Reading Device
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
How to hookup kindle to car audio system
This could be either very easy or a huge headache.
Easy way - The newer cars have an audio input jack, basically a headphone jack (1/8"). There are cables that you can use with 2 male connectors; one on each end. Set your car radio on AUX/LINE IN/MP3 and turn it up.
Hard way - Go to Radioshack or Best Buy, even Target or Wallmart, and buy an FM Transmitter. They shouldn't run over $20. You plug it into you cigarette outlet for power and/or takes 2 AA batteries. Plug the headphone jack into your Kindle and set the radio station on the transmitter to either a very low or very high radio station; somewhere where there is no station close by. Turn the car FM radio to the station you set it on and turn it up.
Sep 18, 2009 | Amazon Kindle 2
Toshiba Satellite m35x-s329 notebook, wireless antena
Do you have a wireless card?
If not you need to get one for it to work!!!
Jan 05, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Amazon Kindle 3G Logo
54 people viewed this question
Top Amazon Tablets & eReaders Experts
castletech
castletech
Martin Murray
Jax Planet
Jax Planet
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
