Question about Kyocera Copystar CS-1820 Black and White Copier
Keyocera 1820 balck & white copier error code C6400 on start up,
Error code C-6400 on start up, cannot use machine
  • 3 Answers
Zero-crossing signal problem
The engine PCB does not detect the
zero-crossing signal for the time specified
below. At power-on: 3 s Others: 5 s
That is what the code means in the service manual. However you can try a reset by doing the following. Press 10871087 to enter maintenance mode. Once in maintenace mode press 906 then follow the steps below
1. Press the start key.
2. Select the EXECUTE using the up/down cursor keys. It is displayed in reverse.
3. Press the start key to reset partial operation control. The maintenance mode is exited, and the machine
returns to the same status as when the power switch is turned on.
If you do not feel comfortable performing this operation, or the problem persists then call a technician immediately.
Posted on Feb 04, 2009
Stuck in the C6400 Error and cannot get out of it, nor print anything. My printer is a KYOCERA KM-1820. Any assistance would be appreciated.
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note: Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Mar 31, 2011 | Kyocera Copystar CS-1820 Black and White...
C6400
C6400 Zero-crossing signal problem
• The engine PWB does not detect the
specified below.
At power-on: 3 s
Others: 5 s
Causes: Poor contact in the connector terminals.
Remarks: Check the connection of connectors YC7
on the engine PWB and YC2 on the power
supply PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
Causes: Defective power supply PWB.
Remarks: Check if the zero-crossing signal is output
from YC2-11 on the power supply PWB. If
not, replace the power supply PWB.
Causes: Defective engine PWB.
Remarks: Replace the engine PWB if C6400 is detected
while YC2-11 on the power supply
PWB outputs the zero-crossing signal.
Feb 04, 2011 | Kyocera Copystar CS-1820 Black and White...
I have Kyocera km-2050 it coming error for call for services error code -C6400
press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Dec 05, 2010 | Kyocera CS-2550 Black and White Copier
Error code c6400 on fs-1118 mfp
fuser temperature over /under u need service engineer to reset it
Oct 26, 2010 | Kyocera Copystar CS-1820 Black and White...
On the copystar 1815 I have an error message that says 'error occurred call service person'. On the bottom of the screen it reads 'C6400". I can not clear it. Help!
when machine is on hold down stop key, start, left exposure. release them and press start. display will show U000. self status. key in 163 and press start twice
Jul 31, 2010 | Copystar CS-1820 Copier
My machine still shows the same: call service person c6400. Kindly help me please.
You will have to call a Copystar or Kyocera technician to reset your fuser memory.
Aug 31, 2009 | Kyocera Copystar CS-1820 Black and White...
Error c6400
A Copystar or Kyocera service technician must reset the fuser memory.
Jun 29, 2009 | Office Equipment & Supplies
Showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
May 31, 2009 | Kyocera FS-1118MFP Laser Printer
KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
May 17, 2008 | Kyocera Copystar CS-1820 Black and White...
Kyocera Copystar CS-1820 Black and White Copier Logo
713 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
