Question about FreeMotion Cardiotrainer 600 Treadmill Walking Deck For Model Number: CTTL038041
Freemotion XTc recumbent bike slips
Hello: I have Freemotion XTc (Model # SFEX13809.0) recumbent bike that slips. I have already tried tightening the belt as per the manual. It does not work. The belt seems to be in good condition. However, I thought it might have expanded and loosened a bit for it to slip. To replace from the manufacturer a belt costs close to $97 + tax. I thought it is too much. Can I get a replacement belt much cheaper from another supplier?
2 Suggested Answers
  • 15 Answers
SOURCE: my freemotion treadmill is slipping,
ajusting the belt tension rollers, front and rear rollers tighten with usually a allen bolt ajustment tool
Posted on Oct 25, 2010
Software error on freemotion recumbent bicycle
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 29, 2016 | FreeMotion Exercise & Fitness
Does the seat recline?
If it reclines there is a handle to release it, does it have one? If not it doesn't recline.
Oct 14, 2016 | FreeMotion 350R Recumbent Bike
Why won't the seat adjustment on recumbent bike tighten sufficiently?
Recumbent bike seats adjust forward and backward along a track, if the adjustment does not lock into place it could be that the pin is just not lining up with the seat adjustment bracket. Or that it needs replaced.
Now if you have an upright bike, there is a bracket right under the seat that hugs the seat post. You need to tighten the bolt on that bracket and it should fix the problem.
In some cases the thread on that bolt could be worn out, you will need to replace the bolt, buy a new seat bracket or just get yourself a new seat.
Hope this helps you out in any way.
If you think you need any further help please do not hesitate to call us 888-713-2880 or talk to us by chat at www.sportsmith.net
We can help you troubleshoot or get that new seat if you need it!
Otherwise, good luck on the repair :)
Aug 26, 2015 | Exercise & Fitness
I have a bike that there is no resistance when paddling.
if this is a stationary bike, look on the wheel for a hand operated knob that has a roller on the tire itself.. this is a tensioner..it will need tightened up..the tighter you go the more resistance you get.the new ones use electronic braking system..dont now how it adjusts except by the control module..
Jul 31, 2014 | FreeMotion Upright Bike C7.7 Battery Pack...
RESISTANCE PROBLEM WITH FREEMOTION 350R
9 out of 10 times the issue is a worn out clutch bearing or "one way needle bearing". Freemotion and Nordic Track are both owned by ICON Fitness. This technology for fitness equipment comes from the original Nordic Track skier. In the skier, there is a flywheel with an axle through it in the middle with skis left and right. Under each ski just about center of the length is a rubber roller that fits over the flywheel axle. Inside this roller is a "one way needle bearing". That is, when you push to the rear with the ski, the bearings rollers will shift and lock against the axle and engage the flywheel. When you pull the ski back forward the rollers inside the bearing release the axle and allow free movent forward untill you again push to the rear. Many poor souls were sold new skis and tension straps in most cases to no avail. What needed to be replaced or rebuilt were the rubber rollers under the center of each ski with the "one way needle bearing clutch" inside. The same technology is used inside this exercise bike except that the "one way needle bearing" is pressed directly into the flywheel itself. So rather that replacing or rebuilding the "roller clutches", you need to replace or rebuild the "flywheel". The price for the flywheel from ICON is $600 plus. Thats right $100 more than you probably paid for the bike. There used to be businesses that rebuilt the roller clutches for the skiers. There is no rebuild service available for the flywheel on this bike. So if you don't buy the maintenance contract witch will cost you as much as the bike for 4 or 5 years you have a very heavy piece of junk to dispose of. This is planned obsolescence at it's best. If you are very handy. You can disassemble the bike and find a commercial machine shop that can replace the bearing for you. It is sandwiched between roller bearings on each end. You will need a press designed to remove and replace bearings for commercial machinery like conveyor belts and assembly line equipment and someone to order and replace the same or an equivalent bearing. This actually should be a relatively affordable service. At least in comparison the only other option.
Oct 30, 2013 | FreeMotion 350R Recumbent Bike
Need manual
http://content.costco.com/images/Content/Misc/PDF/666802_UserManual.pdf
Feb 25, 2013 | FreeMotion 330R Recumbent Exercise Bike
My freemotion treadmill is slipping, what can I do?
Oct 24, 2010 | FreeMotion Treadmill t7.3
Hello. We have an Excel 395 Recumbent Magnetic Bike that is making grinding noises when used. Is there any easy solution to fix it myself. Or, should I just throw it away? Thanks, Greg T.
Sorry just saw your request, you'll have take the side panels off and look for read power on the frame this is a indication that the bearings on either flywheel or pulley assembly are destroyed depending on what you paid for you may want to get rid of it if you haven't already.
Jan 07, 2010 | Stairmaster 3800RC Recumbent Exercise Bike
Vital Fitness RB-251 Recumbent Bike Manual
Can I purchase a computer for my RB330P recumbent bike? If so where and how much?
Aug 23, 2008 | Sport & Outdoor - Others
FreeMotion Cardiotrainer 600 Treadmill Walking Deck For Model Number: CTTL038041 Logo
143 people viewed this question
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
