Question about Sony DCR-HC26 MiniDV Digital Handycam Camcorder 20x Zoom Optical
Tape bay does not close
I replaced the battery thinking that may be the problem?did not fix it.On the screen i get a yellow blinking lite and the tape bay will not close??
  • mark cummings Jan 20, 2013
    thanks i will try
    can't see or find anything in the bay it tells me to re-attach power source??
    Genius:
  • 1,669 Answers
Something is either clogged in the tape bay mechanism or there is something actually in the space it occupies.
Posted on Jan 20, 2013
I placed a sony digital8/Hi8 tape in the camera and attempted to record but only got a blinking yellow underscored triangle in the middle of the screen and a blinking code; C32:00 in the upper right corner...
Hi
Thanks for using FixYa. Error C 32:00 is caused due to bad Gear assembly, to resolve this issue with the battery &cassette removed try whack on the underside, if after doing this still the issue is not resolved then you'll have to get the Gear assembly replaced. To remove the tape thats stuck you'll have to remove the two screws that hold the cover on the tape holder. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | Cameras
When i turn my ds lite on the touch screen blinks and shuts off
either a fuse has gone or the screen is sorting out on the motherboard. check youtube for instructions on how to fix fuses, or if you have had a new screen put some insulation tape on the back of it.
Other possible causes can be a fault with the top screen so investigate tat too. the ribbon cables can tear
Feb 15, 2010 | Nintendo DS Lite Console
We own a Sony handy cam model CCD-TRV37 and the tape will not come out. When pressing the eject button a little yellow arrow blinks upward on the screen and a code C:32:20 blinks in the upper right corner....
Error C:32:20 indicates that the take up reel of the cassette that winds the tape into the video cassette is not taking up the tape fast enough thus causing slacking when unloading.
Remove the battery or power cable, connect, and perform operations from the beginning.
if this fails take the camera to a repairman to remove the tape manually.
Dec 01, 2009 | Video Cameras
I have a yellow tape blinking in the screen what does that meen??
It could mean several things. You should check your manual or go to Sony's website to find the most accurate answer.
However,here are some possiblities:
No tape
Almost full tape
Full tape
Damaged tape
If this helps please vote for my solution.
Sep 02, 2009 | Sony Video Cameras
Screen has error message and won't play tape. What is wrong?
This message appears when the loading tape path become misaligned (mechanically unstable). Your camera just need mechanical adjustment from any expert and it will work fine again. Contact any service man for this.
Thanks for using fixya.
Jul 10, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system.  Requires a visit to the service shop.
Jan 28, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Camcorder is not recording
the capstan motor of the camera is not running that why the power display is blinking and when you eject the tape there a portion of the ribbon that left..it is a poor connection of the capstan motor to the main board of the camera....
Dec 13, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Loading tapes
I had the same Problem. My Solution was i open the camera, then i take the batery away. I put the tape into and close the camera, then i put the battery into and the camera close with the tape
Nov 05, 2007 | Sony Handycam CCD-TRV40 Camcorder
C-31:21 code eror
C:31:21Winding S reel fault when counting the rest of tape. Load the tape again, and perform operations from the beginning
The tape may be faulty
Oct 26, 2007 | Sony Handycam DCR-PC101E Mini DV Digital...
Will not accept any tape
i bought this camara from someone with the same problem for 5 bucks at a yard sale. an easy fix. 1. blow the dust out 2. charge the battery. 3. put the tape in and when it gos down into the case close the door and turn it on, run tape on ff then rr then turn camara to record. if it says to eject tape at any time, eject it and do it again. it worked for me.
Jan 11, 2007 | Canon ZR80 Mini DV Digital Camcorder
Sony DCR-HC26 MiniDV Digital Handycam Camcorder 20x Zoom Optical Logo
49 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
