Question about Winter Sports
98 polaris indy 500 wont start, i pulled it over cold and it popped a bang like backfire
Last year i totally rebuilt engine. weisco pistons,rings, new crank,rods,bearings,seals,gaskets(a professional put it all together) not alot of snow last year. but ran great for 300 miles. over summer water and mouse got in air box. cleaned it out, and carbs. drained water out of bottom of motor. oiled really good. it ran good for 100 i pull and pull and doesnt start good. i smell gas but it doesnt seem to pop off and go?????????
5 Suggested Answers
  • 141 Answers
SOURCE: polaris 500 xc backfiring through carbs, running on 1 cylinder
timing or cam
Posted on Feb 15, 2009
  • 35 Answers
SOURCE: I have 95 xcr polaris triple,upon starting it revs
turn the idle speed screw to the left about 2 full turns on all carbs, see where that gets you
Posted on Feb 19, 2010
  • 46 Answers
SOURCE: I have a 2000 polaris
Posted on Jan 06, 2011
  • 1669 Answers
SOURCE: 98 indy 500 I pull it over cold and it backfired, and wont start
It sounds like some of that water turned to steam in the engine and the pressure of the steam did some damage. Check out the timing chain and the timing mark alignment. Check out the valve condition...there might be some chipped or cracked valves...yikes!
Posted on Jan 20, 2013
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
Why is my newly rebuilt 5.7 350 chev. Engine burning so much oil. It's not leaking, and not smokeing out tail pipe?
what was entailed in the rebuild?
cylinders bored and hone , new pistons , rings
crank grind and new bearings
or was it just a ring refresh and sand paper on the cylinders
I'm thinking the latter ( cheap and nasty)
The oil will be coming past the rings and being burnt in the exhaust ( cat converter if you still have one )
That oil passing the rings comes from , glazed bores , rings being installed upside down, ring gaps not being set 120 degrees apart but almost lining up
worn ring lands in the pistons
Sump oil either leaks out -- Gaskets , seals filters or is passed by the rings and burnt in the combustion process
Dec 30, 2015 | Cars & Trucks
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ... > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from
1995 Indy 500 EFI - won't start - Polaris Files > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
When my 2001 indy 500 idles i have a knock
idle knocks indicate worn pistons or worn gudgeon ( wrist pin) bushes
check the ignition timing as it may be too far advanced for idle causing piston slap
Sep 09, 2017 | Polaris ATV
Polaris snowmobile 500 efi indy
Ok I thinking with the info you posted I have a small thing you can check on the wiring harness by the pull start (recoil) side of the engine there will be a small black box this is a relay (Bosch 30/40) go to any parts store and purchase one cost is from 4.00 to 10.00 and replace it what I think is happening is when you try to rev up the machine it's breaking contact of this relay I hope this helps do not get rid of this machine I'm sure it's a simple fix also check for fouled spark plug this can cause similar issues I hope this help
Dec 26, 2013 | Polaris New Genuine Polaris Snowmobile...
I have a 2000 Polaris 400 that had 30 lbs compression. top end was rebuilt, and cylinder honed. New piston, rings (staggered against stop tabs), wrist pin bearing and pin, and the retainer clips were...
Hey Brandon, there could be several things... one is you put the piston in backwards... the arrow goes toward the exhaust..(if there are holes in the piston, they go in the back).., you installed the wrong piston..or..skirt was too long.., you left something inside the engine..(dropped one of the circlips in the engine).. the rings were installed upside down..,one of the circlips came out..., you got a bad piston..(never seen this happen).., the cylinder needed boring and it had so much clearance that the skirt caught on the intake port lip...
OK...Brandon, repairing this engine correctly is going to require a COMPLETE DISASSEMBLY - there are tiny tiny bits of aluminum in the main bearings, packed in between the main bearings and crank seals.. its in the main rod bearing..and its all in the bottom of the cases... THE ONLY way to effectively remove ALL this is to pull it apart.. this is not a hard job, but if you have never done it, PLEASE take it to a qualified requires several special tools... .they may/should be able to tell you what happened to cause it too..
IF you do not do all this, you WILL have premature ENGINE FAILURE AGAIN!!!! and this time it could be worse!
Aug 12, 2017 | Polaris ATV
13.5 B&S connecting rod
You can get the model and serial number and give it to me along with the manufacturer of the engine. I will get you the correct part number for the rod and crankcase gasket and everything.
Jun 09, 2013 | Garden
Jan 20, 2013 | Winter Sports
What should the engine compresion be when i pull the cord it doesnt feel like any coompression new piston rings and cyclinder slevve jus installedt
It realy depends on how much oil is around the piston, and in the bore, however you should be getting over 100 psi
Mar 27, 2011 | Garden
Winter Sports Logo
1,189 people viewed this question
Top Winter Sports Experts
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
