How old is a dimplex XTC series C storage heater? Should i replace it
I am buying a flat for my mother - built 1984 which comes with 3 storage heaters. These are all model XTC series C. how old are they? should I replace them with newer models before my elderly mother who like to be warm, moves in would new ones be more efficient?
SOURCE: my dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Posted on Feb 13, 2009
  • 415 Answers
SOURCE: Dimplex Electric Heater Model Number DF 3003 fan
Dimplex has a Service Manual for your Heater. I recommend requesting the manual through their Literature Request website. I located the owner's manual and the troubleshooting guide via their website, but it appears you will need to request the Service Manual.
Hope this helps.
Posted on Mar 30, 2010
  • 3 Answers
SOURCE: I have a Dimplex Electric
There is a safety bi-metal strip that is probably tripping out. Does it turn back on after a cooling down period ?
Posted on Dec 05, 2010
Testimonial: "Thanks for all the advice. It is working now and has been for the last 15 minutes. Hopefully it will work for a while."
SOURCE: Dimplex Convector Heater EPX1000 turns off by itself
I have the same problem with 3 of the 5 EPX1000s I have fitted in my flat, although mine don't even warm up. They just immediately turn themselves off. My only conclusion is that they are rubbish. Specifically, the so-called overheat protection doesn't work. Avoid.
Posted on Dec 08, 2010
SOURCE: wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Posted on Dec 11, 2010
Need replacement grille for Dimplex floor drop-in heater FFIH15A31
Get the dimensions of grille and contact dimplex, or plumbing & heating supply store for new grille.
Apr 15, 2014 | Dimplex FFIH15A31 Electric Heater
Hi, I have a Dimplex DUO500i storage heater and
Sounds like you heating coils burnt threw. how much did you pay for it? Might want to buy another.
Oct 29, 2013 | Heating & Cooling
I have economy 7 dimplex storage heaters and last winter they just decided to stay stone cold and not come on one day. can these be repaired or do i need to replace the whole heater? thanks
I belive inside the front cover this a bimetal reset in one of the corners top right I think you have to push this back on it makes aloud click . do this with the power off , have done this but a long time ago . hope this helps
Sep 22, 2011 | Dimplex Heating & Cooling
I HAVE 2400 WATT DIMPLEX BUH24T FLOOR ELECTRICAL HEATER APPROX 20 YEARS OLD WITH FUSED 3 POSITION WALL SWITCH. I AM REPOSITIONING THE HEATER AND NEED TO CONFIRM THE INTERNAL WIRING FOR THIS SWITCH. THANK...
20 years old! I serious doubt that there is an Owners Manual or schematic still in existence, However, if you want to give it a shot call DImplex Customer Support to see if they can help you.
If you live in the UK call 0845 600 5111
If you live in the US call Dimplex Technical Service 888-346-7539
Hope this helps you find what you need.
May 24, 2011 | Dimplex CS3311 Compact Heater
My dimplex xms718n storage heaters are not heating up properly - the bottom half is still cold in the mornings what could be causing this?
I have recently had xms718n storage heaters installed and about once a week none of them seem to come on at all. Do you know why?
Dec 09, 2010 | Dimplex Heating & Cooling
Hi - I have an old Glen Dimplex CLX (I think is the name) wall heater. The switch for turning on the heater broke 2 days ago. It sounded like a fuse blew. How on earth can I get this fixed?!
You say the heater is 'old', so I assume that it's out of its 2 year warranty? Are you referring to the wall-switch or the switch on the heater itself?
The customer service department will be able to give you guidance on finding the problem and resolving it. If you call 0845 600 5111 and have your series number (top left of the unit) and model (CXL) to hand they will be able to help you.
P.S. Please don't try to take the heater apart or remove it from the wall unless you have experience in working on storage heaters, as the unit is VERY heavy!
Nov 16, 2010 | Dimplex DXLWP400 Electric Wall Mounted...
Jan 16, 2010 | Dimplex Heating & Cooling
My dimplex night storage heater is not heating up, the power supply is fine. Is there a fuse or trip switch anywhere
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
Dec 19, 2009 | Dimplex Heating & Cooling
Heating & Cooling Logo
614 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
