Question about Acer Aspire 5552 5552g 5553 5553g 5560 5560g 5625 Clear Keyboard Skin Cover
My Acer 5552G won't turn on.
The power led turns on but not the wifi or the hd leds, even if i can hear it spinning but not reading\writing noises. The fan starts for few seconds then goes to idle. The lcd screen is blank. I think it's not an hard disk or ram problem... sadly i guess it's something about the motherboard or he bios...
  • davex4 Aug 12, 2017
    I had the exact same symptoms with an Acer Aspire 5560. Remove the motherboard and then remove the circular silver backup CPU battery with a flat blade screwdriver noting the polarity. Whilst there remove the CPU cooling fan and heatsink and thoroughly clean out the accumulated dust. It pays to remove the 3 screws holding the fan cover to get good access to the filters. Replace the fan and then replace the CPU battery. Re-assemble and hopefully you should see a message flash up saying the CPU is resetting and then it will boot up normally. Here is a link on how to remove the motherboard for an Acer 5560 and I'm guessing the 5552G will be similar.http://www.insidemylaptop.com/disassembl... Don't forget, you should wear an earth strap when handling the motherboard.
  • Acer Master
  • 3,462 Answers
Try a system reset see below link
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Posted on Jun 04, 2015
My laptop won't start
Does the HD light turns on?
If not, try to open HD bay, disconnect and reconnect disk.
Mar 22, 2013 | HP Compaq nx6125 Notebook
My screen dont light on my aspire 7250
I have just fixed an Aspire 7250 with following symptoms: Only blue Power LED or battery charge LED come on, fan spins, no backlight, no video either on internal screen or VGA output.
Problem solved desolderig BIOS flash chip (W25Q16) and flashing BIOS 1.10 with an universal programmer.
Aug 06, 2012 | Acer Computers & Internet
Is drive working right?
Yes it is normal, the hard drive platters are spinning when it is connected to the USB port and the LED is on to indicate that it is connected to the computer. The LED flashes when you read or write data to the hard disk.
Jun 07, 2012 | Iomega Computers & Internet
Error why coming
Can you hear any fan or drive sounds? If you don't hear anything at all when you try to turn the laptop on, no little LED's light up, the problem almost certainly isn't related to the hard drive. So if you don't have a live screen, start with the LCD troubleshooting flowchart, and if you don't have any activity at all, start with the power troubleshooting flowchart. Even if the hard drive has failed at the electro/mechanical level and won't spin up, this wont prevent the LED's on the laptop from lighting up, or the LCD from displaying the BIOS information and complaining about the lack of a boot device.
Ford F150 Body Kits
Jun 07, 2012 | Computers & Internet
Dv7 motherboard won't turn on
used good power jack and check for wrong soldering&tracks cat
then joint the power jack its work
Feb 09, 2012 | Computers & Internet
My acer aspire 5735z won't switch on.
Solution posted in your latest post,
http://www.fixya.com/support/t11566511-acer_aspire_5735z_doen_39_t_turn_just
Feb 03, 2012 | Computers & Internet
Imac intel will not power on
Possible failed video card. 3rd LED indicates MLB and GPU are communicating: (CAUTION! There is high voltage from the powersupply so any attempt to open iMac other than removing glass panel to see the indicators...should be done by authorized ACMT)
  • LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
  • LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
  • LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
  • LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Aug 01, 2017 | Apple 24" iMac Desktop
LED light blinking 6 times and TV won't turn on
When you turn on the power button listen to the back of the TV, you should hear a motor with a high pitch spin up (the color wheel) and then the lamp should attempt to fire. The lamp should make a sparking sound and if it does your lamp is most likely defective. The part number for the lamp is on a sticker on the sode that will say "Lamp Code" on it and will be something like BP96-****
Aug 01, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Acer Aspire 5552 5552g 5553 5553g 5560 5560g 5625 Clear Keyboard Skin Cover Logo
282 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
