Question about Indesit W 123 Front Load Washer
Indesit machine won't start
Hi, I have a year old indesit wie 147 1400 speed washing machine. I turn the dial for the correct function, pres the start, the door clicks locked. but that it. nothing. it won't do any cycle - even spin. what could this be? any advice greatly apreciated many thanks
  • Anonymous Mar 14, 2014
    indesit wie 147 how do i get it to spin only?
  • Anonymous Mar 18, 2014
    Will not start any programme, just does one click and dial moves a fraction.
    Problem Solver:
  • 15 Answers
On the bottom of the machine there is a panel made of plastic that may be removed to expose the waste filter.open the waste filter and check that the waste pump is not blocked as in the initial start up the pump is run if there is a problem with the pump the machine will not advance.
Posted on Jul 19, 2007
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
It flashes f o7 on my wie 127
hi sir, It seems that a common error code on Indesit washing machines is error code 7. This code can show itself as F 007 or with washing machines that have a rotating control dial the door lock light can flash in cycles of seven times.
This error code usually means, “heater relay stuck”.
The heater is switched on via a relay built into the main PCB. This relay is known to get jammed causing error code 7. In my experience this has usually meant a new PCB needed fitting and as the PCB comes without the main processor EEPROM chip one of those is needed also.
This repair is going to be expensive. I have heard anecdotally of engineers freeing off the jammed relay by giving it a firm tap. However, I would not expect such a repair to last as the chances are the relay would just get stuck again later on.
If a washing machine is still under the five-year parts warranty it would be cheaper to let the manufacture fit these parts but although the parts would be free the labour is going to be about £90.
kindly rate me..
thanks for using fixya..
Feb 12, 2010 | Indesit Washing Machines
My machine is 3 years old and used on average four times a week. It not worked hard as we work in offices, so no heavy overalls. Last saturday it stoped half way thru a washer cycle. The door remained...
Easy, scrapped it and purchased an Indesit. The cost to repair AEG was more than buying a new machine. I would suggest to anyone reading this never invest buying AEG unless you have a live in washing machine engineer.
Jan 26, 2010 | AEG Washing Machines
How do I open the pump access on my Indesit WIE 147,
hi there. its likely that there are coins etc in the pump filter,which causes the filter to jam.usually a little persuasion and patience will give you access.try fast left and right turns ,with the emphasis on anti clockwise.otherwise you may need to strip down the pump.patience usully works though!
hope this helps!steve
Apr 16, 2009 | Indesit W 123 Front Load Washer
I have an indesit WIE 137S. When the door is closed, teh red door lock light does not come on and the wash can't proceed. Any hep greatly appreciated
Have you checked your plug and the connections, also your socket.
If no joy, then door lock probably faulty.
Nov 18, 2008 | Indesit Washing Machines
Indesit W 123 Front Load Washer Logo
541 people viewed this question
Top Indesit Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
