Question about Acer Aspire Computers & Internet
Overheating acer aspire - Aspire Acer Computers & Internet
Try to do some cleaning.Like removing dust.
Posted on Jan 20, 2013
Acer aspire 4552g overheating and sudden shutdown
Try cleaning the fluff out of the radiator and fan. You will be surprised how much will be there.
Feb 20, 2014 | Acer Aspire Computers & Internet
Acer aspire overheating fix
What model of acer apire ?
When a laptop gets hot physically hot, to the touch you know something isn\'t quite right. It\'s normal for a computer to get a bit warm as it runs, which is why computers have a built-in cooling fan in addition to a heatsink and cooling vents. Excessive heat, however, is almost always an indication that something is malfunctioning. This is no different with the Acer Aspire 5000.
What\'s Happened If you\'ve ever looked inside of a computer or seen an "exploded view" of a laptop, you will know that thousands of components work together to ensure your computer\'s best performance. The cooling fan is activated by temperature readings from the central processing unit, which heats up and cools down depending on what it is being used for. Sitting idle, the temperature of the CPU will be low and the fan won\'t come on. When the computer is performing a few tasks simultaneously, the CPU is taxed and the fan kicks in. When you hear the fan whirling excessively, the computer is overheating which can damage the CPU. Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. b> Checking Temperatures You can download programs to monitor the core temperature of your CPU. Programs like Core Temp, Speed Fan or Motherboard Monitor use the hardware monitoring devices built into your Aspire notebook to track its core temperature. Different sources suggest that the Aspire 5000 can run at a different maximum temperatures. Users on Tech Support Forum say 50 to 60 degrees Celsius is normal even optimal and that above 75 degrees is a problem. Acer\'s technical manual for the Aspire talks about external temperatures for running the computer efficiently (between minus 20 and 30 degrees), but it says nothing of internal temperatures. A few different users reported overheating to the point of 90 degrees, at which point the computer freezes and shuts off. Warranty Fix Computer original equipment manufacturers like Acer sell every computer with a limited warranty. Overheating is usually covered by this warranty. If your computer is repeatedly reaching high temperatures, and you\'ve recorded the temperatures with software, contact Acer for a replacement or a repair. Out-of-Warranty Fix The simplest way to address an overheating problem is to let the computer breathe a little. Make sure that you use it on a flat, hard surface so that air can pass to the fan easily and without interruption. You can buy laptop cooling pads at most computer stores that are designed with this in mind. As a complex fix for an out-of-warranty system, you can follow a picture tutorial from MPS Computers to replace the sealant around the heatsink with a new glue called Arctic MX-2. This glue allows more heat to escape and brings the core temperatures down about 10 degrees. Acer Aspire Overheating issues http://www.techsupportforum.com/forums/f108/acer-aspire-overheating-issues-214199.html 257 software downloads results for "temperature"
b> Acer Support - ASP Login http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_AS3000_3500_5000_BOOK.pdf
Feb 26, 2013 | Acer Aspire Computers & Internet
Can the acer aspire use a 2tb internal hard drive
Anny PC can take a 2tb hdd along as you enable it in the bios also on that note check for overheating on ether your internal graphic chip or card as overheating will cause that problem
Jun 19, 2012 | Acer Aspire Ax1700 Dual Core Desktop Pc
My acer aspire 3000 turns off suddenly when am watching videos and also when am installing office.
Turn off( shut down or restart automatically)?
It maybe cause from overheating from your graphic memory device/harddware or problem with your processor.
Are you have using fan or anyelse to cooldown your laptop during you using it?
Try something, using any fan that can cold and maintain temperature for your laptop to avoid it from overheating. Overheating is not good. It will cause your motherboard problem or screen monitor problem.
May 24, 2011 | Acer Aspire 3000 Notebook
Acer Notebook 5315 overheats and shuts down unexpectedly
The weak point of ACER is overheating. I always plug in on usb port additional fan and place it right below the ACER to prevent overheating.
Regards, vote please, Jay
Jan 25, 2011 | Acer Aspire 5315 Notebook
Acer aspire 7520 laptop has overheated diodes on motherboard
what is the start up issue, how far dose it go. do you get the login
Mar 09, 2010 | Acer Aspire 3680 Laptop
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
