I had the exact same thing happen. I was drying a heavy load of towels and jeans and it just quit. No tumbling, no heat, no air.
I took my dryer apart and found that there's a thermo switch on the duct between the fan and exhaust. When open, this cuts power to the motor (which I think also cuts power to the heater).
Heating and not drying can be caused by 3 different things. I will address all three most common first
- Restricted air flow, usually a blocked vent. If the moisture from the laundry cannot get outside and fresh air in the dryer you will take extra long to dry. Be sure there is ventilation into the laundry room and more important make sure the vent is not kinked behind the dryer and that it is clean and allowing good air flow. You can go outside to where the vent terminates and feel the flow while it is running to check.
- Sensor has build up on it. Look in the dryer drum, inside on the back wall, inside on the front wall, somewhere depending on your model you will two strips of metal about the size of a pencil. Clean those with a little alcohol. Those are what sense the wetness of the clothes and control the cycle. If they get a build up residue on them they do not sense properly.
- The load is mixed, meaning you have some articles that absorb moisture like towels and some light garments that dry fast, the fast drying articles can fool the dryer into thinking the entire load is dry when the heavy articles are not.
Put a cup of powdered dishwashing detergent in the barrel ie. Sunlight or Palmolive. Place 1 cup of bleach in the soap dispenser. Run on a quick cycle with HOT/HOT and run complete cycle. This does help and don't forget to clean the filter on the lower part of the unit.
Hello mdonettaYou said, Dryer shut off towels were not yet dry, turned dial to restart dryer
acts as if it isn't getting power I closed door and pushed start
button. Nothing! Checked breakers and power cord at outlet all checked
okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset! If this does not work there are internal fuses that can be replaced!
