I had a problem where the unit stop coming on its an 8" burner. When the replacement came i noticed the element was the same but the long glass piece that goes down the center was shorter. Now it works but it goes on and off real fast and at the lower selections it hardly works. Any Ideas?
What is the model number of your unit?
CER3760AAW
You will need to replace the "infinite switch" for the burner. Here is the part to order.http://bit.ly/T72Lzv
Hey Rich, Thank you but I replaced the Switch,burner and the limiter. Everything looked the same except the Limiter the original was a long glass and the new on is half the size. they tell me its an exact repalcement.
SOURCE: stove top burner replacement
if your sure you have it wired correctly then replace the switch but first id double check the wiring on the switch
SOURCE: Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
SOURCE: Can you replace the element in a glass top stove
sure with the full model number you can replace any part of the unit have to have the full model off of the model number plate
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
SOURCE: Can you replace electric eyes with glass top?
there is more to it than just replacing the glass .
and I'm not aware of any kits that allow this .
