Mvwx500xlo maytag bravos top loader
Washer locks door and 'senses' load for a few seconds then unlocks door and won't move to 'wash'
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
  • 3 Answers
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
Posted on Sep 25, 2009
  • 50 Answers
SOURCE: My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Posted on Jan 08, 2010
  • 50 Answers
SOURCE: Our Maytag Bravos washing machine
du is the code for cannot unlock,,,,is there excessive weight on the lid, such as a basket of laundry? Excessive weight will keep the lid from unlocking. Press POWER/CANCEL once to clear the code.....
  • 4 Answers
SOURCE: How reset clean washer reminder on Bravos washer
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset this indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Posted on Aug 11, 2010
I can not open the door on my Maytag top loading washer
Many new washer use a lid lock instead of a brake to keep people from reaching into the spinner before it stops. You probably have a
bad lid lock. Have a repair man open the top cover and repair or replace the lid lock.
Jul 06, 2016 | Maytag Washing Machines
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
The machine door lock clicks when you turn it on and will not cycle
Possible door sensor not sensing door closed. Usually a magnetic or push button switch. Should be a light indicating door position.
Apr 10, 2013 | Maytag Bravos MTW6600T Top Load Washer
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MVWX600XW won't latch or start cycle just blinks & then turns off
Your door lock assembly has gone bad. You'll need to get your model # and go to either www.apdepot.com or www.repairclinic.com or your local parts supply to pick up. To start the repair you'll need to lift the top up by taking the two metal clips, one on each side, and then pulling the top forward. Once that is done lift top and you'll be able to locate the lock located in the front. Once you find the lock follow the wires back and you'll see that they go back and then upwards. Set the top back down and then remove the back of the control panel, which are 1/4 screws I believe. Located the wires from the lid lock switch and see where they connect on the control board , from behind, it shoould be on your left side close to you. Disconnect the wires and now you can remove the lock safely. Install new lock and put the machine back together;
Jun 18, 2012 | Maytag MVWX600XW - Bravos XTM HE Top Load...
Maytag Bravo Top Loader Lock will not work
There is likely to be a problem with either the door/lid solenoid/lock or the 'door/lid closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 03, 2011 | Maytag Bravos MVWB400V Washer
I have loaded my Maytag Bravos and all the lights blink
Check door switch wiring or door switch or control board
Mar 09, 2010 | Maytag Bravos MTW6600T Top Load Washer
Washing Machines Logo
157 people viewed this question
Top Washing Machines Experts
