Question about Ingersoll Rand SS5L5 Ir Electric Stationary Air Compressor 5HP. 60 Gallon Single Stage Vertical
I have a magnetek motor p#8-165482-20 s#bf3-144 for an air compressor data plate shows hp as spl what does this mean? motor is bad and need to replace
2 Suggested Answers
  • 1388 Answers
SOURCE: I have an Ingersoll Rand Type 30 air compressor.
One dealer for your model compressor is Northern. They are very good at replacement parts. If you do not have 3 phase power, you could shop around for 5 to 7 hp 220 v motor making sure that the motor mount will align with your plate. Pully size depends on dia. of pulley on the pump. Most pumps turn between 550 min to 1100 rpm depending on the power available and cfm requirements. Most motors turn at 1725 rpm so for example if your compressor has a 14 in. pulley then you motor will need a 5 in. pulley to turn it about 620 rpm. The larger the pulley at the motor the higher cfm produced but more amps used. Motor speed x pulley dia. divided by compressor pulley dia. To obtain more efficiency and highest cfm you will need 3 phase. Good place to see motors and two piece pulley combnations is www.grainger.com. Good luck
Posted on Sep 25, 2010
Need wiring diagram for switching volts on a century magnetek 5hp air compressor
What is the model number? Most of the Century 5 HP motors are 220 Volt single phase. What did you want to change it to?
Aug 15, 2014 | Air Tools & Compressors
5 gallon compressor tries to start then stops
it sounds like the unloader is not working so it's trying to start with to much head pressure. One cause is a bad check valve another is a bad pressure switch. Those are the more common problems.
Jan 04, 2013 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Electric Motor running slow
Century / Magnetek motors are used on many compressors but usually is an upgrade to have the option to easily switch from 110 to 220. Dewalt, Rol Air, Jenny, Emglo and others are considered high end compressors and come with switch for selecting voltage. One still must change the cord if selecting 220v setting. One thing in common is that 115v motors are never more than 2-3 HP because the amp draw for anything over 2hp is likely higher than 20 amps and would trip most common outlet breakers. You noted that your motor sticker lists 6.5 hp at 15 amp 220v so it could not work with 110v because it would draw over 30 amps and just not be practical. Magnetek motors are very good quality and most always state on sticker 110/220v and show wiring diagram for proper connection. Your compressor was most likely built to be stationary and be hardwired into an outlet/switchbox with heavy duty wiring or special cord to run such a high hp motor. You made a great buy however, because the motor alone lists for several hundered dollars alone. You could replace the motor with a 110v but you would loose the fast performance / recovery of that 6.5 hp motor. Like replacing a v8 engine with a 4 cyl. but expect to pull same load, not likely. Good luck with your purchase, and post again if you have other question.
Jul 11, 2010 | Coleman Air Tools & Compressors
Wire this motor for reverse rotation
First, take the plate where the wires connect to the motor off, and the solution is normally found in the dust cap for the wiring. If not there, go to the AO Smith website with your motor model number and there should be instructions on which of the numbered leads to group together in order to reverse the rotation. Don't worry- it's easy. Don't forget to unplug everything before changing these wires around.
Nov 24, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Need HP rating
Look on the name plate on the motor
Jul 24, 2009 | Air Tools & Compressors
Change from 220v to 110v on air compressor
I can't blame you for askig, but here's my response. 5 HP is 3750 running watts. or about 35 amps at 110 volts and it would take somewhere around 50 amps to start it provided the motor could even be wired for 110 which I don't believe it can and for that exact reason. I'm sorry, but it's just not practical.
May 16, 2009 | Coleman Air Tools & Compressors
Need to install power cord to terminals on 220 AC motor
Ok, read the data plate on the motor. Does it have a zero with a line straight through it. That means it's single phase. Also the plate may list two different voltages 110/220ac correct. On the inside of the panel of the box where the cord connects it will have a two diagrams. One marked low voltage, the other high voltage. You want 220ac so follow the high voltage diagram. Since it's single phase the green wire will go to a green screw in the box. The black wire from your cord is positive and the white negitive (actually neutral but shown on diagrams as negitive). The wire coming out of the motor will have numbers on it's casing. Follow the connection points on the diagram. Don't worry if you hook them backwards the motor just won't turn. It won't hurt anything.
Apr 02, 2009 | Coleman Powermate 60 Gallon Air Compressor
Compressor bad
I would think that compressor would cost a lot of money.So if I were you I would buy a new refrigerator .
Feb 02, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Motor will not turn over all the time.
is it new or used, does it have oil??hydraulic lock up??compressor dump valve bad,dirty
Jan 14, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Air compressor/ alot of air is coming out of the oil cap vent.
this could be blow back possibly bad piston rings you may need new rings oil chamber is usually at intake pressure unit may need rebuild
Jan 13, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Ingersoll Rand  SS5L5 Ir Electric Stationary Air Compressor 5HP. 60 Gallon Single Stage Vertical  Logo
574 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
