SOURCE: neff washer/drier
soap drawer is just a slide fit - give it a good yank. for the dryer, take the top off and there should be a mainifold across the top with stats mounted on it. one or two may be re-settable stats ie have a little button in the middle which press to reset. if this works, cause of stat popping out is usually a lint blockage in the dryer manifold
SOURCE: dryer heater not working
If it is an electric heater that means that either the heating element, or the thermistor , or the cirrcuit breaker connecting the element must be replaced.
You find diagrams and replacement parts here, just enter the model number.
See also following suggestions from repairclinic :
There's no heat.
How Dryers work
Find a part for your Dryer
SOURCE: my lg dle0442w wont dry clothes blows cold air
Sometimes it is the heater element in the dryer. Other times the main circuit breaker has tripped one leg. Some 220V-230V breakers have two trip switches that are tied together. One half of the breaker runs the motor and the other half operates the heater. A defective breaker can also cause the problem.
SOURCE: LG all in one washer dryer fills with water on the drying cycle
I had the same problem with my machine this week and I discovered an auxillary drain that was clogged with lint. If you lift the inner lip on the bottom of the door gasket you will see a small hole. This hole is actually connected to a skinny tube that drains to the main water pump. Mine was clogged with lint and the water that had accumulated there was draining back into the drum and soaking the clothes again. I cleaned it out and blew air through it and now the machine works like new again. I hope this helps.
