Question about RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer
Paslode im250 works fine but makes loud gun like bang noise, can I reduce bang sound.
Can I reduce bang sound
    Genius:
  • 1,669 Answers
Take a look at the internals and see if there is an air leak or muffler problem:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/paslode/IM250_A/
Posted on Jan 20, 2013
I am using senco gas in a paslode 2nd fixing nail gun. Is the senco gas 'bad for' my gun in any way as i am having a few firing problems
You can use most gases in your gun, but paslode is the best that's why its more expensive. Try warming the gases in your pocket that sometimes helps.
Dec 17, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode im250
There should be a depth adjustment on the gun. This allows you to control how deep the nails sink. The adjustment is usually on front face of gun and just above the tip. You might want to contact paslode to see if they can give you any ideas .
Feb 27, 2014 | Tools & Hardware - Others
Plaslode im250 second fix nail gun fires intermittently. Gas is loading fine and trigger working only fires about one in every ten pulls of trigger
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Dec 31, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My IM65 light flashes green then red, fan seems to be working and the gun does fire
heatman101
Aug 30, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Were can i buy a instruction manual for a paslode
go to Paslode.com and you can download the manual for free. Let me know if you have any problems
Dec 11, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Hi how to change the motor in paslode IM250 i took the gun apart but i can not remove the motor
There is a small torx bolt in the fan, heat the bolt up to losen it, then remove fan.
Now remove spark plug lead and unplug the wires to the butterfly board.
Then remove the circlip that is holding the outer rubber attached to the fan.
Hope this is some help. any problems contact your nearest paslode repair agent.(check on the paslode web site for your local repair agent)
Good luck.!
Sep 15, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode im250 type 2 wont fire
sounds like its losing presure when fireing it could be the next oring if its the rubber one replace if its the metal one take them out and clean the grove they sit in and make sure u space them, meaning the gap in the rings should be set 180 deg apart. this should work if u r getting a spark when the gun is apart. the cable could be making a bad contact at the spark unit and when u r checking this make sure its getting a good contact at the spark plug as well hope this helps u.
Aug 02, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
IM250 Paslode straight brad nailer, fan wont shut off
My paselode was doing the same thing, and I followed all of the cleaning instructions, but the problem continued.
If it was left alone for a minute, it would fire again, so I removed the cover over the trigger assy, and checked the spark plug wire connection. The trigger came out, and during reassembly, I noticed that the electrical switch was hanging, and slowly pushing back out.
I cleaned and lightly spray/oiled the switch pin, and voila.........works like a charm.
Jul 26, 2009 | RTO PasLode 900420 Impulse Framing Nailer
I have paslode finishing nail gun , i cleaned it, not working now
The smoking is normal for a few times after cleaning ,but you might have put to much oil drops in chamber and piston chamber is getting a "vapor lock". Try recleaning with degreaser. Also have you forgotten to set the depth gauge at front of nose.
Please Rate jj505 Thanks
Mar 23, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer Logo
487 people viewed this question
Top RTO Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a RTO Tool and Hardware - Other Expert? Answer questions, earn points and help others
