Question about 18 HP V-TWIN GX610 V-Twin OHV Horizontal Shaft
How to replace a valve stem seal in a honda gx610?
3 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: i have 1990 honda civic it has good compresson
Remove valve cover, loosen valve and lifter nuts, remove rod and seal.
You can go to autozone.com and register for full free online repair manual with everything you could need.
Posted on Sep 16, 2009
philschneide
  • 448 Answers
SOURCE: 1990 HONDA ACCORD VALVE COVER SEALS.
They go UNDER the valve cover in the slight recesses around the plug holes(might use a dab of RTV sealant to keep them in place, or do so by adhering them to the recesses in the valve cover itself, making sure to let the sealant dry a bit so they do not fall out when you put the valve cover in place), NOT down in the plug holes from the top as some people seem to think.
Hope this helps you.
Posted on Dec 01, 2009
Testimonial: " Speedy responce,good advice, you are to be highly commended for such willing help. "
My 2007 Honda rancher 4x4 smokes bad, but has plenty of power what could this be
Normally there are three culprits to excessive smoke:
1. Cylinder or Piston Problems
2. Worn Valve Guides or
3. Worn Valve Seals** - there are seals that go around the valve stem at the top of the engine. Oil is pumped up to the top and dumped on top of the valve springs and the rocker assemblies to be lubricated. The stem on the valve has a seal - to prevent this oil from leaking down into the combustion chamber - forcing it to follow the proper route back into the crankcase. If your valve seals are shot - oil bypasses these seals and enters the combustion chamber - thereby creating excess smoke because you're now burning oil with the air/gas. Definitely could be possible - here's a diagram of the parts and a page that lists the three reasons for excessive smoke in 04-07 Ranchers. Hope this helps - good luck.
All The Best, Justin McCartney
Nov 29, 2015 | ATVs
How easy to repair valve seals
Valve stem seals replacement...
Remove cylinder head, remove valve springs with a spring compresser.
Seal is just a rubber boot that you lubricate and slide over the end of the valve guide.Replace valve springs,refit head with new gasket.
Refit camshaft and re-time...
How easy this is depends on previous mechanical experience and availability of tools
If you are confident enough with refitting and timing the camshaft and have access to a torque wrench and valve spring compresser then this is a pretty simple job.
Feb 27, 2012 | Honda Motorcycles
Cbx 1000 1982 is it possible to change valve stem seals with out taking head off ta
Not really. Once the valve cover, oil line, intake and exhaust cams, and shims are removed you are looking at the top of the valve stem. The valve needs to be held up against the head to take off the valve keepers, the stepped disk and the two springs. The valve stem seal is way in there behind everything mentioned previously. If you could jam the valve against the head to remove the valve keepers etc. then you would have to do the reverse to replace everything after putting new seals on. You would have to do this 24 times, rotating the cylinders just right to get to TDC. The chances of completing this without bending a valve or ever being able to run the motor without always expecting an imminent catastrophic failure would be about zero.
(However, if you were planning on selling it to someone you were not ever going to meet again in this life or the the next - well ok then).
My apologies.
Dec 01, 2011 | Honda Motorcycles
How to replace valve seals. when cycle is on side stand for a day or two and you start engine it smokes for a few seconds
This has been an issue for ALL Goldwing's (1000, 1100, 1200, 1500, and probably 1800's). It does not hurt anything. If you center stand you cycle it will never happen. but all Goldwing's are known to let out a puff of smoke if left on the side stand. The oil may be leaking past your piston rings and not your stem seals. If you want to change your stem seals you need to put the cylinder on top dead center compression stroke, remove the spark plug, screw in an air hose from your air compressor to pressurize your cylinder, with air pressure hold the valves in place compress the valve springs with a valve spring compressor, remove the parts (washer, cotter keys,and springs), pry off the seal, pop on the new one and reassemble. It is a lot easier living with the puff of smoke, Happy Trails.
Jul 18, 2011 | 1993 Honda GL 1500 Aspencade Gold Wing
How do i replace valve stem seals on 1990 nissan pulsar GL
To replace the seals in ANY cars valve stems you need to buy the valve core. They screw into the stem.
Apr 23, 2011 | 1990 Nissan Pulsar
2003 polaris preditor 500 engine smokes and burns oil. compression is 135 and engine still runs strong. What do you think is the problem
If you still have good compression, and motor runs strong, then the problem is in the head, eg, usually valve stem seals, letting oil in the cylinder. Have your head reconditioned, valve grind, and some new valve stem seals should solve the problem. It is fine to keep riding it, just keep your eye on the oil level, as it will be burning oil.
Aug 31, 2010 | Honda vt 500 ft ascot Motorcycles
Kitchen taps drip and leak.I do not want to replace with new but would like to sort these problems.
dependent on the type of faucet, you need to replace (a) the washers, (b.) the spring and seals or (c.) the gasket. They all serve the same purpose. 1. turn off the water supply to the faucet. 2. double handle? (a)remove the center cap (b) then remove the screw holding the handle down (c)next unscrew the valve stem retaining nut (normally it is the one right above the faucet body). (d) pull the valve stem out, if there is a small rubber piece held down by screw remove the screw, replace the washer. if there is a rubber gasket wrapped around the stem, remove and replace it, if nothing is on the stem look into the faucet body you should see 1 or 2 small rubber pieces these are the seals the springs are right below the seals. Remove and replace springs and seals. 3. single handle? remove the handle retaining screw, normally covered by hot/cold indicator symbol, unscrew valve stem retaining nut, pull the valve stem and replace either the gasket or springs and seals.
Aug 28, 2009 | Home
Valve seals on 1993 accord
if your car smokes blue smoke when you let of the gas then your valve stem seals are leaking
Jun 10, 2009 | 1993 Honda Accord
18 HP V-TWIN GX610 V-Twin OHV Horizontal Shaft Logo
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Spud Howell
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
