My microwave door part broked, i open the microwave and find a plastic part with 2 litte pins inside broked thats the reason i cant open my microwave, anyone know where i can buy that part the mycrowave is only 18months old and works perfectly.
SOURCE: Door latches to microwave broken
I assume you're talking about the spring that keeps tension on the door hooks (latch heads, as they're called by Sharp). When you shut the door, the "hooks" are held down by this spring to actuate the door switches. To fix this, you'll have to separate the door panels. You can download the service manual from my Web site. There's a loop built into the latch head assembly and sometimes the loop breaks. If so, you can drill a tiny hold in it and reattach the spring there. There may also be a loop on the innner door panel to hold the spring. That one can break, too. If it's broken, you'll have to find a way to secure the spring to the panel. If the panel material is thick enough, a tiny screw eye could be inserted, then epoxied overnight to secure it. I've attached a diagram to this message that should help you. If that doesn't help you, I have the service manual for the R1600-series microwaves on my Web site at: http://www.microwavedisplay.com/R1610.pdf Repost if you need more help.
SOURCE: Replacing the door catch
If you're talking about a hook-like device that sticks out of the door and goes into a hole in the chassis of the microwave (or any other internal part of the door for that matter) you'll have to take the door apart. Brands and models vary, but some use screws which are obvious, and others use hidden hooks similar to the ones in the drawing I've added to this post. If you can post or e-mail photos of the area where the part goes, we may be able to translate our experience with other brands to yours.
SOURCE: Maytag MMV1153BAW
This is the stirrer cover. It is important. It is to keep food particles and grease out of the stirrer and waveguide area.
If
grease or food particles build up, they can arc, which will cause burn
damage to the cover, stirrer, chassis, and/or magnetron.
If you have any arcing, you should remove it for cleaning. Be careful of sharp edges.
The stirrer's job is to stir the microwaves to ensure even heating, even when a turntable is not present or not used.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: microwave door button spring broken and door wont open
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
SOURCE: Door handle broke off
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can get Samsung parts here.
We're happy to help you and we'd appreciate your
