Question about Electrical Supplies
Powerhouse generator 3100ri starts, but wont keep running
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Why does my powerhouse PH3100ri generator run fine for about 5 minutes or so then dies and it will not start again in till it sets for 30 minutes or so then it will fire right up please help!!
Maybe faulty CDI ignition module ? There are a number of components ( electrolytic capacitors ) in the module that can fail with temperature rise.
A test... Remove the ignition plug lead when motor has stopped after the 5 minutes and put a wire inside the plug cap and place end near a metal part of motor. Careful not to zap yourself... Pull starter and look for ignition spark. If there is no spark then probable fault is ignition module. If there is spark then problem may be in fuel system.
Do check vent on fuel tank is open.
Do check choke is turned to off once motor is running.
Do check the oil level as the low oil cutoff can cause shutdown and will result in no spark.
Mar 16, 2015 | Powerhouse PH3100Ri Inverter Generator...
I have a PH3100Ri . It will not start with remote or with manual switch. The starter motor does not turn. Battery has full charge. Any ideas
My powerhouse PH3100 ri turns over with the remote and key but will not start , when it did run it ran for 10 mints and shut down and now it will not start at all
Jun 30, 2013 | Powerhouse 3100 Watt Inverter Generator...
How to change fuel filter on a PH3100Ri
Check to ensure you did not trip any of the amp switches. My generator acted the same way until I reset the switches.
Apr 11, 2013 | Powerhouse PH3100Ri Inverter Generator...
My coleman powerhouse dual fuel lantern brightens and dims continuously. could this be the generator acting up?
Hi bradley m925...
Try using the cleaner for the generator, it is a twist type crank, make a few turns on it if you have it.
If not then your right, replace the generator as it is faulty.
Please take time to rate me
Coleman Generators website...http://www.summitcampinggear.com/lage.html
Sep 21, 2011 | Coleman Cable Coleman Twomantle Dual Fuel...
What grade of oil do you use in the Coleman powerhouse 8000 with the 18 HP twin?
For normal operating conditions use straight 30 weight. For below 30 degrees use 10w 30.Thank you
Jan 09, 2011 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
135 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
