Question about Denon AVR-3805 Receiver
Hooking 901 bose serires VI to denon avr 3805
Can you please help me with a solution to hook up my bose speakers 901 series VI to my Denon AVR 3805. The denon does not have a Tape monitor. But If can can use pre amp out and main amp I could go that route. Unfortunately I could not identify these adapters on my Denon AVR 3805. Thanks in advance.
Rod
  • 2 more comments
  • rhod28 Jan 28, 2009
    I am not sure what that would do.
    1-The main issue is for the signal to go through the bose EQ before it gets to the speakers.
    2-Could I have a diagram of how that would work.
    3-How would any other signal source (such as optical) go through that EQ channnel. Tape monitor (when it is on ) cancels all other channels and everything goes through the EQ. Pre AMP in and Pre main amp just equalizes all signal through Bose EQ. Maybe I am confused. Enlight me.
    findmeifucan sound good but where would I place the IN from the equalizer so every signal goes through that same channel even optical one so they can be equlized by Bose EQ. Do I make sense? I can play through the speakers with no prblems but I need to play equalized soud using the Bose EQ.
    what kind of cable.
  • rhod28 Feb 03, 2009
    I have decided to go with and external amp to hook up the 901 Bose speakers to the pre out of the denon 3805 . Any suggestion suggestion of a good amplifier that could do that with no annoying hummm... and big delay.
  • 15,935 Answers
THIS IS TAKEN FROM THE USER MANUAL PAGE 10...
Use these instructions:
• for stereo-only operation if your receiver does not have a TAPE MONITOR connection.
• if you are using a surround sound receiver that has a section on the back marked PRE
AMP OUT/MAIN AMP IN. The jacks may be labeled ADAPTER or SIGNAL PROCESSOR.
Note:
If your receiver does not have this PRE AMP OUT/MAIN AMP IN section, the 901
speakers will not be usable in your home theater system.
Your Denon reciever (MANUAL) does have a "EXT IN", and should be able to be used the way you want.
Using THIS PICTURE of the rear of your reciever, you have the required input, labelled EXT IN on the lower left side.
However, the EXT IN will bypass the denon equalization, and give the raw signal to the bose system.
You will need 2 sets of red/white RCA cables.
Set 1 goes....
FROM BOSE - "Amplifier Connections" (from amp)
TO DENON - "Pre Out" Zone 3 - (Bottom Left)
Set 2 Goes....
FROM BOSE - Amplifier Connections" (to...)
TO DENON - "EXT IN" - (SR and SL) just above Zone 3 pre-outs.
To listen to the bose, your DENON must have Zone 3 selected.
This connection is pictured in the BOSE USER MANUAL on page 11 (Figure 7)
Thank you for using FixYa - A FixYa rating is appreciated!!
Posted on Jan 28, 2009
  • blueextc3221
    blueextc3221 Jan 28, 2009
    Component RCA Cables
    Genius:
  • 1,550 Answers
Denon has a jack section in the back labeled 'multi ch in',You need to connect the output from your Bose to the left and right channels of the multi channel inputs. This is an input directly to the amplifier section of the Denon, bypassing any processor modifications to the signal.
Posted on Jan 27, 2009
  • 10,594 Answers
You can use LINE OUT jacks as alternate of Tape Monitor.
  • Shahid Electronics
    Shahid Electronics Jan 28, 2009
    AVR-3805 already have built-in equalizer that's why you can not hook another equalizer with it. It is 7.1 surround system.
    Bose Equalizer is designed for old fashioned amplifiers that has no built-in equalizer facility.
    Please use Bose speakers by hooking directly. There is no way to use equalizer with AVR-3805
    Thanks.
    President:
  • 1,990 Answers
Welcome to Fixya! Crutchfield.com has the Best selection of Equalizers for your Setup. Check them out. Great Prices and Customer Service Also! Please Rate My Response! Thanks!
Posted on Feb 03, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The 901 speakers could still be hooked up as FRONT (but the equalizer is a redundancy if you want it integrated to the Denon AVR 3805 plus internal mods are needed).
Or
Wire the 901 as a separate feed from any of the PRE-OUT (except the SUB WOOFER) attach the OUTPUT of the Bose equalizer to its own stereo amplifier that will use the 901 speakers.
Good luck and thank you for using FixYa.
Posted on Jan 30, 2009
  • Louie  Role
    Louie Role Feb 03, 2009
    Hi again and hope that you were commenting on my suggestion of a separate amp for the 901 equalizer and speakers. Most known brands would serve the purpose and would further suggest a plain stereo amp with volume controls (nothing more). The rationale is if an amp with Dolby processing or other sound processing is used with the Bose equalizer, then again, it's back to the redundancy of sound processing. Power wise, it should be equal to or slightly less than what the Bose Speakers are capable of.
    To address the humming sound, a few ideas to consider:
    • select/use high grade RCA to RCA cables;
    • use polarized power plugs and power strip;
    • use a common/ground strip.
    Cheers.
    Genius:
  • 1,913 Answers
Try to reset all setting to factory defaults.
    President:
  • 1,214 Answers
Your not going to get Dolby 7.1 through the Bose equalizer. You can use the Bose equalizer to balance equalize the front two, or rear two, speakers.
But, I wouldn't use the Bose equalizer at all. Use the equalizer from the Denon.
Be sure and use a sound level meter and sound alignment CD to set all this up. You'll be glad you did.
  • 6,784 Answers
The denon/bose hook up can be a headache. they just don't mesh well. you can order an adater cable from Bose to fix this problem.
  • Denon Master
  • 19,396 Answers
Bose 901 does not work on all system .
you need to call Bose to find out.
  • Ginko
    Ginko Jan 30, 2009
    As I told you, Bose 901 may not work on this system .
    you need to call Bose first to find out.
  • Ginko
    Ginko Feb 03, 2009
    To get the best result with this speakers it is better to buy a Bose Amp, I know they are expensive, but...
    Regarding the speakers and the original problem, this article may be of some interest.
  • 4,234 Answers
On the back is a set of jacks labeled pre-out. This is the source to feed to the Bose Eqs. You will require external amplifiers to drive the speakers
There is no way to utilize both the pre-amp section and amplifier section of this unit with an external EQ as you would like.
Dan
  • ABRsvcs Feb 03, 2009
    ANy high quality amp will work just fine. There is no need for a Bose specific amp. The requirement for the 901 is the EQ which compensates for the sweetspots of the speaker system itself. With the EQ inserted, a standard amp will be fine.
    Dan
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
How do I hook up my bose 901s to this unit?
Well the basic connection of the speakers would be the same as another stereo speaker pair. Wire the left and right speakers to the L/R Front Surround speakers on the Denon.
With the 901's I am assuming that there is an external equalizer supplied by Bose. Typically this EQ is installed in a tape loop on the receiver/amp so that it is ahead of the power amplifier that drives the speakers. This EQ needs to be there to attempt to get reasonable frequency response from a speaker that has only 4" drivers. I'm not sure I see any reasonable way to make the EQ work with the Denon AV receiver. You'd likely be better off using the Bose speakers in a dedicated 2-channel stereo and getting a set of speakers for the AV usage.
Apr 16, 2016 | Denon Avr 3805 7.1 Channel Audio Video...
How do I turn tape monitoring on my Denon AVR 3803 on/off? I recently purchased a set of Series V Bose 901's and I am having a difficult time figuring out how to activate the equalizer.
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
Connect the Active EQ between the pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Oh, but you don't have pre-outs. Bummer. Most AVR's will NOT pass digital sources to analog tape outs. Page 40 of the manual confirms that.
no can do. sorry. You need Pre-Outs to feed an external amp.
May 22, 2011 | Denon AVR-1803 Receiver
I cannot connect my bose 901 series v1 active equalizer to my denon av surround receiver avr-891
The reason: You can't use the Active EQ (or ANY processor) in a tape Monitor loop with anything but 2-channel stereo material. As soon as you activate the loop you lose digital sources.
Adding to YOUR particular problem is that the Denon doesn't have a volume-controlled pre-out to feed that amp. If you want to deal with controlling the separate amp volume manually you COULD connect the Active EQ between DVR Out and the 901 amp IN but you would have a stereo mixdown instead of true front channel from the speakers.
Bummer.
Dec 26, 2010 | Bose 901 VI Main / Stereo Speaker
I have a Denon AVR 3805 receiver. It does not have a Main Amp in or a pre Amp out in the back. How do I properly hook up the Bose 901 equalizer to this receiver? I use the 901 speakers as surround...
By properly, you must mean WITH the Active EQ.
According to this picture, you're in luck BUT...
http://www.audioholics.com/reviews/receivers/denon-avr-3805/denon_AVR3805_rear_lg.jpg
(Short answer from personal experience.)
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers. A good 100-wpc amp will do. (I like Carver)
Connect the Active EQ between the Front pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Helpful Hint: If you don't have sufficient between-speaker room for proper reflection off the front wall you CAN turn the 901's around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Oct 14, 2010 | Bose 901 VI Main / Stereo Speaker
Can't get the MultiZone to work on my Denon AVR 3805 Reciever
No as there is no volume control on the zone outputs
Aug 18, 2017 | Denon AVR-3805 Receiver
Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
Sep 28, 2008 | Denon AVR-2807 Receiver
Bose 901 speakers hookup
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Jul 02, 2008 | Denon AVR588 Receiver
Is it possible to to have a home theatre with Denon AVR 3600
one option that may yield results, since the bose connection to equalizer is presently not possible is to set the speaker out put on the denon for 'small' on all but the front speakers.
and then set the delay for all speakers based on the distance to the amp.
this should result in better audio that that with the bose eq.
will work on the issue of using the eq. with the denon if you like. but, you will likely not improve on the sound with the denon set up correctly.
good luck
mark
Dec 17, 2007 | Bose 901 VI Main / Stereo Speaker
Denon AVR-3805 Receiver Logo
514 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
