Question about Pioneer Audio Players & Recorders
What is the output voltage pioneer model sa 6800 ii
Pioneer stereo amplifier model SA 6800 ii
marsrover
  • 682 Answers
SOURCE: hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Posted on Mar 11, 2008
robotek
  • 1512 Answers
SOURCE: pioneer amph sa 9500 II
Hi yalazogeday
Your amp is fitted with two 2SD588A (NPN) and two 2SB618A (PNP) power transistors in the output stages. Click on the part for a place to get them from. These parts are no longer available from Pioneer, nor are the prescribed replacements. (the amp was built in 1978) Because of the unusual transistor package used, you may have to upgrade to a more modern transistor, and modify the mounting also.
robotek
Posted on May 28, 2008
  • 3 Answers
SOURCE: Pioneer Stereo amplifier SA-7800 sound problem
reach me at my email snhaqua@hotmail.com for to fix pioneer amplifier 7800
Posted on Sep 11, 2008
  • 118 Answers
SOURCE: I have a technics reciever - model SA-GX670 --
depends on whether it works or not
Posted on Nov 03, 2009
SOURCE: i need help
Loose connection on "POWER-SUPPLY" and sometimes solder loose on "C I S BOARD" due to extreme - heat of amplifier. $137.51 repair done in 1HR as I waited at CENTURY SOUND ELECTRONICS.
Posted on Feb 01, 2010
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
WANT TO GET OUTPUT I.C FOR STEREO AMPLIFIER TECHNICS MODEL SA-AX540
Try Ebay or Audio Lab of Ga.
If it's a single module , it wont be cheap
May 01, 2014 | Technics SA-EX500 Receiver
Need service manual for pioneer sa-600
Head straight to the (European) electrotanya website, which offers free downloads of a wide range of service manuals. No registration is required either.
The Pioneer SA-600 schematic shows both voltages and currents. For this amp, the total current for left & right output modules (no signal) is 60mA. No-load voltage is 58 volts, dropping to 48 volts (one channel driven, 25 watts out).
PIONEER SA 600 SCH Service Manual free download schematics eeprom...
Feb 26, 2014 | Cameras
I have an pioneer SA-510 amplifier and i want to know how to connect it to my laptop and what kind of aux i need ? plz help
Just go to Radio Shack and buy a 1/8 male stereo cable and the other end with 2 male RCA plugs and connect them to the AUX or CD input of your receiver, the 1/8 male connector goes to your earphones output of your laptop, hope it helps.
Sep 08, 2013 | Audio Players & Recorders
Pioneer model SA 9500 stereo amplifier problems.
Is the dc voltage reading on the base of the outputs 0.6 with emitters reading 0.014 or there about. Depending on the outputs used you might read 1.2volts on the base. Your collectors will read the power supply voltage of 50 or 60volts or more. If this is what you are reading on your meter the problem is in the speaker protection circuit. This circuit is what drives the relay you tested.
Jun 27, 2012 | Pioneer Audio Players & Recorders
I have recently receieved No Audio from my SA-DX940 stereo. Is there something I can fix myself to help avoid destroying the stereo completely? Thanks, Scott K.
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Aug 12, 2011 | Technics SA-DX940
How do i connect a pioneer tx-940 to a pioneer
You need two RCA-to-RCA cables (or one double-cable). Connect the L(eft) Output on the tuner to the L(eft) Tuner or Aux(iliary) input on the SA-1040. Connect the R(ight) tuner Output to the correcponding amplifier input.
Oct 07, 2009 | Audio Players & Recorders
Aug 24, 2008 | Audio Players & Recorders
Pioneer amph sa 9500 II
Hi yalazogeday
robotek
May 24, 2008 | Audio Players & Recorders
Hook up pioneer stereo amplifier model SA-1270
Oct 15, 2007 | Audio Players & Recorders
71 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
