Question about Canon PIXMA MP530 All-In-One InkJet Printer
Printer service error 6502
I have a Canon MP530 printer/fax and am getting service error 6502 but do not know what it is. I just put in new ink cartridges so it is not that
  • sandep_16 Mar 15, 2009
    i have mp 530 all in one printer . no one comes to do the servicing as my printer is leaving black ink while printing and back side paper feed does not capture paper properly.
    sandip taylor
    a-16, p.v.k. , ground floor, palam vihar , gurgaon 122017
    ph: 9811122155, 9311122155
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
Error 6502
this error indicates a problem with an ink cartridge. this can include a bad cartridge, improperly installed, or possibly ink leaking out when installing it.
reinstall ink catridges.
Oct 17, 2013 | Canon PIXMA iP3600 Photo Printer
Changed ink cartridge and now have error 6502 - have no clue what that means, but it won't print - yellow and green light alternate flashing
Error Code 6502 appears generally after changing a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 12, 2011 | Canon PIXMA iP3500 Printer
Error 6502
Hello
Try
Error Code 6502 appears generally after chaging a cartridge.
Solution:
Hope it helped.
Thanks for using fixya
Nov 09, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Service error 5c10
This error is a message indicating print head/ink failure on the printer.
I would try the following 2 things:
1. replace the ink cartridges/print heads. test to see if the problem is fixed.
2. If this does not solve the issue, you may need to either send it to the manufacturer for repairs (if under warranty), send it to a local repair person to service- or look for a new printer to buy (which may actually save you money).
Jun 30, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Will canon mp530 stop fax mode if low on ink?
It will run as long as the ink is just low, when empty it will not let you proceed. It will take an incoming fax and hold it in memory until the inks are replaced. When empty the error will stop you from sending a fax.
Sep 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error 6502 canon MP530
Hello
Try it for a canon
Solution:
All Best: Pineworks
Jun 07, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error 6502canon MP530
Solution:
All Best: Pineworks
Canon IP4500 service error code 6502
canon pixma 4500 service error 6502
Jul 15, 2008 | Office Equipment & Supplies
Canon Pixma IP600D - error code 6502
What is the brand name and model of your printer? Make sure that your ink cartridges are precisely the correct cartridges for the brand and model that you are using. From what I have experienced ... if you try to use a used ink cartridge you will recieve an error.
Please refer to the following link http://www.coldreset.com/modules.php?name=News&file=article&sid=60
Terry
May 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Error 6502
Have you replaced the ink cartridge recently? Service error 6502 is an ink tank position sensor error. Service error 6502 generally means that your ink cartridge chips cannot be recognised. The primary cause of this is the blockage of the LED. Ensure that no tape, glue etc is covering the chip or LED on the rear of the cartridge. Problem more prevalent on third party replacement cartridges or ink systems.
Jul 27, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
306 people viewed this question
old marine
old marine
