Question about Cobra Ga-cs Or Ga-cl Microtalk Charging Stand Charger For Priss Walkie Talkie
What volt charger is needed for (cobra microtalk pr560wx)? Thanks,Richard
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi Richard,
Volt Charger??? I'm not sure what you mean, but if you mean what voltage to recharge the batteries, then you need to look at the unit, all over to find the AC input, there should be something tht states voltage and polarity there, if it infact has one.
Pease reply with more detail re: your query.
Regards,
Peter
Posted on Mar 05, 2013
3 Suggested Answers
mrwtech727
  • 75 Answers
SOURCE: my cobra microtalk cxt450 will
pull the batteries out, slam them ******* a solid surface. put 'em in, let 'em charge. if that doesn't bring 'em back buy new bats.also, use a voltmeter to make sure the charger was getting voltage.
Posted on Sep 04, 2011
kditterline
  • 127 Answers
SOURCE: I too need a charger for the Cobra microtalk Walkie Talkie
u can use a phone charger as long as the jack is the same as your jack, walmart has about any kind they make.
Posted on Jul 16, 2009
My crx700 cobra micro talker won't charging
Will one of them charge? If so, use it to check the other side of the charger. If both sides will charge the good radio then take the battery out of the good one and put it in the one that won't charge. If it now charges, then the battery was bad. If you have a radio that won't charge in either side or on either battery then the power is not getting to the on switch. Check for corrosion. You can use a volt meter to check the charger terminals and see if they are putting out juice. Both sides should read about the same.
Oct 05, 2013 | Cobra Electronics microTALK® CXR700 Two...
Trying to get the batteries out - won't re-charge
check charger with a tester to see if it's putting out what the radio requires. if radio says 6 volts see if charger is that or close.check for corrosion on battery and charger
Aug 18, 2013 | Cobra Microtalk 100 FRS Walkie Talkie...
What (low voltage) goes from wall plug into (charger stand)? Thanks, Richard
I don't know what the question is here for sure but the voltage is converted to 12 volt from the wall to the charger. Milliamps is the only variation from charger to charger.
Jan 22, 2013 | Cobra Ga-cs Or Ga-cl Microtalk Charging...
Walkie talkie radio sku #641068 lost charger
  • Hope this helps.
Oct 28, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
Need online manual for COBRA microtalk 2way radio
Most of the Cobra product models are here: https://www.cobra.com/pages/manuals.cfm . Scroll down to the MicroTalk Two-way radios/ . The direct link to the manual for the CXT90 is https://www.cobra.com/downloads/manuals/CXT90_MANL.pdf .
I hope this helps.
Oct 06, 2011 | Cobra Electronics microTALK® CXT90 Two...
My cobra microtalk cxt450 will not charge. and the charger lights are not on when i place them in the charger
Sep 04, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
Cant charge
first confirm the battery is in properly. then your charger should have an output equal to your battery power, e.g. if the battery is 3.6 v make sure your charger is at least putting out that. make sure the contacts on your charger are making contact on your radio.
Sep 24, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Jul 09, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Brand New Cobra microtalk won't work!
Double check against all the instructions - in particular, make sure the batteries are charged according to "before first use" spec, that the volume is turned up, and that the squelch (if fitted and not automatic) is adjusted properly. If it still doesn't work, take it back to Wal-Mart. If the product doesn't work, there's no need for the packaging to be in good condition - it's not as if they'll be needing it to resell the goods to anybody else. A.
Apr 08, 2007 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Cobra Ga-cs Or Ga-cl Microtalk Charging Stand Charger For Priss Walkie Talkie Logo
218 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
