Question about Samsung HT-X50 System
Repair Samsung HT-X50
I am trying to replace the Display Board on my HT-X50, I have taken apart everything but the Volume control knob, cannot figger how to take this knob off, need to do this to remove the board. I know something has to come off the Volume Control knob to remove it from the board but cannot see what. This seems real simple but this has me stopped. Thanks, Ronne
  • Britt73 Feb 02, 2009
    what is the part # for the board I need to replace mine due to static charge that srewed up the display?Thanks
Samsung HT-X50. I just installed a new 50" plasma TV and cabled the digital out to the Samsung HT-X50 digital in via an optical cable. The TV audio is now heard through the HT-X50 speakers but only...
Look into the TV's audio controls. If it was my setup, I'd NOT send audio through the TV to the hifi, nor video through the hifi to the TV. Additional hops and interconnects cause problems even though they're theoretically transparent.
Jan 23, 2011 | Samsung HT-X50 System
My HT-X50 front display screen has all of the LEDs lit up like they do when it is first powered up (self check). They all stay on regardless of the mode the unit is in - DVD, Aux, etc. The room the unit is...
The display is damaged. This is how this series dies. In some cases the receiver still works except you can't see the display. Samsung service center can repair it, nobody else.
Apr 01, 2010 | Samsung HT-X50 System
Hi, I have Samsung HT-X50 connected with SWA-4000. It was working fine, then for somereason I had to remove and reinsert Tx card. After doing that SWA-4000 is not connecting to HT-X50. Blue light blinks...
You have to reset the connection:
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Jun 09, 2009 | Samsung HT-TZ515T Theater System with...
Samsung HT-X50 and HP Personal Media Drive
you need to format as fat32... use a mac computer... otherwise it wont recognize it... no NTFS... just fat32... that is how i did it.. hope this helps you.
Aug 25, 2008 | Samsung HT-X50 System
Remote issue
Loose connection or cold solder and cleaning problem this is the main caused of your remote to malfunction.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. Try to resolder the solder joint so it works normal again..
Jul 10, 2008 | Samsung HT-X50 System
The display shows all the icons of the sytem and wont clear...
$38 part from Sears PartsDirect took about 30 mins to install.  Part # AH92-02673A Ay pcb-front.  There are actually 2 boards to this setup, I went ahead and replaced both but the power button side of the board has some wiring that requires you to remove the disc changer which is only 4 screws and 2 screws for the piece that holds the disc above the reader.
I couldn't find an easy way to get the knob off on the front it required me to force it, nothing borke but your replacing the board anyways..
Jan 09, 2008 | Samsung HT-X50 System
Shutting off When Volume is Turned Up
geting hot is sumting on it welll vented ?
Dec 25, 2007 | Samsung HT-X50 System
Samsung HT-X50 System Logo
120 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
