Question about Sewing Machines
How to thread singer sew mate 5400
I haven't sewn in years and i just bought the singer sew mate5400 and would like to know how to get started threading the machine from pictures of doing it from online, Sometimes that's the only way for me to really see and know how to get things right. Can you help?
louislevel_2
  • 374 Answers
SOURCE: How do you thread a SInger Sewing machine 2623
hi! there,
you can show some actual bobbins winder and threading go to internet explorer and type the address of "www.youtube.com" then on search type "sewing machine".there is a slide show for sewing instruction.just click the slot and it play the video showing what you want.regards don' t forget to rate me.
Posted on Apr 09, 2009
  • 25 Answers
SOURCE: machine is threaded but thread not sewing into material, just holes!
Check bobbin thread....Insert the bobbin thread into the bobbin case in a clockwise direction...pull the thread through the **** on side of bobbin case and slide up into small opening...make sure you pull through about 2 inches of thread to enable upper thread to loop. Good Luck
Posted on Jun 02, 2009
  • 139 Answers
SOURCE: How do I thread a Singer 6104 sewing machine
http://www.singerco.com/resources/threading.html Check out their threading diagrams, they are really helpful!
Posted on Apr 05, 2010
  • 139 Answers
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
http://parts.singerco.com/IPsvcManuals/
Posted on Apr 07, 2010
  • 5 Answers
SOURCE: How do you thread the machine, top and bottom, please.
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin.
NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  1. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  2. Slide bobbin cover back into position.
Upper threading:
  1. Turn the handwheel toward you to raise the take-up lever to its highest position.
  2. Lower the presser foot.
  3. Place a spool of thread and spool cap on the spool pin.
  4. Place the thread into the first thread guide at the top of the machine.
  5. Bring the thread down the right slot of the threading path, then around the tension dial. Push the thread tension release lever and pull the thread up so the thread is secure in the thread tension dial.
  6. Bring the thread up the left slot of the threading path and through the take-up lever from right to left.
  7. Bring the thread back down the left slot of the threading path and into the needle eye from front to back. (Clip the thread end with sharp scissors fro easier needle threading.)
Raising the bobbin thread
  1. Make sure the presser foot lever is raised.
  2. Hold the end of the needle thread with your left hand. Turn the hand wheel toward you with your right hand until the needle goes down once and comes back up, stopping when the needle is at its highest position.
  3. Gently pull up on the needle thread. The bobbin thread, looped around the needle thread, will be drawn up through the needle hole.
  4. Push the thread tension release lever and pull about six inches of both the upper and lower threads toward the back of the machine, placing them under the presser foot.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Posted on Jul 29, 2010
How do you replace bobbin
Usually, slide back the footplate, release the catch on the bobbin holder and lift it out.
the manual is available here at a cost
http://www.sewingpartsonline.com/instruction-manual-singer-5400.aspx
This one says it is available free
http://issuu.com/service-repair/docs/singer_5400_series_service_manual.pdf
Sep 23, 2015 | Singer 5400 Sew Mate 60-Stitch Sewing...
How do I fix the looping under the material when I sew?
the looping on the bottom usually is a tension problem, the top & bottom tension are unequal usually fixed by adjusting the top tension.
some people that I've talked with have had success with changing to a different size needle ( depends what type of thread is being used).
when the machine is threaded the foot needs to be up ( this releases tension on the thread), when the foot is lowered it the tension is set on the thread. if the material being sewed is too thick it raises the foot too high & releases tension on the thread ( the material has to be really thick to do this).
if there a piece of thread or lint in or around the tensioner or bobbin area it could cause trouble.
other wise if you've tried everything you can think of, take it back th the store & have them try it & tell you what is wrong.
also this machine has bad reviews (i'll provide a link so you can read them), people having the same problems as you are. the newer singers just don't seem to be the same quality tha the older ones were.
all bad reviews
http://www.amazon.com/Singer-5400-60-stitch-Sewing-Machine/product-reviews/B007ZG9DTQ/ref=cm_cr_pr_btm_link_1?ie=UTF8&showViewpoints=0&sortBy=byRankDescending
mixed reviews
http://reviews.walmart.com/1336/20573406/singer-5400-sew-mate-60-stitch-sewing-machine-5400-reviews/reviews.htm
Aug 26, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
I have a singer Sew Mate 5400 and the top thread gets so tight
Ok, you definitely have something going on. So you'll need to try the following.
1. Re thread the machine making sure the presser foot is in the up position.
2. Make sure your needle and thread are the right size for each other.
3. Check that your thread spool or spool keeper disk doesn't have a burr that is catching the thread.
4. Make sure the thread isn't wrapped around the thread spindle.
Aug 15, 2012 | Singer Sewing Machines
How to thread twin needle on singer
Look in your attachments for the secondary spool pin. Then you'll thread both upper threads as normal.
Jul 30, 2012 | Singer Sewing Machines
I bought a Singer in 1993 model 9410, serial # 323310126. I no longer have a manual and haven't used it in years, but thought I might try. Can't even remember the proper way to thread it. Is...
Try this link: http://www.singerco.com/accessories/instruction-manuals Type model no. in the search field and press Search. You'll be able to choose to pay or download for free! Good luck!
Jun 27, 2011 | SINGER 7470 Sewing Machine
I have the same problem, new machine, and I haven't sewn a stich.
Machines should be bought from local dealer who actually has a clue how to show someone to us it. Sorry for your problems but commonly they are operator error
Oct 14, 2008 | Singer 2732 Mechanical Sewing Machine
Sewing Machines Logo
377 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
