Question about ASUS Computers & Internet
Max temperature 5pld2-vm/s with e6300 not overclock
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 2,226 Answers
Http://www.asus.com/Motherboards/P5LD2VM/HelpDesk/
Posted on May 25, 2014
2 Suggested Answers
SOURCE: overclocking with p5sd2-vm motherboard.
i have no install the sound driver please help to the install...............
Posted on Jul 27, 2010
Issue modify vcore for e6300
Really?
Are we talking about the Asus P5LD2-VM motherboard, Zoltan?
(Zoltan is a C-o-o-o-o-l name!)
Because I'm looking at the motherboard manual right now, and state you are mistaken.
1) Use the Right Side Arrow key, and highlight the - Advanced - tab on top of the Main menu.
2) Use the Down Arrow key and highlight -
JumperFree Configuration
Press the Enter key.
Configure System Frequency/Voltage
AI Overclocking - [Auto]
Use the - key, (Minus), and move Auto to Manual
Use the appropriate arrow key, and highlight -
CPU VCore Voltage [ Auto ]
There are 40 Voltages you can choose from.
1.7000Volts to 1.2875Volts.
Remember,
Use SMALL increments at a time. Do a 24 hour stability test.
(Small increment example, 1.7000V to 1.6875V )
If your system is stable for 24 hours, then you can come back, and change the Voltage one more small increment.
(1.6875V to 1.6750V)
Also remember; you are changing the Front Side Bus of the Processor. (FSB)
Change it TOO much, and your ram memory, and expansion slots will not work.
(Ram Memory typically operates at a frequency rate ('Speed'), of half of the FSB of the Processor.
Processor FSB is 800MHz for example? Ram Memory operates at 400MegaHertz.
Intel Core2 Duo E6300? 1066MegaHertz Front Side Bus.
{1066MHz FSB}
Ram memory? 533MHz)
Asus Support > P5LD2-VM > Download page,
http://www.asus.com/Motherboards/Intel_Socket_775/P5LD2VM/#download
For the - Select OS box, click on the blue Down Arrow, and choose WinXP. (Doesn't matter as you are just going for the manual)
Click on the + sign next to Manual (14)
Scroll the inside scroll bar down until you come to -
Version E2281 -
P5LD2-VM User's Manual for English Edition (E2281)
Click on the blue - Global
A PDF file version of the motherboard manual will come up.
Using the PDF file page number box at the top, go to;
Page 63 - 2.4 Advanced menu
Page 65 - CPU VCore Voltage [Auto]
http://www.techwarelabs.com/reviews/processors/e6300/
Overclocking article at the end. Just one of the hundreds of overclocking articles out there.
Regards,
joecoolvette
Aug 15, 2012 | ASUS P5LD2-VM Motherboard
I cant overclock my system but i go to bios now whati had to do
The BIOS. Overclocking is best done in the computer's BIOS (Basic Input/Output System or Binary Integrated Operating System). There are also some motherboards that let you do a basic increase in power by setting a jumper, but this is dangerous and you have no real stability control.
There are some software programs available which allow you to overclock inside the operating system, but the best results are achieved by changing BIOS settings. Usually you can get into your BIOS by pressing DEL (some systems may use F2, F10, or Ctrl-Enter) as soon as your computer begins the POST
(Power On Self Test - when it shows the RAM size, processor speed, etc.).
Here, you can change your FSB (front side bus), memory timings, and your CPU multiplier (also referred to as CPU Clock Ratio).
Clearing your CMOS. Sometimes, an overclock can become unstable. If this happens, or your computer will not boot, you will need to reset the BIOS back to default and start over again.
This is done by clearing the CMOS (a small piece of memory on the motherboard which stores your BIOS configuration, and is powered by a small battery). Some newer motherboards will bypass user settings in the CMOS if the computer fails POST (often caused by a faulty overclock). However, most motherboards require a manual clear.
This can be done in two ways, depending on your motherboard. The first way is by changing the position of the clear CMOS jumper on your motherboard, waiting a few minutes, then repositioning the jumper to its original place.
The CMOS Jumper
The second way, if your motherboard doesn't have this jumper, consists of unplugging your computer, removing the little CMOS battery, then pressing the power button (your capacitors will discharge), and waiting a couple of minutes.
Then you have to refit the battery and plug in your computer. Once your CMOS is cleared, all BIOS settings are reset back to default and you'll have to start the overclocking process all over again. Just so you know, this step is only necessary if your overclock becomes unstable.
Locked or Unlocked. The first thing to know when you start the process of overclocking, is whether your processor is multiplier locked or unlocked.
To check whether your CPU is locked, lower your multiplier via the BIOS one step, for example from 11 to 10.5. Save and exit your BIOS and your computer will restart.
If your computer posts again and shows the new CPU speed, it means your CPU is unlocked. However, if your computer failed to post (screen remains black) or no CPU speed change is present, this means your multiplier is locked
Multiplier Unlocked Processors. Usually, your max overclock is limited by your memory, or RAM. A good starting place is to find the top memory bus speed in which your memory can handle while keeping it in sync with the FSB. To check this, lower your CPU multiplier some steps (from 11 to 9, for example) and increase your FSB a few notches (e.g.: 200 MHz to 205 MHz).
After this, save and exit your BIOS. There are a few ways to test for stability.
If you make it into Windows, that is a good start. You can try running a few CPU / RAM intensive programs to stress these components. Some good examples are SiSoft Sandra, Prime95, Orthos, 3DMark 2006 and Folding@Home.
You may also choose to run a program outside of Windows, such as Memtest. Load a copy of Memtest onto a bootable floppy, then insert the disk after you have exited the BIOS.
Continue to increase your FSB until Memtest starts reporting errors. When this happens, you can try to increase the voltage supplied to your memory.
Do note that increasing voltages may shorten the life span of your memory. Also, another option is to loosen the timings on the memory (more on this a bit later). The previous FSB setting before the error will be your max FSB. Your max FSB will fully depend on what memory you have installed. Quality, name-brand memory will work best for overclocking.
Now that you know your max FSB, you'll figure out your max multiplier. Keeping your FSB @ stock, you raise your multiplier one step at a time. Each time you restart, check for system stability. As mentioned above, one good way to do this is by running Prime95.
If it doesn't post (reread the section about clearing the CMOS), or Prime 95 fails, you can try to raise the core voltage a bit. Increasing it may or may not increase stability. On the other hand, the temperature will also be increased. If you are going to increase the core voltage, you should keep an eye on temperatures, at least for a few minutes.
Also note that increasing voltages may shorten the life span of your CPU, not to mention void your warranty. When your computer is no longer stable at a given multiplier setting, lower your multiplier one step and take that as your max multiplier.
Now that you have your max FSB speed and your max multiplier, you can play around and determine the best settings for your system. Do note that having a higher FSB overclock as opposed to a higher multiplier will have a greater impact on overall system performance.
http://www.pcadvisor.co.uk/news/index.cfm?newsid=107977
hope this helps
May 30, 2012 | Computers & Internet
Overclocking with p5sd2-vm motherboard.
Jul 27, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Overclock fan speed question
The amount that you can overclock you're video card differes for each individual card. The limiting factors are temperatures and stability. If games start crashing, etc you should back off the overclocking. Also keep in mind the temperature of the card. Increasing fan speeds will lower the temperatures of the card. Increasing the fan speed (as long as you don't go beyond 100%) will not damage the card... It will be louder though. For the 9800gt, the maximum temperature before damage is 105 degrees C. Try to keep the temperatures at 80 or below optimally. Increasing the fan speed is the best way to accomplish this.
Jan 17, 2010 | Nvidia Zotac GeForce 9800GT Amp Edition...
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
P5RD2-VM recognises only 2 GB
According to Asus, the max supported memory is 2 gig. That second stick of 512 is not needed and the error shown is in memory configuration.
Hank
Aug 03, 2009 | ASUS P5RD2-VM Motherboard
Overclocking E6300 on GA-8I945GZME-RH
yes you can. but awar of thet instability can appare..
Jan 09, 2009 | Gigabyte GA-8I945GZME-RH Motherboard
Overclock an Intel E6300 on a GA-8I945GZME-RH motherboard
You need to check your BIOS. If you can overclock you will see a selection for CPU and speed in BIOS. If not there then your motherboard does not allow you to overclock your CPU.
Rate this solution.
Jan 09, 2009 | Intel Core 2 Duo E6300 / 1.86 GHz...
P5ld2-vm problem
go to "bios settings" by pressing "delete" key or F2 at the system start up time .. after going in to bios then search for the options load optimal defaults ....then save it and exit ..
after that restart ...
now have a check if your problem persists then the processor which you have choosed might not support the motherboard specification the frequency of the processor is higher than the specified rate .. check here for the details of the processor which supports your motherboard
Intel Core 2 Duo HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.L2 1102 2.00G HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.L2 1202 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0492M BX80557E4500 E4500 2.2GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0562M BX80557E4600 E4600 2.4GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0642M BX80557E4700 E4700 2.6GHz,800FSB,L2:2MB,revG0 1401 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0364M BX80557E6320 E6320 1.86GHz,1066FSB,B2:4MB,rev.B2 1202 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0464M BX80557E6420 E6420 2.13GHz,1066FSB,L2:4MB,rev.B2 1202 2.00G HH80557PH0564M BX80557E6600 E6600 2.40GHz,1066FSB,L2:4MB,rev.B2 0901 2.00G HH80557PH0674M BX80557E6700 E6700 2.66GHz,1066FSB,L2:4MB,rev.B2
check the website given below for details :
http://www.cpu-upgrade.com/mb-ASUS/P5LD2-VM.html
thank you
rate my solution
Sep 10, 2008 | ASUS P5LD2-VM Motherboard
Overclocking failed
Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
Sep 01, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
69 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
