Cd-player does not work in onkyo cr-185
CD drawer opens and closes wildly
  • 1153 Answers
SOURCE: Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Posted on Oct 08, 2007
robotek
  • 1512 Answers
SOURCE: I have a marantz cd
Hi dr dray
Your player has a CDM12.1 laser transport fitted to it. They suffer a couple of problems that can be fixed that stop em from working so well. If you are handy with a screwdriver, then I can talk you through it.
regards
Robotek
Posted on Apr 28, 2008
  • 4234 Answers
SOURCE: I have Onkyo cd player
Try opening up the unit and cleaning the lens using a cotton swab and alcohol. The skipping is caused by the loss of the tracking information from the disc or the motor getting stuck. While the unit is open, clean the silver rail that the optics assembly rides on using a dry cotton swab. That should resolve the problem assuming that the optics are not starting to fail. These units can be adjusted a bit as well, but that requires an alignment CD as well as some test gear. Let us know how you make out.
Dan
Posted on Apr 30, 2008
latinmcgyver
  • 208 Answers
SOURCE: Cd drawer opens and closes by itself
the sensor that tells it when door closes under door theres a guide that flips a slide switch as it goes in is failing. bad hardware!
Posted on Nov 13, 2008
SOURCE: onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Posted on Dec 20, 2008
Cd drawer will not stay open
It may just need a good cleaning and a can of computer compressed air while drawer is open. Let us know. Thank you Phirohrer and please leave feedback. Good luck
Jul 12, 2016 | Onkyo DX-C380 6-Disc CD Changer
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
ONKYO CR-315 cd player locked.
Hello
Just try to reset the CD receiver by holding the clock call button and pressing the STANDBY/ON button.
Nov 30, 2011 | Onkyo CS5VL Super Audio CD Player Black...
Drive belt replacement to open and close cd drawer for Onkyo DX-2700
I have no idea where you are located, but I know this guy has belts for everything, you just need to know the size (or he can look it up).
UNIVERSAL AUDIO VIDEO ELECTRONICS
1137A QUEEN STREET EAST
M4M 1K9 Toronto, ON
Phone: 1-416-461-9899
Mar 01, 2011 | Onkyo Audio Players & Recorders
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Open & close button Does not work
Being that it is an old unit, even though it worked just fine except I had to open and close the drawer by hand. I sent it to the trash bend, It was an Onkyo C110. Thanks anyway!....Bob
Nov 19, 2008 | Onkyo DX-C340 CD Player
Loading tray will not load or close-reopens immediately
Sounds like the tray position switch has gone wrong.
Sep 30, 2007 | Onkyo DX-C340 CD Player
Cd stuck in
take the cover off and take the CD out
Oct 06, 2006 | Onkyo DX-C390 6-Disc CD Changer
67 people viewed this question
 Grubhead
Grubhead
