Question about Maytag MMV1153A Microwave Oven
My microwave just stopped.
Could you tell me how to find and replace the fuse?
    Scholar:
  • 93 Answers
First a warning microwaves can be dangerous there is a lot of voltage in there waiting to get out and if you touch the capacitor you will get shocked and seriously injured so take care,the cover must be removed by takeing out the screws at the back of the panel sometimes there are screws at the sides or underneath.then look on both sides one side will have a fan and a big thing on the base this is your transformer(do not touch)you will see a wire with a larger plastic tube in the middle from the transformer(do not touch) that goes to a silver device with two wire attached this is the apacitor(really do not touch this can kill you)take a pair of well insulated long nose pliers and pull the wire with the plastic tube from the capacitor first the pull it from the transformer turn the tube in opposite direction to open you will see visually if the fuse is blown if so replace and reverse process to reasemble there is also some times a fuse on the pc board(if you have one)located behind the display panel normally a white ceramic fuse and on most machines whe the power cable comes inside the machine it is joined to a pc board there is normally a glass or ceramic fuse there check these first before going to the mains fuse between the transformer and the capacitor please again this is a dangerous piece of equipment respect it or it will bite you
Posted on Jan 26, 2009
Where can i find the fuse in this magic chef microwave. I was cooking rice and power just stopped. Not the outlet.
I've used several microwave ovens and NONE of them had a serviceable fuse but maybe this video might help you
https://www.youtube.com/watch?v=IN0BqiVX5ds
Apart of this fact, honestly I don't know have any mocrowave elctronics knowledge to hepl you diagnosing the failure.
If your oven stopped working and you don't have electronic knolwedge to repair it, bad new is that you should take it to a reapair service.
In any case, you may read about issue on line, open thhese links:
Microwave Not Working
How to Fix Microwave Oven Simple Fuse Replacement
My microwave stopped working What should do ACP
GE Profile Microwave JE1390 stopped working
Sep 07, 2015 | Magic Chef Microwave Ovens
LG LMV1813ST MIRCOWAVE STOPPED WORKING?
The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
If the microwave is not working the thermal fuse may have blown.
When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Aug 02, 2014 | LG LMV1813ST Microwave Oven
Whirlpool over the counter microwave stopped working
SEE THE steps and fix it. and diagrams attached.use the DVOM.God bless you
Line Fuse
Every microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
Main Control Board
If the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Thermal Fuse
If the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown2_6_2013_8_43_03_pm.gif2_6_2013_8_43_37_pm.jpg
Feb 06, 2013 | Microwave Ovens
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
Microwave blows fuse in microwave mode grill function ok
It is most likely the capacitor has shorted or the rectifier has shorted. Check with ohmeter, but make sure it is discharged first by shorting the capacitor with a wire.
May 21, 2010 | GE Advantium 120 Convection/Microwave Oven
Microwave has stopped working after being run empty for a short time. Is there a fuse that needs to be replaced or is the microwave dead?
There is a fuse inside the oven. The rating of the fuse may be 8amps. It is not suggested to run the oven without load inside.
May 04, 2009 | Kenmore 63252 Microwave Oven
Thermal fuse needs replacing.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjkj
Apr 18, 2009 | Daewoo KOR-630A Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Maytag MMV1153A Microwave Oven Logo
81 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
