Question about Hotpoint Washing Machines
Washing machine makes noise when spining - Hotpoint Washing Machines
    New Friend:
What kinda of noise? If it's banging, it's an unbalanced load and you need to open the machine and realign the contents. Or the agitator may need to be adjusted If it's a squealing noise, you may have something caught around the adgitator. Anything else snd we'd more info
Posted on Jan 20, 2013
  • 1314 Answers
SOURCE: washing machine spine
you have something jamming your water pump you may have to cleanout the pump and replace the motor coupling Well I'm going to do my best to fix your washer. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Jan 16, 2008
  • 958 Answers
SOURCE: washing machine making crackling noise when spinning
check for some loose items underneath the unit. washing machines normally reverses its rotation when spinning. check if mechanical solenoids pulls the right levers as it starts to spin....
Posted on Feb 12, 2008
Illeagle
  • 525 Answers
SOURCE: Amana NAV8800AWW making noise while running and spining
Spin Shake is usually contributed to a weak floor support condition. Also, carpeting under the leveling legs can cause a "spongey" effect, which can produce the shakes. Prolonged shaking can cause parts to loosen and make noise.Firstly, we must determine what loosened up from all the shaking.
Remove the front panel by removing the 2-5/16" screws located at the bottom front. Pull out at the bottom to release the top retainer clips, and set aside.
Warning! Never reach inside the machine while it is in operation!
Investigate the cause of the noise by setting the washer to spin, and turn on. Inspect all moving parts for possible wear or breakage. Next, stop the machine and inspect for loose or worn suspension parts, nuts, bolts, struts, hoses banging the cabinet, etc. A protective motor cover can cause noise, or a belt slapping the base mount. Once you have conquered your noise issue, then we will have to eliminate the shakes, provided, what you repaired wasn't the cause...and usually isn't.
Carpeting under the leveling legs should be removed or cut away.
If other items in and around the laundry room shake, then you will need to add support to your floor joists. Shim the floor from under the house while the washer is spinning for best results.
Your installation instruction manual should tell how level the washer properly, after you have added support to your floor.
Good Luck! Post me back if can be of more assistance.
Dave E. (Illeagle)
Posted on Jun 06, 2008
  • 25 Answers
SOURCE: My washing machine makes noise. I want a washing
all washing machines make some sort of noise LG make a washing machine that is a direct drive no belts or pulleys less vibration these seem to be a lot quieter
Posted on Jul 16, 2009
SOURCE: spining makes noise and machine vibrates a lot
All machines vibrate and make sound while spinning including front load. Dont worry, its perfectly fine
Posted on Sep 01, 2009
Bosch 500 next ers washer has a bad grinding noise when spining it's getting very loud
Clothes load may be out of balance, try to rebalance load, may take multiple tries. My bet, it doesn't make this noise if just water in the tub and spin out. However, if it makes this noise with just water in the tub, you may need serviceman to look at it. How old is the machine? Service may cost more than a lightly used replacement.
Mar 04, 2015 | Bosch Washing Machines
THE DRUM ON MY MACHINE ISNT GOING AROUND AND IT'S NOT SPINNING
Is it old washing machine?
One problem could be belt. It could be dropped. If you hear motor spining noise, but drum isnt spining - this is it.
If you cant hear anything - motor carbong brushes..
If not - electronics problems (semistor or etc).
I need more info to help you better.
Apr 05, 2013 | AEG Lavamat 74640 Front Load Washer
I n the spine cycle the washer makes a loud noise and shakes.I found a dime under the tube between the rim and door gasket.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 22, 2010 | LG WM2016C
Washer makes straining noise when draining water from tub while spinning?
my admiral washer machine model AAV7000AWW makes a noise only when draining/spining water, is no water spill at all. Thanks
May 21, 2010 | Washing Machines
My front loader wont pump out the water when spining and when the machine is washing it makes a terrible loud screeching noise.
Mine does the exact same thing, only now I can only wash underwear in it as anything else is too heavy for machine to turn while washing.... My socks have dissappeared wonder if thats whats stopping it from turning or maybe thats just my messy kids making them dissappear!lol I've all but given up on it and think I'll dump it for top loader...
Feb 16, 2010 | Samsung WF337AA Front Load Washer
Washer makes loud humming noise when aggitatingand spining and shuts down
something is stuck in you water pump if removing object not stop noise then replace the pump
Aug 23, 2009 | Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
