Question about Alpine Car Audio & Video
3.5 jack on the back of the alpine CTA 1505 R what,s its purpose
I was wondering what the 3,5 jack on the back of my Alpine CTA 1505 R is for. can,t find the 3,5 jack in the manual al the other cables are clear to me but i can,t find anything about the jack cable. I was also wondering witch cd changer plays mp3 discks en will work properley on my alpine CTA 1505 R.
5 Suggested Answers
SOURCE: cta-1505 auxiliairy input
you supposed tu turn mute off and the pink cable to ground
Posted on Mar 04, 2008
SOURCE: Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Posted on Nov 06, 2008
SOURCE: I need a manual for Alpine CDM 7871R car audio
Try this
http://www.restricted.alpine-electronics.co.uk/support/ownersdatabase/CDM-7871R/OM_CDM-7871R_EN.pdf
Posted on Feb 19, 2009
  • 6 Answers
SOURCE: Alpine CDM-7861 will not work with IPOD M-BUS cable attached.
Were you guys able to get this to work?????
Posted on Jul 05, 2010
Hello iv jus bought a alpine cde 113bt and it wont play my music through usb on my iphone can you help???
Either way, Most Alpines don't support iPhone through the USB jack. You need the KCE-433iV iPod cable which plugs into the back of the Radio.
Jul 03, 2011 | Alpine GPS
Bass aint working how to turn on menu features with out remote control
Press and hold the INTLZ button for at
least
3 seconds.
Notes:
Initial mode is "SUBW OFF."
Set to "SUBW OFF" unless the
subwoofer is used.
When the subwoofer is turned on, the
subwoofer output level can be adjusted.
For more details, refer to the Adjusting
Volume/Balance/Fader
hope this solves youre problem found it in the manual.
Apr 19, 2010 | Alpine CTA-1505
Connecting mp3 player other than ipod to cda 9851
CLICK HERE for your owners manual in PDF format.
Please see Page 19 on how to toggle ON the AUX IN function on the radio
A KCA-121B (alpine bus to RCA) adapter is required.
-or-
AI-3NPUT (alpine bus to Female 3.5mm) adapter is required.
There is no alternate INPUT on the rear of this radio - an adapter is required... converting the changer port to an input.
Thanks for using FixYA - a FixYa rating is appreciated for answering your FREE question.
May 12, 2009 | Alpine CDA-9851 CD Player
Haveing trouble hearing sound when I have my IPod connected
You need a AI Net cable or Speed Cable... It plugs into the back of the radio (looks like a circle with holes), and the other end can have a "Y" plug (headphone jack and iPod flat jack). The headphone jack for sound, the flat jack to charge he iPod while listening. I just bought mine on Crutchfield.com for $29.99. With the discount code: 3A156 you can get standard shipping free. The item # is: 127ICALPA and it's named "PAC iPod Adapter for Alpine".
Mar 14, 2009 | Alpine CDA-9833 CD Player
Alpine 7190ET Manual
Enter Alpine car audio in your search engine and go to alpines home page and then click on support then enter in the product # SWR-1242D and it will pull up the manual.
Mar 09, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
I have a Alpine CDA-9830. It has a AUX setting and so I was wondering if I can connect an ipod to it? I cant seem to find any input for a cable. I looked online at the manual, but it didnt really answer my...
Hey Guys,
This is the part you need..its an adapter for Alpine stereo..its called the ainet to rca.. then all you need to do is get a stereo jack cable to rca and plug the stereo jack cable in to the ipod and rca's in to the adapter..it plugs on left side of back of the unit if you are looking at it from behind
KCA-121B
cheers
Oct 23, 2008 | Car Audio & Video
How do I add an Aux input?
Does your Alpine support the ALPINE AI NET adapter?
If so, this will work;
http://www.installer.com/item/display_item.php?it=alp-ai-35mm
Otherwise, you might want to get an FM Transmitter;
http://www.amazon.com/Griffin-White-iTrip-Transmitter-iPod/dp/B0000AAAPF
Best of Luck.
Please RATE my solution BELOW.
Nov 24, 2007 | Alpine CTA-1505
How to wire a stereo system
Connect the 2 gage to the battery thru at least s 50 amp fuse, then connect the capacitor in line before the amps. Then run the 2 gage to a connector/splitter block and run 4 gage leads to each amp. You also will need at least 4 gage ground leads from each amp to a body grounded bolt or screw. You need to run a quality set of speaker leads from the head unit to the amps. The speakers will need separate leads from the amp to each speaker.You will need to try some different combinations to get the sound and bass you want. You want to be able to fade from front to rear and control everything thru the head unit.
Use a hole saw to cut a 2 to 3 inch diameter hole in the side of the speaker box for a port to get a better punch from the sub.
Hope this helps some....
Nov 03, 2007 | Alpine CDA-7863 CD Player
Cta-1505 auxiliairy input
Oct 09, 2007 | Alpine CTA-1505
Car Audio & Video Logo
240 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
