Question about Garden
GK425 oil not getting to chain
Oil reserve is full but not flicking oil from chain when in use
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 18 Answers
Make sure the bar groove is clean and free of debris. Run the saw without the bar and chain to see if oil is coming out. If not you will need a new oil pump.
Posted on Jan 23, 2013
  • 1 more comment
  • Owen Cooper Jan 23, 2013
    Is it possible to buy a new pump?
  • Mike Forrest
    Mike Forrest Jan 23, 2013
    www.toolsandpartsdirect.co.uk/Black--Decker-GK425.......Try this site. It has a great parts breakdown. Also how to order.
  • Owen Cooper Jan 25, 2013
    many thanks for your help
dennisgladx
  • 52 Answers
SOURCE: Insufficient chain oiling
Sorry to tell you this but you need a new OIL PUMP but it's not a difficult thing to replace.
On the main shaft of the crank shaft under the centrifugal clutch is a spiral wound wire that matches a plastic part that is the oil pump. You can get the part from Poulan parts and it will take about 15 minutes to fix the first time eight minutes the second time.
Glad to be of assistance.
Posted on Oct 20, 2008
SOURCE: stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
Posted on Apr 24, 2009
SOURCE: Chainsaw bar is dry. Chainsaw is full of oil.
I have Poulan 2375 Wild Thing and auto oiler stoped working. After disassembling I found the oil pump plastic driven gear was damaged by the metal drive gear. The gear was damaged because iol pump was locked up do to dirt in pump. The replacment pickup line has a filter the pump and line kit sell for around $12.00 at Home Depot on line a simple repair for any one with some mechanical abillity.
Posted on Jul 01, 2009
dontbother10
  • 2220 Answers
SOURCE: I Have a poulan brand chain saw that the bar oiler
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
An example of a Poulan “PP220 Gas Chain Saw Type 5” IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP220-Gas-Chain-Saw-Type-5/75.PP220-Gas-Chain-Saw-Type-5.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for the oil system and is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly.
It has an outboard clutch use this and the IPL as a guide for removal. R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If your saw is not a Type 7 an IPL for all Poulan chainsaws can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 04, 2010
  • 518 Answers
SOURCE: bar oil doesn't seem to oil the chain while
the oilways feeding the chain must be chocked with sawdust,,a clean out will help
Posted on Jul 07, 2010
Makati DCS 4610 chain saw is not getting oil through to te chain but the tank is full
How old is the saw? The first and easiest thing to do will be to drain the oil tank and make sure that filter isn't plugged. It's probably wise to fill the tank half way with fuel mix while it's empty and give it a few good swishes to clean it out real good. Next make sure that oil holes on your bar aren't clogged with gunk. After that take off the clutch cover, and remove the bar and chain. Start the saw and see if your getting any oil to the discharge. If you have oil there, make sure that the oil hole on the bar lines up with the oil discharge on the saw. If you're not getting oil at the discharge, your oil pump is likely faulty.
Mar 17, 2017 | Garden
Performance Power Tool chainsaw does not let the chain oil get to the chain the tank is full I have cleaned the chain end where the oil should come out I have blown compressed air thru the oil tank
It can be the oil pump, it but first control it unmount the chain and chainring look at the guide bar there is a little hole in it its can be clogged but if not !! .start your engine without this guide bar on it and in a short time then there must be come oil out on the place where it should near that hole , if the oil is to old it can be thick use always special chainoil and dont forget it under all circumstances to use because the guide bar not only but the tool will become to hot and will become worn in a short time.
Fill the oiltank always full .
Best is the most synthetic oil you can get because of overtime the chain will become motionless after long inactivity and then you must burn your chain links free of wood rosin.
Some oils will do their protect job better , but the natural oils not all.
Dec 07, 2016 | Garden
How do i clean oiler for chain on stihl farm boss?
The filter could be stuffed with sawdust, but depending on the model of saw, the problem could also be the oil pump drive system.
First of all though, empty out the chain oil and then part fill the chain oil tank with petrol, replace the cap and with the saw switched off, shake the saw violently for 10 secs. Remove the cap and empty out the tank and then refill with chain oil and try out the saw, revving it and check if any oil is flowing onto the chain.
If that has not solved the problem, let me know what the model of the saw is, Farm Boss is not enough, it could be an 038 an 041 and a few more as the farm boss name is used as well as the number.
We can then check a few other points which could be causing the problem.
Sep 16, 2014 | Stihl Farm Boss Chainsaw 16"
I dont know why the chain won't get oiled? everything runs fine. full of oil. but chain gets dry and burns. Why?
clean your bar out with a feeler gauge and go all the way around it and clean the 2 oil holes in it too. start the saw with bar off and run it momentarly to see if oil is coming out the oil hole, if not replace you oiler
Sep 16, 2011 | Garden
We have a riding mower w/a 18hp 4 cycle onan engine in it. my husband rebuilt it last winter. it runs but oil is coming out of the exhaust. could it be to much oil in the reserve?
Yes. The oil reserve has probably become contaminated with fuel. Check the oil level, if it is over full change the oil and fill to the correct level. Also fit an inline fuel tap and turn the tap off when the mower is not in use. This will prevent a repeat of the problem. Regards Phil.
Apr 17, 2011 | Garden
Not getting any oil on the chain and the oil is full
Remove the bar and chain--clean the cover and case side. Start the engine and see if oil oozes out of the side port where the bar fits. Also, try the manual oil pump if it exists. If ok, clean the bar end oil-passages including the two channels that run from the large holes out to the chain groove on each side of the bar. Clean the entire chain groove, and check the tip sprocket for free turning. If no oil came out of the port, then remove the rear case which exposes the two tanks, the oil pump and the bracket that holds the bar to the engine. The oil pump runs by use of crankshaft impulses and has a diaphragm in the pump body that may be damaged. Also check the tank filter fitting. When you get everything back together, run the bar tip at speed near some cardboard--it should throw off a thin line of oil after several moments of fast running. Hope this helps!
Jun 19, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My remington 16 inch electric chain saw is not oiling, how do i fix it?
Start by making sure it's unplugged. Then remove chain, and bar, and clean oil slot in the bar and all of the housing in the area the oil comes out onto the bar. I use carb cleaner (safer than gas) and then empty and clean the oil reserve. Refill with straight 30 weight. Never use car oil like a 10w30 or 5W40! Then prime (pump) and start the saw without chain or bar. You should see some oil squirt out. If not, soak a clean empty oil reserve overnight in carb cleaner and try again.Once the oil path is clean, you should be back in business. If not - see your authorized service center.....LOL
Jun 17, 2010 | Remington 16" Electric Chain Saw Assembled...
Husqvarna 350 oil not getting to chain
Take the bar and chain from the saw. Clean the two small ports that run from the large oil holes at the drive end of the bar out to the chain groove on each side. Clean the entire chain groove. Start the engine with these parts removed--oil should ooze out from the side port in the engine case with the engine running at med speed. If it doesn't, then there is trouble near the pump inside the case. When everything is back together, run the saw at full speed with the bar tip near a piece of cardboard--it should throw off a thin line of oil onto the cardboard after a few moments of running. Hope this helps!
May 26, 2010 | Husqvarna Chain Saw 20" Bar
Lubrication
The cap on top with the bulb, screws off. Use bar oil. Give the bulb a pump every 30 seconds of operation or so. This will keep your chain and bar lubricated.
Regards, --WoobieDog--
Jul 10, 2009 | Remington Electric Pole Saw
New gearbox oil
oil filler underneath passenger seat lift back carpet twist knob and remove plate youll also on some models under the bonnet have a oil reserve bottle which should be full or at least 3 quarters full -estima emina 2.2 diesel
Mar 31, 2009 | Toyota Previa Cars & Trucks
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
