Question about Baumatic Washing Machines
I have a baumatic BWD1212 integrated washer dryer, our electric was flickering on Friday due to the heavy snow and the machine stopped mid cycle with clothes and water still in it, now it won't fi
  • 1294 Answers
SOURCE: washing machine stops mid-cycle and full of water
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
  • 1294 Answers
SOURCE: hoover six express wdm130 1300 washer dryer
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 26, 2008
jsrock516
  • 5911 Answers
SOURCE: my whirlpool washer (Ultimate care
If the washer fills, but won't spin or drain, you may have a defective lid switch. This is a very common problem and a very common symptom.
Let me guess: The washer fills, agitates, but when it gets to the spin cycle it just stops. On some models the washer will fill and then shut off. Am I explaining your symptoms correctly?
If so, this what you need to do:
Open and close the washer lid and listen for a distinctive "clicking" noise. The contacts on the switch should close when the lid is shut, allowing the washer timer to run. This is a designed safety feature that prevents the washer from agitating or spinning with the lid open (don't need to lose any fingers). If you don't hear the switch, it may have come loose, or has broken.
Some lid switches are located on the right-hand side of the tub rim. There will be a slot where the lid strike pushes down on the lid switch. Make sure the lid strike (small plastic piece) is still present on the lid. This can prevent the washer from working as well and make it seem like a huge problem.
On some models the lid switch is located near the left-hand lid hinge under the washer casing. A small rod on the lid hinge activates the switch contacts.
If you determine the need to replace the switch, follow these steps:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. And, still there are some of the older models that have screws holding the console in place from the back. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in on the side of the tub opening and a ground wire attached to the casing. Remove the connector plug, by pushing in on the release tabs on either side and pushing it down through the opening in the washer casing. The wire harness will be held in place by clips under the washer rim. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Good Luck.
Posted on Feb 27, 2008
  • 73 Answers
SOURCE: My LG Clothes Washer has
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Posted on Apr 29, 2009
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
Error message ERR1 on BWD1212 washer dryer?
Door not closing properly. Hinges may need adjusting. The door switches are very sensitive
May 06, 2014 | Haier washer BWD1212 User Manual
Washer heavy duty cycle issue
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
Sep 26, 2012 | Washing Machines
Hoover six 1100 stops at certain points during the cycle until i turn the dial to skip to next part of cycle?
see this causes and fix it. God bless you
Sep 25, 2012 | Washing Machines
Machine stops half way through program
One looses touch with all the codes available, but normally if washer stops mid cycle its due to a blocked or faulty drain pump. OR incomming water is to slow or defective inlet sensor. Switch off and start from the beginning. See if you can get machine to drain by moving the timer etc. If not, rectify pump problem. Take note where in the cycle the problem arises.
Jul 21, 2010 | Zanussi ZWD1680W Front Load Washer / Dryer
Whirlpool washer periodically will stop mid wash cycle. And won't restart until hours later. Seems to only happen when I need to do lots of laundry what is going on
THIS IS A BALANCE PROBLEM, IF YOU ARE PUTTING A LOT OF CLOTHES IN AT ONE TIME, YOU WILL HAVE TO BALANCE THE CLOTHES WHEN IT STOPS, DONT OVERLOAD IT, AND MAKE SURE YOU ARE EVENING THE CLOTHES OUT IN WASHER ESPECIALLY BLUEJEANS AND HEAVY THINGS, I KNOW MY WIFE DOES THIS HA, TRY THIS AND LET ME KNOW THKS LARRY
Apr 26, 2010 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
LG WM2233H stop worrking in mid cycle, no displya
This has happened to me when the power has gone out. It doesn't display anything and all you can do is restart the cycle.
Jan 17, 2010 | LG WM2487H Front Load Washer
Crosley Electric dryer stopped in mid cycle and will not start
if the machine is completly dead an not doing anything locate your fuse panel ,check your fuses for the dryer ,if you can find wich one is it reset the breakers again you probably popped one of the 2 lines since you need 2 for a 220v.
good luck!
May 26, 2009 | Crosley CDE6000 Electric Dryer
Baumatic MEGA WDSS washing machine
go onto manualtree.com type baumatic megawdss washing machine, if this does not bring anything up scroll down until you see it in the listings. type in the code it asks for (this will be supplied underneath, its just to stop cumputers auto logging) and then download then manual. good luck
Jul 02, 2008 | Baumatic MEGAWDSS Front Load Washer /...
Washing Machines Logo
433 people viewed this question
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
