Question about Retail Supplies
Where can I find cheap display counters? - Retail Supplies
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
Try this website, they have a huge variety of counters and display racks: http://www.displays2go.com/
Posted on Jan 20, 2013
How do i fix unable to initial 4f error
The most common cause of this will be a full waste ink chamber and purge counter.
There are lots of pages and u-tube videos to deal with this or just junk the machine and buy a new one as they are cheap enough
How to Clear the Unable to Print Message from the Brother Printer Display
May 04, 2015 | Brother DCP-J125 Inkjet Multifunction...
Cobra microtallk PR 240-2 radios. One of the radios transmits and receives on a frequency one channel less than the selected/displayed channel. That is, if channel 7 (462.7125 MHz) is displayed, the...
I'm looking at a price range somewhere in the area of 40 - 120 $$ to buy them new. If YOU can fix them without getting a tech involved then go for it but you will need a frequency counter that covers the range and they don't give them away cheap and the repair cost wouldn't be cheap either. I would buy another pair.
Oct 13, 2013 | Cobra Radio Communications
Printer unable to clean
This most likely means that the over flow tank is full. You can order a replacement tank but you have to disassemble the printer pretty far to get to it. You would also need to reset the counter so ..... if you want you can just reset the counter. Doing this without replacing the Ink Absorber will mean that once it is truly full it will leak into the printer itself. Do so at your own risk, but then again these are cheap printers....
Brother Maintenance Mode Commands:
- Quickly press Menu/Set * 2 8 6 4 to enter maintenance mode.
- Display should read maintenance.
- Press one or more of the maintenance mode commands below. After each command display should read re-init for a few moments then redisplay maintenance.
- Press 99 to exit the maintenance mode.
Maintenance mode commands:
01 Full RAM clear (see 91 below for retaining user programming)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
99 Exit maintenance mode"
I would use the 01 and reset everything. Otherwise you can go through the 91 parameter list till you find the counter.
Jim
May 11, 2011 | Brother MFC 420CN All-In-One InkJet...
WHEN I TURN ON THE COPIER RICOH FT 4822 AN E-5 CODE APPEARS
When a service call condition occurs, SC codes are displayed in the copy
counter. The first three digits are displayed in the copy counter. Hold down
the "·" key to display the last two digits.
Example:
When the copier detects the E507 condition, "E-5" is displayed in the copy
counter. Hold down the "·" key, and "07" is displayed in the copy counter.
Jan 28, 2011 | Office Equipment & Supplies
Maintenance error 46 on DCP-115c
It is cheap printer, and if used with after market inks, it provides really cheap alternative to more expencive cousins. I provided this solution several times and still works, error 46 on brother printers/faxes usually indicate full buffer ro absorbtion pad.
Please follow instructions below:
First, try to establish if this really is full absorbent pad, remove power cable from the back, wait 20sec, press menu/set key, insert power mains - in most brother printer/faxes this will display machine error code. if this is code 46, you are on the money, your absorbent pad is full (not necessarily, only counter is showing it as such in most cases).
We will asssume that counter is showing full and therefore reset it again to zero:
1. after machine code is displayed, key in "80",
2. go down with arrow key till you find "purge counter"
3. type "2783" this should set counter to "0"
4. press "stop/exit"
5. press "9" twice
6. remove cartridges from craddle
7. remove power cord
8. insert power cord back
9. switch on printer
10. insert cartridges back
If that do not work, then maybe really you need to replace absorbent sponge... it is done under warranty and if not technician in service centre.
If you want to do it yourself, remove cartridges, remove front cover and on the right hand you will have "offending" sponge/felt . Either clean it (absorbent, lint free tissue is fine to remove excess first, then few drop of water and repeat draining process with tissue several times, at least till "cake" from the top is removed. Be aware that ink may leak and spoil your table underneath, I use several layers of newspaper and on top butchers paper to protect my bench if I do that. Best of course will be to replace the sponge with new one.
After that you still need to reset counter. in another way - follow steps...
Hope this will solve your problem and make your printer happy again :-)
Aug 14, 2010 | Brother DCP 115C All-In-One InkJet Printer
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
CHA display were the counter numbers are
CF Card reading error.  Usually cheap cards, can be bent/tarnished/worn pins inside D70, this part can be replaced.
First read:
http://www.vandyll.net/?p=499
Then read
http://www.stephanmantler.com/wordpress/d70s-camera-repair/en/
Nov 14, 2009 | Nikon D70s Digital Camera
Xbox recently stopped displaying on tv. There is audio but no video. Have tried toggling the HDTV switch. Didn't work. Have tried replacing the component cable and it worked at the store demo counter...
the problem is the hanna chip it controls the graphics and when the board heats up and cools down over and over again(while playing games) the chip losses connection to the board and you lose the graphics it can be repaired but is not cheap. in my opinion get a cheap xbox console from ebay
Nov 09, 2009 | Microsoft Xbox 360 Console
Need to reset display counter/meter on a bizhub 750
If your are speaking of the total counter of the machine, the main counter when you press the "utility/counter" key this can not be reset except in the case of replacing the main board.
Jan 22, 2009 | Office Equipment & Supplies
DVD/CD will not load and ejects
junk it and buy a better player...cheap dvd players fail quickly..
Feb 25, 2008 | Durabrand DVD-1002 DVD Player
Retail Supplies Logo
990 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
