Question about Jenn-Air JCD2295HES Side by Side Refrigerator
Fridgerator no longer cooling
The fridgerator is not longer cooling. It's not completely off but doesn't cool as well as it use to. Do you have service reps in different areas you can recommend? I'm outside of Charlotte in a town called Waxhaw 28173
  • 1 more comment
  • bucsnpats Mar 06, 2009
    Freezer is fine but the refrigerator is not keeping cool. I have adjusted the temperature setting up to the coldest position, but still not cooling the refrigerator.
  • Moppy1998 Mar 12, 2009
    Refrigerator and Freezer both stopped cooling at the same time. 4 years old. Lights are on, everything else works.
  • John Tripp
    John Tripp May 11, 2010
    Sorry no one answered sooner. I am here to help resolve your problem. Let me know . Is fan under fridge. running, compressor , and fan inside freezer compartment. Is area clean below fridg. clean.
take off back panels in freezer. you will find ice built up. i used hair dryer ,mine was a blook of ice.
Posted on Mar 12, 2009
Fridgerator not cold and freezer not freezing
You will need to clean the condensor coil. It is usually under the refrigerator on newer models and in the rear on older models. All you need to do is use a vacuum to clean it. Also try to leave some room behind the refrigerator, do not keep it too close to the wall. It needs to circulate the warm air it extracts.
Jul 15, 2012 | Roper Refrigerators
The fridgerator won't get cool. Freezer works just fine. But the fridgerator stopped working. The model number is LSC27931ST
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | LG Refrigerators
I have a Kenmore top freezer refrig, My freezer works fine. My fridgerator is not cooling. I can hear the fan running. What could be the problem?
heatman101
May 26, 2011 | Kenmore Top Freezer Refrigerator
The temperature of the fridge has risen to 11/12 degrees & wont come down? Freezer works fine! Any answers please
Don't know the make and model of your fridge, but most fridges have only one evap coil located in the freezer. The fridgerator compartment is cooled by a fan to blow air from the coil back into the fridgerator section. Check that the fan is working and the vents in the fridgerator are not blocked. Often the problem might be that the defrost circuit is not functioning causing ice to build up on the evap coil thus block the air flow to the fridge. If you seen any ice build up in freezer or refrigerator that could be the problem. If that is the case, then you need to have the defrost circuit troubleshot, typical failures are the heater itself or the defrost timer if you have an older model. Hope this helps you.
Oct 08, 2010 | Refrigerators
Not Cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
gfad
Jun 13, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
My GE fridgerator will not make ice and will not
Open the door and depress the door/light switch,the evaporator fan motor should run.If it doesn't make sure the thermostat is set cold enough.If it is,you could have a bad defrost timer.they are fairly inexpensive and easy to replace.Every day the compressor and evap,motor shut down for @ 10 min and the heaters are turned on to defrost the evaporator to prevent ice buildup.You could have a compressor problem also but lets hope not.
May 31, 2010 | Refrigerators
Fridgerator not cooling
I've had the same problem and it is the thermister inside the freezer compartment. There is probably a ice build up there too. remove the 2 screws and check, you can fix this yourself and save $100 bucks.
Apr 06, 2009 | Maytag MSD2454G Side by Side Refrigerator
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Mar 24, 2009 | Frigidaire FRS26R4A Side by Side...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
197 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
