Question about Samsung N150 Notebook
Samsung notebook N150 Plus has gone completely dead
Gone completely dead i.e. no lights after prolonged charging
  • Samsung Master
  • 7,627 Answers
Try another AC outlet, try another cord/charger of the EXACT same power spec. Has the AC jack in the computer been damaged by pulling on the cord? Power surge? With a multimeter, verify DC volts at ac cord plug. Is the Laptop usually left plugged it when not in use? Do you shut it down and unplug when not in use?
Posted on Jan 20, 2013
griffinkec
  • 46 Answers
SOURCE: how to reset upside down samsung q210 screen
Press Ctrl , Alt & Up arrow key together...
Posted on Feb 19, 2012
  • 4 Answers
SOURCE: Hi On the samsung n150 plus
pres FN + F1 to F12
your laptop might be turn OFF restart your laptop again and that should do it.
Posted on Sep 11, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Hii i hve purchased a
Hi mustafa ****....
Click start>Control Panel>Appearence and Themes
When the window opens it will give you tabs, pick the one you want to change and click on it
and change what you need to change.
Please take time to rate me thumbs up
Posted on Sep 13, 2011
  • 6771 Answers
SOURCE: samsung n150 plus notebook making crackling noises
I would recommend getting the laptop checked for safety reasons, the sound may be coming from the hard drive, it makes a similiar sound when processing information, for example when windows is starting the sound will be more pronounced, if that is the case it is normal. If the sound comes from the cooling fan it should checked for ware.
Posted on Mar 14, 2012
Testimonial: "I've cleaned the air vents although didn't look clogged up however computer is so quiet now - am hoping that was the problem and not my hard drive as it is just out of warranty. Many thanks for your help"
Geekman
  • 32281 Answers
SOURCE: Why my samsung laptop n150 plus is only charging 80% still i put on charge after 80%?it only show green light after 80% which means that laptop not going to charge after 80%...WHY?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Posted on Dec 04, 2012
Samsung n150 plus press f1 to continue
go into bios and disable everything related to stop of failure this will prevent stopping for any f keys
Jun 22, 2014 | Samsung N110-12P Notebook
Powerswitch to Samsung n150 gone how do I turn it on to get into bios
the switch should have 2 wires. you will have to bridge 2 wirs untill it turns on but remember to disconect the 2 wires ones the laptop turns on
Oct 02, 2013 | Samsung N150 (36725723009) Netbook
Hi On the samsung n150 plus notebook when i pres the k key the number 2 comes up. K will only come up if I press the fn key
pres FN + F1 to F12
Sep 11, 2011 | Samsung N150 Notebook
When i pull out the power cord on my N150 plus the comp crashes,even though the battery is saying 100 per cent..any idea?
A lot of times this happens when the battery has gone bad and needs to be replaced. It might say 100%, but due to use (and sometimes just due to a faulty battery) the battery will charge less and less and eventually won't hold a charge at all. For example, when I first got my laptop a year and a half ago, I could get almost six hours out of a charge. Now I get almost twenty minutes. Unfortunately, I would say you need a battery. You can get one either from samsung (though you may have to call them, I couldn't find your battery on the site), Newegg.com, or ebay.com.
Some good tips for handling your new battery. First, if the computer's plugged in, remove the battery. Put it back in before you unplug it. This will prevent long-term wear on your battery. Secondly, it's good to regularly (I'd say yearly or so) let your computer "die" on battery (run it until the battery dies), then charge it completely THREE TIMES. This will "cycle" your battery. They say that with the newer batteries used nowadays this isn't an issue, because the new type of battery doesn't create the crystals like the older type does, but it can't hurt anything and I've noticed a difference when I do it.
I'm sorry about the bad news, but hopefully this will help!
Aug 22, 2011 | Samsung N150 (36725723009) Netbook
Samsung n150 plus is expandable to how many memory?
The Samsung N150 Laptop comes installed with 1GB of Memory and can be upgraded to a maximum of 2GB Memory. This computer has 1 (one) SO-DIMM memory slot, so to upgrade to 2GB of RAM, you will need to replace the installed RAM module with a single 2GB PC2-5300 DDR2-667 200pin SDRAM SO-DIMM memory module.
If you find this solution helpful, please leave a positive rating!
Jun 21, 2011 | Samsung N150 Notebook
My samsung n150 plus is although plugged in, the battery information describes that "plugged in but not charging"
my samsung n150,although plugeed in charging port displaying not charging..what is the solution for this problem..reply on vvvswathi@gmail.com
Apr 19, 2011 | Samsung N150 Notebook
My acer notebook wont charge all the way it stops at 87% and it wont charge anymore.
hello
The battery is starting to be dead. one or couple of battery cells gone dead, need replacement. if the battery is giving enough backup time then no need to replace it immediately. let the battery gone dead, sooner or latter, then you can replace or repair it,
good luck
Dec 14, 2010 | Computers & Internet
Samsung N150 Notebook Logo
245 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
