Question about Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher
Door Leak:Electrolux #EDW5500DSS
After using the dishwasher for 1 yr the door started to leak.
The unit is level, and the seal looks good, but has a gap at the bottom from the manufacture.
I have run out of ideas on how to fix this issue.
Bob
  • robert_shepp Jan 26, 2009
    I have checked under the machine and the leak is definatly coming from where the door meets the body. Today it was leaking a lot and by pushing on the door the leak would slow down and stop.
    The leak today was large, where somedays it is only a small leak.
    The door seems to fit tight, but the extra push stopped the leak.
    Hope this helps to clarify the problem.
    Bob
  • Garth Jackson May 11, 2010
    Bob
    Are you sure the water is comeing from the door and not from under the machine near the front just make double sure first let me know and we can try to fix this.
    Scholar:
  • 93 Answers
The leak from the door sounds like the door may have moved could be from the door going down a bit hard (yes we all do it sometimes)to acidently leaning on it etc whatever the cuase this can happen you will need to remove the side panels for this and see where the door hinges mount on the machine there is normally an adjustment there where you can loosen a screw or two and push the dorr for a closer gap when closed(it is also possible that these were loose from the factory)if you machine has no screws to adjust with there will be springs normally on both sides wich can be adjusted with a rod and nut system or by moveing the sping to a new location on the mounting plate(the different positions are marked out.Hope this helps you please let me know if you require any further assistance.Garth
Posted on Jan 26, 2009
  • Phil Gar Mar 07, 2011
    I also have had problems with mine. I originally bought a floor model and it was only $500 so I thought - lets give it a try. I installed it myself and it is very quiet, but average at cleaning dishes. It also developed the error 1 code - I took it out and flipped it over and took off the pan and tightened the hoses. The problem went away for a while ( 6 months) , then returned. I took it back out and thought I could find the leak. (this was yesterday). It was also leaking a little on the floor toward the end of the cycle. I put it up on some 4 x 6's and took off the pan and ran it on a normal wash. After about 10 min it started dripping into the "pan area" . What I found however was that it was not from the motor, but was coming from the front door seal/pan. I took apart the front door ( remove the screws from the inside (but leave the top philips screws!) and ran it again. What I found was that at the corners of the door, water was running outside the seal, slowly filling up the front little lip, and then leaking out. There is a gray plastic shield below the lip held by 2 screws ( I think for sound insulation) which would then catch the water and channel it back inside the machine that would cause the error 1 code!. What I did at this point was open the door and lift part of the gasket from the bottom ( it was a little loose) and realized that it was allowing water to dribble out past the gasket, catch on the lip, overflow over the lip, and cause the problem. I then pulled out ~ 4 inches of the gasket, and put silicone in the channel, and reapplied the gasket. Also, I lifted the corner rubber gasket ( bottom corner where the hinge meets) away from the wall and then applied silicone. I waited overnight and reran the dishwasher this morning watching for the leak and- NO LEAKS! I also put a large swath of silicone on the gray plastic below the lip so water can't go into the pan and set off the alarm, and I also put a door vinyl weather stripping glued to the lip to add a little height in case it starts to leak again. Well - all is well now ? for how long? But I could at least see the problem (their design problem) It took me a few hours, but so far so good. If any major thing happens to this dishwasher again however, I will trash it and get a bosch or kitchenaid/kenmore elite. hope this helps
  • Brent Lawrence Jan 13, 2013
    Thanks for your great post. Our Electrolux diswasher has also been leaking. I also investigated and found the leak to be from the front door. The leak caused our laminate flooring to buckle up and it is now ruined. This post is 1/14/2013. your post is from 2010. Did your solution hold up after three years?
How do i find the leak sensor on my electrolux dishwasher?
Good Afternoon Friend,
I understand you want to know where the leak sensor is on your Electrolux dishwasher, model# EDW5500DSS. Typically the leak sensor will be located underneath the tub area. There are no diagrams that show exactly where the sensor is located. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and will be able to best assist. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Electrolux 24 in. EDW5500DSS Stainless...
Electrolux dishwasher leak detector light
This was a good answer. It reset the error. But once we started the washer up again it threw the same error. Next step, remove it from the cabinet and check for leaks.
Apr 10, 2014 | Electrolux 24 in. EDW5500DSS Stainless...
How to find leak in electrolux dw6105gs1a dishwasher
Check the door seals for any leak, and then the internal tub and underneath the unit by taking off the toe grille, or kick plate. If you cannot visually see any leaks, contact a professional service company - you might have a faulty sensor or a further control issue.
Dec 28, 2012 | Electrolux Frigidaire Professional Series...
Error 1 code now says dry function
If your unit is displaying the ER01, E01, or 01 codes in the display panel you are experiencing a leak concern. The unit has detected a leak somewhere within the unit. This could be within the door seal, the tub basin itself, or in the drain lines/pump. Only a professional can diagnose further for complete repairs.
Dec 25, 2012 | Electrolux Frigidaire Professional Series...
The Door leaks at the bottom seal, new seal is fitted, can the door be adjusted
The seal at the bottom of the door is PASSIVE (not actually sealed). If you are leaking there, look for correct type and quantity of soap, and be sure the machine is LEVEL.
Jul 01, 2011 | Electrolux Dishwashers
Model # FDB1100RHB2 Dishwasher The dishwasher, since the installation just one month ago, has leaked continually (requiring a drip pan be placed beneath the door) from the lower left hand corner of the...
The door bottom is actually NOT sealed. Look into the levelness of the unit, and that you are using the correct soap. Both can cause water to leak by the door.
Look closely at the door alignment and make sure is did not get damaged along the way..
Nov 08, 2010 | Frigidaire Dishwashers
EWDW6505GS0 Model Electrolux dishwasher 10 months in service has Error Code 01. Leak. What to do?
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Feb 14, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Jan 25, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Dishwasher has started leaking on the right hand side of the machine. Only thing around that region is the salt dispenser
You want to take off the kick panel and look for the location of the leak If it's from the door- You want to adjust the units feet to make sure the unit is level and square. if you can adjust the door latch tighter try that. replace the door seals if needed.
Mar 24, 2009 | Dishwashers
Dishwasher Door Tension Adjust on Electrolux EDW5500DSS
I just adjusted my Electrolux DW springs. The springs are on the bottom sides near the back. They pull on cables that hold the door (via pulleys). The springs can be moved to five different holes to change the tension, but I needed to pull the DW about 2/3 out for side access.
Oct 26, 2008 | Dishwashers
Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher Logo
1,980 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
