Question about Dyson DC35 Handheld Vacuum
Lost the cap that locks the brush in place on my dc35. Can't use it until I can get another one or find out where to purchase a new head.
Need help ASAP. Thanks
  • virginia mullen Jan 22, 2013
    Found the cap I needed and ordered 3 but after ordering them I found the other one.
  • Dyson Master
  • 18,402 Answers
Kenmore help
There are 2 plastic screws that pivot 90 degrees on the top of the front nozzle. Turn them and lift off the hood. You will see the brush roll and belt. Remove the brush roll and clean off any debris or hair, also from metal caps at the ends of the roller. Be careful not to loose the 2 washers under the end caps. Place the new belt on the motor shaft that sticks out of the main body, then place the brush roll pulley against the belt and pull forward and lock the roller in position. Spin the roller by hand to make sure that the belt is aligned properly. Place the hood back on the front nozzle and turn the plastic screws to tighten. Have fun cleaning.
Nov 05, 2013 | Vacuums
Replacing belt on brushroll on a Hoover SH40060 canister
Your manual is pretty lacking. Most all brushes have holder guides on both ends, normally the entire brush and guides will lift straight out of the head if the belt is broke, there could be a locking clip, make sure the area is clean so you can see it, but the brush head has to come out somehow or a new belt can't go on, some have the top of the head comes off, the cover, this way you place the belt on the brush, set the brush back in the head, then you set the belt onto the motor shaft from the top.
What ever you do, make sure you watch how the brush comes out and the guides, if you need to take a marker and put a mark on the guides so you know what the top was and how they go back in.
Apr 03, 2013 | Hoover Platinum Cyclonic Bagless Canister...
How do you replace the belt on a G4 Kirby Vacuum?
Remove the head from the machine, and unlatch and remove the bottom plate. The brushroll can now be pulled or pryed out. Slide the new belt onto the brushroll and center it. When re-installing the brush, note that one end cap is wider than the other. The brush caps are also marked with 1, 2, or 3 notches to adjust for wear. In normal use, setting 1 should face the carpet. Be SURE both ends are on the same setting. Replace the metal rug plate and turn the belt lifter counterclockwise to stretch the belt into a loop. Place the head back on the machine, latch it firmly in place, and turn the belt lifter clckwise to drop the belt onto the motor shaft.
Jan 28, 2011 | Kirby G4 Bagged Upright Vacuum
Purchased ProHeat 7920 Po-Tech recon. Unable to use main brush as no water/cleanfluid. Belt drive is ok. Grateful advise location of fluid jets as not visable behind main brush. Turbo brush works well.
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
Nov 16, 2010 | Vacuums
I have a problem with my model 6585-3 bissell upright powerforce bagless turbo with turbo brush vacuum The brush has quit spinning upon removal i noticed that one side of the brush was free to spin the...
Hair and dust build up under the end caps of the brush roll and cause friction. Replace the brush roll and belt. Be sure to clean the brush roll frequently after use.
Jun 24, 2017 | Vacuums
Install New Belt
Lift the headlight and rotate the thumb dial to release the carpet head. It will spin to the side. Rotate the square handle at the front of the vac fully to the left.
Remove the carpet head and open it from the bottom side. Observe which side had a little block below the LED belt indicator when you rotate the brush. The brush must go back in this way. The blocks at the end of the brush are color coded for height adjustment. Remove the brush, slide a genuine belt onto the center and close the bottom cover of the housing. make sure the brush spins freely, now look into the belt opening, round hole at the side. Using the square dial at the front of the head, rotate the hook into the belt to twist the belt and open it for installation onto the motor shaft.
Reinstall the head onto the vac, using the thumb dial to lock into place and rotate the square handle again . This will release the belt tension onto the motor shaft. Raise the vac up two knotches with the pedal before lower onto the carpet.
Sep 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Mar 11, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Part numbers for washers and end caps of vacuum agitator brush
The part numbers for the washers and caps can only be found if you know the agitator brush number.
Mar 28, 2008 | Panasonic MC-V5745 Bagged Upright Vacuum
Replacing Belt
On the front of the power head is a knob with the KIRBY name on it. Rotate this knob in a counter clockwise direction and it will "lift" the belt off the motor spindle. Release the head lever, only one direction it will turn and remove the head. Turn the head over on its back, turn the KIRBY knob to release the old belt. Remove the brush guard by turning the two release fixtures. Remove the guard. Pry the brush out of the head. Remove the old belt. While the brush is out remove any build up of hair and lint off the ends that's where the bearings are. put a few drops of 3 in One oil on the ends. Put the new belt over the brush and re-install the brush into the head. the brush will go in only one way. With your finger pull the belt into the housing and rotate the KIRBY knob until the pawl inside grabs the belt. Re-install the brush guard by engaging the two metal pieces into the front of the head and pull down backwards over the head and rotate the holding clips back horizontal. re-install the powerhead on the machine, lock it in place and rotate the KIRBY knob clockwise. You should be all set!
Aug 23, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Dyson DC35 Handheld Vacuum Logo
91 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
