Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Plantronics Explorer 220 no longer connects to Blackberry Curve
The bluetooth is already paried with the phone. The phone shows that the device is connected when it is not. Everytime I make a call it comes throught the handset not the earpeice. When I select bluetooth devices on the phone and select the plantronics, it asks me if I want to disconnect. I have deleted the device from the phone and paired it again and the same thing still happens. It use to pair very easy, I would put the bluetooth on hit the button and my phone would ask me if I want to connect to the plantronics and that was it. I let the bluetooth die just so my phone wouldn't say it was connected and recharged and started over, that didn't work either. Please help.
  • 903 Answers
You can have the two devices connected, but still get your sound through the phone. During a call (maybe call your voicemail or an automated number, just to make a call) try holding down the answer/end button on the earpiece until it beeps, and see if the sound switches from the phone to the earpiece. You can also try pressing the speakerphone button on your phone during a call to switch the call to the earpiece.
Did either of those ideas work?
Posted on Oct 14, 2010
2 Suggested Answers
  • 25 Answers
SOURCE: need passcode for my plantronics 220 earpeice
if 0000 dosnt work try 1234
Posted on Jan 25, 2009
I am trying to pair my 220 with my blackberry 9600. This is my 3rd BB. It won't let me pair this phone. Do I have to clear the other pairings? I no longer have these phones. Is there something else I need...
Shut your Explorer 220 off. Shut your phone off and take the battery out for about 30 seconds. Put the battery back in and turn your phone and headset back on and try re-pairing them. This should take care of the problem for you.
Here is a link to the Plantronics Explorer User's Guide.
Good luck from Headsets Direct!
Apr 19, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Tip
How to pair a Plantronics Explorer 245 Bluetooth headset and a BlackBerry Tour
The Plantronics Explorer 245 headset can be paired with most Bluetooth-capable phones and smartphones to enable hands-free phone conversations. To pair the headset with a BlackBerry Tour, follow the steps below:
Make sure the Plantronics headset is off before trying to pair the two devices. On your BlackBerry, scroll down to Manage Connections (the antenna icon) in your Home folder and click the trackball. From the list of connections, select Set Up Bluetooth. The Add Device box will appear, asking if you want to search or listen for a Bluetooth device.
At this point, turn your Explorer 245 on by sliding the on/off switch toward the microphone end of the earpiece. Once the device powers on (if you have it in your ear, you'll hear a few short tones) you should see repeating red and blue flashes from the LED lights on the side of the headset. If you only see blue flashes, hold down the call button (the side button) for a few seconds, until the lights start flashing red then blue.
Now, on your Tour, select Search. Bluetooth will be enabled if it's not already, and then the BlackBerry will search for nearby devices. When the headset appears on the list of devices found (it should read "245Plantronics" or something similar) select it. A box will appear letting you know that pairing is now complete, and asking if you want to connect to the headset. Select Yes.
Your BlackBerry Tour and Explorer 245 are now paired. If at any point you turn the headset off, turn the BlackBerry off, or turn the BlackBerry's Bluetooth feature off, the two devices will automatically reconnect when they are able. When you look at your list of paired devices on the BlackBerry, the Explorer headset will appear in bold to show that it is currently connected.
on Oct 26, 2010 | RIM BlackBerry? Tour 9630 Smartphone
My 220 plantronics bluetooth keeps shutting off on me during calls sometimes it will stay on for 30 sec. or so if im lucky.even when its just connected on stand by it turns off. i have a Blackberry curve...
You have an older headset and it sounds like the battery isn't holding a charge. Try pairing a different headset to your phone and see if the problem goes away. If it does, you know it's the battery. If the problem continues, then you will know the problem is with your phone and it's Bluetooth connection.
Good Luck from Headset Direct!
Apr 13, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Can you play music through a plantronics 220 from a Blackberry 9700?
Yes! I have the same phone and headset :) When your in the song (and your bluetooth is connected, press the BlackBerry button, and select, "enable headset".
Jul 15, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Need numeric code to pair with blackberry pearl 8100
when pressing the call button to turn on hold it a little longer then usual after the headset has turn on, it will flah red and blue, then simply do a bluetooth scan with your phone, it will detect the headset.
May 30, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics explorer 233 bluetooth and blackberry 8100
On your main screen scroll down to the bluetooth icon.
click it
add device will appear
click "search for devices from here"
then get your bluetooth
hold the side button until it flashes red and blue. then release
it will find your bluetooth
scroll up and highlight it.
the passkey is "0000" when it ask for it
then click again
let the 2 pair
you should be golden
Mar 12, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
289 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
