Question about John Deere Garden
Charging problem with a john deere sst16
Charging system does not work.
  • 142 Answers
SOURCE: John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Posted on Sep 20, 2008
  • 138 Answers
SOURCE: The charging system on the mower will not charge the battery up
The first thing to check on this machine is your voltage regulator try bypassing the voltage regulator to see if the alternator starts charging, it would be better to check your charging system with a voltmeter so that you know what the exact input and output in the electrical system.
Posted on Sep 23, 2009
MNfisherman
  • 11896 Answers
SOURCE: I have a 1985 year model 116 John Deere mower. My
It should have continuity. This provides main power to coil and spark. This will also in return lead to your cdi and charge your system as well.
Posted on Sep 24, 2009
Testimonial: "Thank you, you have answered my question."
  • 100 Answers
SOURCE: i Have a john deere
need to find small wire to positive side of battery or solenoid...disconnect it and use multimeter to check if getting charge
Posted on Aug 14, 2010
  • 6 Answers
SOURCE: I have a John Deere
sounds like there is an obstuction, maybe from the deck, or deck hanger interfering with steering components
Posted on May 07, 2011
Charging system troubleshooting
To begin in wall/ext outlet... use Voltmeter tester set it in AC volt if u don't have tester use other appliances plug in to check if its working. Next smell charger if there is a burn component inside there is strong smell "don't use it anymore" . 3rd Plug your charger and check if the unit is charging ...all unit/equipments that use charging system has a icon showing its charging those w/out screen usually red LED is ON if charging system is working. This are the simplest way troubleshooting charging system, I hope it will help
May 17, 2018 | Cars & Trucks
Charging system light in on, what to look for
Charging light is usually alternator is inop or worn, check/replace alternator if not working properly.
Charging systems can be checked at O'reilys or Autozone for free.
Nov 12, 2015 | Jeep 2012 Grand Cherokee Laredo 4WD
Charging system not working
Most parts stores will test for free.
Oct 08, 2015 | Cars & Trucks
2012 Grand Caravan. How do I turn the battery light off after installing a new battery?
Test the alternator. The battery light is for the charging system. Once the charging system is working with the engine running, the light should go off. If your light stays on with engine running, the alternator may need service or replacement.
To test the charging system, just put a voltmeter on the battery with engine running. The voltmeter should register at least 13.5 volts- alternator is charging. If you only show battery voltage with engine running, like 12.2-12.8 volts, the alternator or charging system is not working. The battery light should be on to signify this.
Jun 17, 2015 | 2012 Dodge Grand Caravan
Chrysler battery charge light on
check the charging system and battery to make sure these are working properly. if the charging system is not working then the alternator will have to be check and possibly the PCM as the PCM controls charging voltage and the alternator continuously tries to run a max. check for a code in the PCM related to charging. this may help finding the problem.
Aug 25, 2014 | 2006 Chrysler 300 Touring
Why does system battery not charge ? new battery and new charging kit show no improvement on laptop. well charged battery works but not recharging.what is wrong ?
well this is a hardware problem.in this case your charging stage is not work.i am showing you a picture in the yellow marking fat 's are shorted if you can change these components the issue will be solved.sorry for bad english.
Jun 18, 2014 | Dell Inspiron Mini 10 N450
Light check charging system comes onm
It is telling you what to do
Check the charging system
It isn't working as it should
Mar 10, 2013 | 2000 Lincoln LS
My 1999 cougar alternator stopped charging also no speedometer or techometer or cluster lights even after installing a knew alternator still not charging ,car will run until battery goes dead than...
If you get no red light for the battery charging system the charging system will not work. The indicator light initally excites the field to start charging.
Feb 28, 2010 | 1997 Mercury Cougar XR7
Aprilia atlantic 500, blown fuse, charging system
has any work been carried out recently?, maybe a wire is touch the metal frame. the charging system could be over charging, have the voltage regulator & charging system checked so many possiblities ..
Oct 14, 2009 | 2002 Aprilia Atlantic 500
My charging system isnt charging on my Kawasaki
have you tried testing the regulator rectifier i am sure this has an effect on the charging circuit also is it definetly the charging circuit not working or could the battery be not holding the charge thats put to it.
Apr 21, 2009 | 1998 kawasaki KDX 200
Garden Logo
221 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
