Question about Panasonic PV-DV400 Mini DV Digital Camcorder
Windows 7 updates.connect
Can't download and install printer driver HP Deskjet 1220C for window 7
There is no downloadable driver for this printer. You just need to update the Windows 7 list on your computer with the latest update. Here are the instructions from hp:
The drivers for your HP product are already included in the new Windows 7 operating system! You do not need to download drivers to use the product . Simply connect the printer to your computer with a USB cable, and Windows Update automatically installs the driver for your product. With the in-OS The driver located in the Windows 7 operating systemdriver, some of the buttons on the product do not function and some of the advanced product features are not available. For more information about your in-OS driver, and to see workarounds for lost functionality, go to our Frequently Asked Questions below. Install the Windows 7 in-Operating System (in-OS) print driver When you connect your printer to the computer, Windows 7 detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD. Step one: Install the in-OS driver Follow these steps to install the in-OS driver in Windows 7. NOTE: The computer must be connected to the Internet for Windows Update to detect and install your product.
  1. Turn the product on.
  2. Connect the USB cable to the printer, and then to the computer. Figure 1: USB cablec01704933.gif NOTE: When you connect the USB cable to the printer, and then to the computer, Windows 7 activates Windows Update. Windows Update searches online for the most recent product driver on the Windows Update site. If the online driver is more recent than the driver stored in Windows 7, the computer downloads and installs the updated driver.The Windows Update process takes place automatically. Therefore, you might not notice that the process is in progress.
  3. Windows 7 detects the hardware and automatically installs the correct driver. A notification displays on your computer to let you know when installation is complete.
Your basic Windows 7 driver is now installed. Some functions might not be available, but you can use workaround procedures instead. See our Frequently Asked Questions section below. Step two: Print a document Print from any software program to make sure your printer is working correctly.
  1. Open a document in the software application in which it was created.
  2. Click File , and then click Print .
Jul 26, 2011 | HP DeskJet 1220c InkJet Printer
My mouse Labtec Wireless Laser Mouse for Notebooks doesn't work on windows 7, Thanks
If your internet connection is working in Windows 7, I suggest you try obtaining the drivers through Windows Update. Click Start > All Programs > Windows Update > Turn on Windows Update. A list of available updates will then be downloaded, you will have the option to view them, do so and check off the appropriate drivers or software patches you need and click Install. You can also check the manufacturer's website for patches, updated drivers or to simply find out about Windows 7 support for the particular product.
Apr 17, 2011 | Computers & Internet
I NEED WINDOWS 7 COMPATABILITY DRIVER SOFTWRAE FOR MY PC
Connect printer to computer, turn on and then go to windows update. Search for updated drivers and you will find it. You need to do this while runnind add printer wizard
Rob
Please rate. thx
Mar 02, 2011 | Konica Minolta PagePro 1350W Laser Printer
I want update windose 7
To update your windows 7 Go to start>Type update in search box>Select Windows update> select Check for update
Check whether you are connected to internet or not
Thank You
Don't Forget To Rate
Jan 24, 2011 | Microsoft Windows 7 Home Premium 64BIT...
My hp deskjet 810C printer does not function with windows 7
If you mean Windows 7 Drivers issue with this printer, simply connect the printer and update the Windows, it'll automatically install the printer. This model supports windows 7, but there is no driver available to download, the only way to get it worked on windows 7 platform is Windows Update.. You can follow the instructions on how to update windows:
  • Click Start, and then click Control Panel.
  • Depending on which Control Panel view you use, Classic or Category, do one of the following:
  • Click System, and then click the Automatic Updates tab.
  • Click Performance and Maintenance, click System, and then click the Automatic Updates tab.
  • Click the option that you want. Make sure Automatic Updates is not turned off.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Oct 13, 2010 | Computers & Internet
I have an HP PSC 2210 all-in-one ink jet printer. I need print driver software so that this printer can be operated on a new Windows 7 64-bit desktop machine.
The drivers for your HP product are already included in the new Windows 7 operating system.
Use the following instructions to install the basic driver in Windows 7, and then review the workaround procedures to use the available features for your product.
ollow these steps to install the basic driver in Windows 7.
  • Turn the product on.
  • Connect the Universal Serial Bus (USB) cable to the printer, and then to the computer. Figure 1: USB cablec01704933.gif
    NOTE: When you connect the USB cable to the product, and then to the computer, Windows 7 activates Windows Update. Windows Update searches online for the most recent product driver on the Windows Update site. If the online driver is more recent than the driver stored in Windows 7, the computer downloads and installs the updated driver.The Windows Update process takes place automatically. Therefore, you might not notice that the process is in progress.
    A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, click Close (c01884617.gif ), to close the window.
    The basic driver in Windows 7 is enough for printing from a software program, scanning documents, and importing and viewing images on a memory card. Also, using your All-in-One product, you can fax a printed page.
    NOTE: not all features will be available if you use the basic Windows 7 drivers
    hope this help
    Sep 06, 2010 | HP PSC 2210 All-In-One InkJet Printer
    My computer runs windows 7, will the PSC 1210 printer be compatibke
    Hello and Welcome to FixYa!
    Yes the Printer is compatible with Windows 7 both 32bit and 64bit, you can install the printer on Windows 7 without any eternal driver source, the drivers for this product model are already included in the Operating System, all you have to do is;
    • A Your devices are ready to use window might display on the screen.
    Note: When you connect the USB cable to the product, and then to the computer, Windows 7 activates Windows Update. Windows Update searches online for the most recent product driver on the Windows Update site. If the online driver is more recent than the driver stored in Windows 7, the computer downloads and installs the updated driver.The Windows Update process takes place automatically. Therefore, you might not notice that the process is in progress.
    If you got any Questions/queries, do ask us, we are here to help.
    If you think I was of help, your token of appreciation in the form of rating will be esteemed.
    Concerned, Nooh
    Aug 06, 2010 | HP PSC 1210 All-In-One InkJet Printer
    Windows 7 cannot detect my D90. Error: MTP USB
    Try also to do windows update while the camera is turned ON and is connected to the computer. Windows update automatically searches for updated drivers on Microsoft's database.
    Apr 24, 2010 | Nikon D90 Digital Camera with 18-105mm...
    Windows 7 hangs on saving new connection. Closes when click save
    Hello and thank you for using Fixya's services.
    Please make sure all of your updates are installed as there are 57 total updated already available for Windows 7. This si a common issues with wireless and should be fixed after updating.
    Connect directly to router (hardwire) and you can connect and download updated.
    Please let me know if you have any questions.
    Nov 19, 2009 | Computers & Internet
    Panasonic PV-DV400 Mini DV Digital Camcorder Logo
    21 people viewed this question
    Top Panasonic Video Cameras Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    zimcloud
    Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
