Question about Fujitsu LifeBook AH530 Pentium Dual-Core P6000 1.86GHz 4GB 320GB DVD?RW 15.6 LED Win7 Home w/Webca... (FPCR33731) PC Notebook
How to remove virus recycler
Want to know how it is
  • 1,824 Answers
You can remove any program in Control Panel - Uninstall a program.
If the program is not in the list, try using:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
Posted on Jan 20, 2013
Dear Sir, There is one problem to my Compaq Laptop it is that when i click on any of the icons then it show the option i.e( Are you sure you want to remove the folder and move all the contents...
i can only offer you to use latest version of "ESET NOD32 Anti Virus".
because i know only this anti virus which can delete this virus.
you can download it from here:
http://www.scanwith.com/download/NOD32.htm
Jan 11, 2011 | Compaq Presario 700 470024-192 Notebook
How to remove autorun.inf, system volume information, recycler etc virus from the harddisk.
1st: Go to Tools>Folder Options>View>unckeck this items below:
1>display the contets of system folders
2>hide extensions for known file types
3>hide protected operating system files(Recomended)
2nd:check all other options in VIEW
3rd:APPLY>OK.
4th:Download unlocker 1.87 ,install it after that enter any drive (C:,D:,........) and delete the recycler folder >then a error message will appar and shows that " can not delete RECYCLER:access is denied." it's in use.>click "OK">after that the "unlocker 1.87" will appears automatically and will give options "noaction","delete","rename","move" at down-left corner and there you can select " delete" optinon by scrolling down and after that you can success fully delete the virus,RECYCLER,from that drive.:D
continue this proccess for all drives where you can see RYCLER folder
NOTE ADDED: This site is listed by McAfee Site Advisor as a potential source of adware and malware.
another answer::::::::::::::::::::::::
Use a batch file (Example.bat) to change it from to a non hidden and a non read only file. It will convert it to a deletable folder and delete it. Do not delete the Autorun file because I found that the virus changed one of my documents to the autorun.
@Echo off
ATTRIB -S -A -H -R
Pause
Then if no errors come up after running the batch right click on RECYCLER folder and click delete.
Make sure the Batch is in the drive not the subdirectry.
(Example) - DriveLeter>Example.bat
Hope this helps : )
Please note that the following advice if taken will absolve me from any responsibility. I am only reporting what I did to get rid of the virus installed on my hard drive.
1. You should be able to see your root drive root drive which is c: or d: etc.
2. Ensure that you are able to see hidden files by going to Tool>Folder Option>view and checking off hidden files.
3. System Volume Information and Recycler should be visible in your root drive (c: d: or whatever drive you use)
4. Right Click on Recycler folder and go to Properties.
5. Go to the tab labeled Security, If your user name is not there then add your username that you use for XP . Give yourself all security rights as well as the SYSTEM user. Then press okay. If you cannot see the security tab and you are using XP professional then go to Tool>Folder Option>View uncheck box "Use simple File sharing" then select Apply.
6. Right Click on System volume information folder and go to Properties. Repeat step 5.
7. Go to the garbage icon on the desktop and right click. Choose properties then check the box " Do not move files to the recycle bin. Remove files immediately when deleted." Press Apply.
8. Go back to the root drive and delete Recycler folder.
9. Go to the System Information folder and delete the last folder. These folders are where Xp has taken a snapshot of your system in order to restore it. The virus is hiding here in the event that you restore it is also restored.
10. You should now open the registry editor and remove the virus from here so that when you restart the virus is not recreated.
11. Open the registry editor. Start >Run> then type regedit in the box and select OK The registry will now open.
12. Hit Ctrl+F Type Recycler in the search box . Delete the entry when found. press F3 to find the next occurrance of Recycler and delete.
13. Close regedit.
14. Go to all installed harddrives and so steps 2- steps 6, steps 8 and steps 9.
15. Run your virus software. You should be able to update any virus software that was previously unupdatable.
16. Reboot your computer
17. Verify that that the reycler folder is deleted from you root drive.
18. Then you can uncheck the box in the garbage that you checked in step 7. To keep all you deleted files in case you need to restore a file that was accidentally deleted.
My findings: This virus is recreated using the methods of the garbage bin. Everytime you delete a file it recreates itself because it looks in the garbage and restores or copies the virus information inside. If the virus is not able to be stored inside and is immediately removed when you check the box in step 7. Then it cannot recreate itself and all of its power is lost. So erasing it from the registry and drive ensures that it cannot return.
I frequently get this headache and finally heartache sooo annoying it had brought too much trouble for me. After installing various kinds of software, running them and so on, I found some of them useful and some of them not at all effective.
Even if we make changes in folder options to view all the files and change various settings, searching through regedit etc or following by some software, in most conditions a typical average user lands in confusion and finally some disaster happens to his system.
I found this simple system to effectively remove Recycler virus - Blam to Recycler virus.
1. Go to Desktop, right click on Recycle bin and select properties.
2. Check (select or put a tick mark) on the square box (Do not move files to the recycle bin. Remove files immediately when deleted)
3. Get File zilla FTP which is free and install. (you dont need to change any file settings)
4. without entering any sort of web address anywhere click the directories in the Local site box.
5. Then each directory will display all the folders below this box with file name, file size, file type and last modified.
6. Now check if RECYCLER folder is there. Then simply delete it.
7. Your job is done.
8. Repeat in all the folders by searching if it is sub folders too.
9. Repeat for each directory ( C D E F ...)
After your job is done again go to desktop, right click on recycle bin and then deselect on the square box.
Apr 21, 2010 | HP Computers & Internet
HOW TO DELETE RECYCLER VIRUS
Installed a strong antivirus on your PC the scan the whole computer with the antivirus the locate where the recycler is and use shift+delete to remove it. Run the antivirus will have weaken the recycler
Jan 15, 2010 | Computers & Internet
Is recycler a virus.
Yes it is a virus
3rd:APPLY>OK.
4th:Download unlocker 1.87 ,install it after that enter any drive (C:\,D:\,........) and delete the recycler folder >then a error message will appar and shows that " can not delete RECYCLER:access is denied." it's in use.>click "OK">after that the "unlocker 1.87" will appears automatically and will give options "noaction","delete","rename","move" at down-left corner and there you can select " delete" optinon by scrolling down and after that you can success fully delete the virus,RECYCLER,from that drive.:D
Jan 14, 2010 | Computers & Internet
How to remove recycle virus?
Access: http://cainternetsecurity.net/entscanner/
and do a scan of your computer, and then click "remove" when the scan is done.
Jul 17, 2009 | Computers & Internet
I have a recycle virus suggest me removal tool pls
Dear user,
pl search in google for autorun eater2.3
and download it it will remove autorun.inf virus successfully
Regards,
Ravindra Shah
Jun 06, 2009 | Computers & Internet
Cannot open C: drive by double click
you have a virus. i encountered the same problem on a HP Pavillion desktop, its a trojan type virus that hides in your recycler folder, you need to run Avira Anti Virus, its the only one ive found that can get rid of it, you can get it free at downloads.com. or you can reformat your harddrive and do a clean re install of windows but then you lose everything on your pc. try running avira, if that doesnt work you may want to consider reformatting. the recycler folder is supposed to be in windows but the virus hides itself in the folder, im not exactly sure what it does but i know it will restrict your access to the c drive until you remove it, you cant just delete it either, it will show back up in like 2 minutes, also be careful with flash drives, removable usb storage, it will put itself on those drives also and infect other computers that you plug them in to unless you remove it from the flash drive then disconnrct the flash drive but be quick so it doesnt re appear on the flash.
May 11, 2009 | ASUS Computers & Internet
I can not remove viruses from my hard drive ...
"System Volume Information" is not a virus; it is a folder where your system restore points go.
"Thumbs.db" is not a virus but a program windows uses to create thumbnail images.
"Recycler" is not a virus but the location of the recycle bin.
The reason these items are "ghosted" are because they are hidden files; removing these files/folders can have adverse affects on your computer and if you did succeed in removing them, windows will just recreate them because they are not virus related.
If your current antivirus is up to date and running okay, then you don't need to switch. It sounds like you do not have any virii.
Oh and one more thing, please take a moment to give this solution a rating of fixya. Thanks!
Feb 02, 2009 | Microsoft Windows XP Professional for PC
How to remove recycler and system vol info folders
what antivirus do you have? most of them can easy remove it... i had the sam problem... but here is a list of antivirus programs, i know that they can remove it:
Norton Antivirus, and internet security
Kaspersky Antivirus, and internet security
ESET Smart security /can only stop these virus from coping itsepf on the PC, but can not delete it if you install it later.../
as i know Recycler is not that dangerous... but it is a pain in the ***... you can also try to delete ot from the registry /in safe mode/
Jan 16, 2009 | Microsoft Windows XP Professional With...
Recycle name is changed and become G W BUSH
Click on the icon name twice (give it a second delay) NOT double-click to change the name.
Nov 15, 2008 | Microsoft Windows XP Professional With...
Fujitsu LifeBook AH530 Pentium Dual-Core P6000 1.86GHz 4GB 320GB DVD?RW 15.6 LED Win7 Home w/Webca... (FPCR33731) PC Notebook Logo
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
