Barcrest mpu5 genesis led flashing 12 green 2 red
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Posted on Mar 14, 2009
  • 187 Answers
SOURCE: Stuck in standby.
Mainboard damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
Posted on May 27, 2009
  • 17 Answers
SOURCE: red led flashing 6 times
Something is wrong with the power supply of the Hi Voltage section
Posted on Oct 08, 2009
  • 8909 Answers
SOURCE: Sony KDL-40S4100 Bravia LCD will turn on for like
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Posted on Mar 28, 2011
  • 15 Answers
SOURCE: LC-42DH77E Sharp No picture Green led comes on
maybe its on power supply try to check at power supply section check nearby parts of regulator ic if you can, test those passive and active parts using vom if those parts are ok then the regulator ic is defective
Posted on Apr 30, 2011
Why did the red flashing alarm light stop flashing? Alarm and remote working fine
Most likely the 12 volt led light burned out.. all bulbs LED too don't last.. Find the 2 wires usually Black and red and check for 12 volts with the alarm set and if you have 12 volts,. you need to go to radio shack and see if they still have 1. 2 volt led bulbs.. Good luck.
Oct 23, 2016 | Toyota Cars & Trucks
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
How do I repair Lithonia ECR M6 LED Emergency/Exit Light combo. No emerg lights when test button is depressed, no led lights from AC? just a flash when test switch is depressed? is it the small transf
Fixtures are covered by Lithonia Lighting 24-month warranty against mechanical defects in manufacture.
All life safety equipment, including emergency lighting for path of egress must be maintained, serviced, and
tested in accordance with all National Fire Protection Association (NFPA) and local codes. Failure to perform the
required maintenance, service, or testing could jeopardize the safety of occupants and will void all warranties.
Note: Specifiations subject to change without notice.
Actual performance may diffr as a result of end-user environment and application.
Standard
Catalog Supply Input Pallet Carton
Number UPC Description Voltage Wattage Qty. Qty.
ECR LED M6 784231874516 Red 120/277 3.8 108 6
ECG LED M6 784231874592 Green 120/277 3.2 108 6
ECR LED HO M6 784231874561 Red, high output 120/277 3.8 108 6
ECG LED HO M6 784231874615 Green, high output 120/277 3.2 108 6
Accessories: Order as separate catalog number.
ELA WG3 Wireguard (back mount only) 1
ELA LED M12 Single remote lamp2,3
ELA LED T M12 Double remote lamp2,3
ELA LED WP M12 Single, weather-proof remote lamp2,3
ELA LED T WP M12 Double, weather-proof remote lamp2,3
Notes
1 See spec sheet ELA-WG.
2 See spec sheet LED-Remote Lamps.
3 Only available with HO option.
11 5/8 "
7 3/16 "
1 5/8 "
Integrated Exit-Unit Combo
12-5/8"
(32.1)
8"
(20.3)
4-3/8"
(11.1)
5-3/8"
(13.7)
1-7/8"
(4.8)
LED Unit
LED Combo
LED Exit
15 (38.1)
3-3/4
(9.5)
5-3/8 (13.7)
12 (30.5)
3-3/4
(9.5)
2"
(5.2)
4-1/2"
(11.4)
9"
(22.9) 8"
(20.3)
20"
(50.8)
12"
(30.5)
All dimensions are inches (centimeters).
Shipping weight: 3.6 lbs. (1.6 kgs.).
ECR LE
Oct 27, 2014 | Lithonia ECR M6 Exit/Emergency Lighting...
Mpu5 error codes barcrest
I have a cash beast machine, whenthe unit is powerd up, nothing happens, the mpu5 had got the -12v and the 34v leds on but nothign else, i have looked over the board to check the various status leds and as far as i cansee all of them are on, could this be a power supply problem, or is the card dead, does anyone know what/where i could look to see if i can find the fault, i do have 2 power supplies,. and both leave in the same state, i am tempted to say its not the PSU.
Read More.. HP Printer Support
Thanks,
Aug 18, 2014 | Office Equipment & Supplies
Apc smart ups 2200 all led flashing 3 orange 2 red 1green,what is that? and How to Fix It?
this problem is caused control board with that. the solution is replacement.
Jul 21, 2014 | APC Smart-UPS 2200VA LCD 230V...
Nissan pulsar 1987 n13 the ECM light came one and the car cut out and won't start again and I need to know where the ECM is
Hi, the computer is under the passenger's seat. Code extraction procedure is pasted below.
READING CODES Modes will not switch while the engine is running. The ECM automatically switches to MODE I when the ignition is switchedOFF.
1984-90 Vehicles With Dual LED System
The self-diagnostic system has 5 modes. To switch modes, switch the ignition ON and use a screwdriver to turn the mode select switch through the access port on the ECM. The inspection lights will begin to flash. When the desired mode has been entered, turn the screwdriver fully counterclockwise. The red LED and green LED perform different functions in different modes.
Mode I-
This is the normal vehicle operating mode. The green LED will indicate loop status. If the green LED is not blinking when the engine is running, the vehicle is in open loop, or the HO 2 S, O 2 S, or sensor circuit has a malfunction. If the green LED is blinking, the vehicle is in closed loop. If a malfunction takes place, the red LED and the MIL will glow, indicating a malfunction has occurred.
Mode II-
Both the red LED and green LED are used to monitor mixture ratio feedback control. The green LED will function as described in MODE I. If vehicle is in open loop, the red LED and green LED will remain on or off. In order for results to be valid, vehicle must be in closed loop. In closed loop, the red LED remains off if the system is running rich, comes on if the system is running lean, and blinks at the same time with the green LED if system is within 5% of the exact air/fuel ratio.
Mode III
-When this mode is accessed, the codes stored in the ECM's memory will be flashed by the green LED and red LED on the side of the ECM. The red LED will light first. This is the first digit of the trouble code; the green LED will flash next, showing the second digit of the code. For example: 2 flashes of the red LED followed by 1 flash of the green LED corresponds to Code 21.
Mode IV-
This mode is used for checking the throttle plate (TP) switch, starter, and vehicle speed switch status. When the TP switch or starter switch is activated, the red LED will briefly flash as the status changes. For VSS status, the green LED will remain off when vehicle speed is less than 12 mph (19 km/h) and come on when vehicle speed is greater than 12 mph (19 km/h).
Mode V-
This mode represents a real-time diagnostic test of the crank angle sensor, ignition signal and the mass airflow signal. The malfunction code will be displayed only when the malfunction occurs and will not be stored in memory. The output code will appear as a single or short string of pulses. Count the number of pulses for the malfunction code.
1 pulse-CMP sensor signal lost or noise in signal 2 pulses-MAF Sensor signal abnormal 3 pulses-Fuel pump circuit shorted or open 4 pulses-Ignition signal lost
Apr 19, 2011 | 1987 Nissan Pulsar
SONY VPL FX-40 projector. After plug in-ON/Standby LED is red for few seconds and starts flashes in red(repetition rate of 12 flashes). After pressing I/O key-ON/Standby LED flashes in green(few...
A Flashing Red ON/STANDBY LED means one of the following
2 Flashes - The internal temprature is high. Check the air holes are unobstructed.
4 Flashes - The fan is broken
6 Flashes - The internal electrical system has failed.
There is no entry in the manual for 12 red flashes.
Feb 19, 2011 | Sony VPL-FX40 Projector
The LED's on my Energizer charger flash red and green constantly.
If your charging 2 batteries only they must be palced in the following poistions on the charger
1. both side by side in the 2 left slots
or
2. one each in the two right slots.
Otherwise the batteries will not charge.
The users manual can be downloaded here:
http://www.energizer.com/SiteCollectionDocuments/pdf/rechargeable/CHDC.pdf
Thanks for using FixYa.
Kelly
If the batteries are charging the battery indicators
Mar 24, 2010 | Energizer Rechargable Battery with Charger
Battery date code for genesis np12-12
Typically they are etched on the side of the battery and a little vaguely encoded. For the most part the first one or two digits will be the year followed by the month or the week of the year.
Most commonly:
0807XXXX would mean the battery was made in July of 2008.
or
807XXXXX
Alternately:
0834XXXXX would be the 34th week of 2008, sometimes the lead 0 is dropped: 834XXXXX
Sep 19, 2009 | Yuasa (Enersys) Genesis NP4-12 - 12 Volt/4...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
