Question about Bosch Exxcel WFO 2465 Front Load Washer
No display lights on panel
My machine didn't drain and spin so I checked filter, then removed motor to check brushes - they are fine. to do this I replaced packing bolts and put m/c on it's side. Water leaked from softener drawer and may have got onto panel. The display flickers when Start is pressed but then goes blank. I ran the Spin cycle and it appeared to work properly. Can the display be fixed?
  • wellsedd Jan 27, 2009
    I was probably lucky. After properly drying out, everything is working ok. There is a sense of "we can do it" on this site. Perhaps a certain President was inspired by it!
  • 130 Answers
Probably not without replacing the board.
Posted on Jan 26, 2009
Washer will not spin. Cleaned drain/filter. Worked for 2 days. Now won't spin and checked drain, it is clean. The drain pump works fine. What to check next?
i had the same problem a year ago. nothing seemed to work. we even got a new washer, same problem. we ended up putting the washer on its own circuit. works fine now.
Feb 16, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a beko 1512s washing machine, it goes thru the cycle but then wont do a final empty and spin. Its not the pump and its not the brushes please help :(
Are you refering to the main motor when you say 'Its not the 'pump' and its not the brushes' or have you been able to check the separate drain pump and clean the filter, please?
Because I do not know your answers and just in case with no promises ;-0) ---------->
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 16, 2011 | General Electric Washing Machines
Washes clothes fine but won't go into spin cycle.
Could be that the load is either a) too big or b) unbalanced. Try removing some items then set to spin again.
Alternatively it could be that the water is not pumping out. Check the hose from the machine to the drain. Check the filter / junk catcher. Check the hose between the drum and the pump.
I have also had machines that will wash but not spin because the carbon brushes for the motor were worn out. It is not a difficult or expensive job to change the brushes yourself.
Jan 15, 2011 | Zanussi FJD1666W Front Load Washer
The machine doesnt spin with clothes in it
Could be a blocked filter, or worn brushes in the motor.
To check filter, remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum
Remove and clean filter inside trhe hose.
Remove hose onto pump, and check for obstruction or blockage here.
To check the carbons remove motor from washer, and the carbons are located at the oppsite end to the motor pulley.
Hope this helps.
Dec 16, 2009 | Hotpoint Washing Machines
My bosch classix 1200 fl wont spin or drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Oct 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
BOSCH Maxx washing machine will drain and fill but not spin. Also recently clothes are left with sludge on them. Have put on several cycles with cleaning agent.
RepairClinic.com
espares.co.uk
mcminone.com
Pl click 'very helpful' for the free help, thnks.
Oct 08, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Jul 01, 2009 | Washing Machines
Machine will not drain water or spin
hi..Most washing machine have a drain filter that can become
clogged over time.Front load washers typically have a small
removable panel about the size of a half sheet of paper on the
bottom front of the machine.the filter is inside.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Does not remove all the water on spin cycle
Its the filter cap or plug. It unscrews anti-clockwise.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Apr 10, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Maxx 2260 washer won't drain or spin.
RepairClinic.com
espares.co.uk
mcminone.com
Feb 24, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Exxcel WFO 2465 Front Load Washer Logo
228 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
