Kenmore stackable washer/dryer. Model 417.93802209. Dryer will run but won't heat. Flipped breaker. Suggestions?
  • 4 Answers
Possible that the heating element has burnt out, or that the thermostat that controls the element is defective. If you have a low or warm setting try that also as it may use a different element? Good luck.
Posted on Jan 20, 2013
  • 262 Answers
SOURCE: plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Posted on Jan 04, 2008
SOURCE: Dryer spinning but not heating up
There's a fuse...
Posted on Jan 21, 2008
docjohn174
  • 943 Answers
SOURCE: Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Posted on Sep 15, 2008
  • 1122 Answers
SOURCE: No heat in a Kenmore stackable washer dryer
there should be a small fuse on the heater box,if that is not working the element will not work also-mike
Posted on Apr 16, 2009
SOURCE: Trying to disable the dryer's loud buzzer
The wiring diagram is located in the slanted panel above the washer door
Posted on Sep 09, 2009
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 | Dryers
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Where to locate dryer circuit, I think fuse needs changed. Dryer runs but no heat. Stackable set, dryer on top.
kill the power by unpluggin of kill breaker get acess to inside usually from back check the thermal fue or themosats or heating element.. clean your venting as well there might be a tech sheet inside but yea start there.. u can test those with a meter for contunutiy or call for service
Jan 28, 2010 | Kenmore 98702 Stacked Washer/Dryer
Where is the breaker located on a Kenmore stackable washer and dryer?
get the entire model # ( ###.######## ) and go to sears.com > parts direct. type the model # into the search tool and it will pull up drawings for your machine.... hope this helps.
Oct 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Model 417.94802301 stackable with electrical haywire?
you got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
Feb 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
