Question about Hoover S3330 / S3332 Straight Suction Telios Bagged Canister Vacuum
Vacum i dont no it just wont come on. i changed fuse and still will not work. its only about 12 months old
  • Anonymous Dec 16, 2007
    I have the same problem - but what do you mean 'meter' ??
    Mine sometimes works, then either cuts out miduse, or its fine until the next time i want to use it then it doesn't work at all. - my guess is a dodgy wired connection somewhere.
    i found another post with a similar product about taking off the screws under the buttons to get inside - where is the fuse though?
  • 51 Answers
Sounds like on/off switch, but need to meter out to check.
Posted on Jul 25, 2007
Hi My Electrolux Oxygen Z5530 stopped working from one second to another. No lights - nothing - totally dead. What can I do? Is there any fuse? Sincerely Eva
I have same problem and I check it out.
The special requrement of Electrolux for his vacum cleaner motors is that they working with high reliably approx 800 hours working time and no more!!! (it should stop safe with no danger for users...)
7 years has past (2 h/week x 52 x 7 = 708 working hours) so it is time for us consumers to buy new vacum cleaner...
Jan 05, 2011 | Electrolux Vacuums
Hi Our H20 Mop is just over 12 months old and when we start it up the red LED light will not change to green nad will not steam up. When you run your hand down the machine you can feel a little bit of...
Hello
Our (POS !!!!) H20 Mop is just over 20 months old,suddenly became inoperative....
At startup,LED lites red,shortly thereafter changes to green,however NO steam out unit & an audable 'humming'
type noise comes from the unit.
Whatcha got ????
Alf
If you need further help, reach me via phone at https://www.6ya.com/expert/ralph_2f0886b7d6af32ce
Oct 29, 2010 | Vacuums
I was in the middle of using my vacuum when it quite on me. I tried multiple things including letting it cool off for a while as I was using it to vacuum my car outside and it was pretty hot. I also...
Hi the problem you are more than likely having is with the wires that go into the vacume they are not that secure and do work loose.
now if you remove the cylinder that you empty, now you see where the wire goes into the back of the vac, well if you look at the front of the vac in the same place the wires go into the vac you will see a little inspection panel held on with star shaped screws.
you need to undo this to get to the wires
once undone you will see how the wires are secured into the vac you need to undo the connectors screws that secure the wire and remove the mains wire from the vac
now cut about 5 inches off the wire and then peel the outer cable back and cut it back so the two inner wires stick out as much as they used to, then refit the wires in the vac and close it all back up
dont do this with it plugged in as you will give yourself a shock.
when its back together check the fuse in the plug it may need changing due to the short its best if you change it anyway, then switch the vac on and see if it works
give me a shout back if it dont.
please dont mess with it if you are unsure what you are doing as you could cause harm to you and others if you dont put it back together properly
let me know how you get on ok
Aug 14, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
My kenmore vacum wont start
Hello, I'm sorry, but please post additional info such as any symptoms prior to not working, will it make noise, does it do anything. It can possibly be your fuse, but we need more info provided to be able to help you.
Thank you
-Chris
May 03, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Vacume wont **** opened it up see nothing wrong HELP
If no suction usuallly means a clog, either in the hose and the dirt inlet by the brush roll. Sometimes if the belt is stretched, it won't turn the brush roll under load and it would seem like there is no suction.
Apr 19, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Hoover S3330 / S3332 Straight Suction Telios Bagged Canister Vacuum Logo
144 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
