Question about ASUS Eee PC 1001PX 10.1 Netbook 1.66GHz 1GB 250GB WiFi
I can't have wifi connection
What should i do? i connect same wifi on my phone but i am not able to connect it on asus (as i selected above configurations). i think drivers are missing from where i can got them?
    New Friend:
  • 4 Answers
Make a LAN connection and get drivers from here or you can download driver finder program.
Posted on Jan 20, 2013
TIPS72
  • 369 Answers
SOURCE: ASUS EEE PC 900 wireless lan doesn't appear on network connection
please if u have a switch for the wifi connection on your laptop please put it on and should see the wifi on your taskbar also please check in controll panel then go to my network connections and see the wifi resides there if yes just right click and enable if not ther check device manager and check for nework devices if the wifi is enable and installed ...if not please installed by right clicking on it and using reinstall..
please let me know what happens
thanks
Posted on Jan 24, 2009
  • 18 Answers
SOURCE: asus eeepc wont connect to internet wifi but will
turn your wireless on
Posted on Apr 23, 2010
  • 116 Answers
SOURCE: I just bought this asus
Change Your Wireless Channel
If you're using a Linksys router, you'll need to browse to the address of your router, which is probably set to http://192.168.1.1 but could be assigned to another address. You can run a quick ipconfig command at the command prompt to check:
In my case the address is different (because I changed it, of course), but what you're looking for is the Default Gateway for your Wireless connection, and then go to http:// in your browser. Enter in the password that you hopefully remember, and head to the Wireless -> Basic Wireless Settings tab.
My router has two separate bands, but your router might just have a single band here. In my case, what I've done is set the 2.4 GHz band to only be used for Wireless-G, and the 5GHz one to Wireless-N only. Since I'm not having any problems with the Wireless-N settings, I've left those on auto.
Where I am having a problem, however, is my Wireless-G devices-so what I've done is chosen channel 9, since it's the only channel that's not being used by any of my neighbors, who are using mostly channels 1 and 6, though a few are using 11 as well.
Channels 1, 6, and 11 are the most common channels to choose, and most routers will use one of them as the default channel-but the general idea is to be as far away from everybody else as you can.
Note: I've also configured my router for 20 MHz only on the 2.4 GHz Wireless-G band, just because that was the only way it would let me choose the standard channel manually.
If you are using a different router, the IP address will generally be the same, but you'll have to figure out how to change the Wireless channel without any screenshot tours. It's usually fairly easy, though, once you know what you're looking for.
Fun Technical notes
Posted on Jul 18, 2011
  • 11 Answers
SOURCE: msconfig in ASUS EEE PC to turn on WIFI
please install again drivers and execute it from firewall settings
Posted on Apr 28, 2012
rahulwozniak
  • 87 Answers
SOURCE: Asus K52F unable to connect to wifi
Try re-installing your wireless LAN driver or updating it on the internet.
Thank You.
Posted on Jun 25, 2012
Hi i have a asus sonicmaster L403N i canot get on the internet, it us saying no connections available. I have tried everything i can think of. Can you help.
What have you tried, wifi, ethernet? Here's something I found with a Google search:
First, make sure your laptop is 'not' connected to the modem/router via an Ethernet cable and follow the steps:
1. Go to "Control Panel".
2. Next go to "Network and Internet" and then "Network and Sharing".
3. Now click on "Manage Wireless Networks".
4. On this screen, remove all wireless connections by "right clicking" on it and select "Remove network" from the drop down menu.
5. After doing this, close the open windows and reboot the computer.
6. Once the computer is fully reloaded, scan for the "Wi-Fi networks".
7. Click on the available network that you want to access and select "connect".
8. It takes a moment, but then you will be asked to give a password for your Wi-Fi connection. Type in the password and click the "connect" button.
It should now be connected.
NOTE: If this doesn't work, you may want to reset your modem/router, and then once it is fully loaded again, repeat the above steps.
If this doesn't work, test seeing if your laptop will connect via Ethernet. If so, then your WiFi card may be going. You can either look to replace it/have it replaced, or get an external (plugs in via USB) WiFi card.
Mar 10, 2018 | ASUS Computers & Internet
Why can't i get access to data network, or wifi but phone shows i'm connected
Open your dial pad and dial ##847446# a menu will come up select edit and a box will open, enter 10 zeros in MDN and 10 zeros in MSID then select "ok" the phone will restart then try activating again.
Apr 27, 2017 | Virgin Mobile - Lg Optimus Elite Mobile...
Wifi connection
"I am trying to get wifi but I can't connect to wifi from my iPhone it doesn't let me"
YEP, i can solved this issue, try following steps..
1. connect your IPHONE to your pc/laptop(make sure you have latest itunes).
2. take backup from "your's iphone" right click and select backup
3. after completed go to summary in ituns.
4. select "restore iphone". and chose next if asked
5. after finished it select restore backup form itunes and
when it finished you done.
try it 100% working.... thnkyou
Apr 29, 2013 | Cell Phones
My Samsung s390g doesn't connect to web or WIFI
Make sure you are selecting WiFi first from the main menu, then connecting to WiFi before you select your browser. If you just select "Browser" on the main screen the phone automatically tries to connect via cell data and then gives an error message if you don't have phone service. If that is not working then restart the phone, pull out the battery then put it back and restart.
Dec 23, 2017 | Samsung Cell Phones
My kf 900 the wifi doesnt wort
Do you have a wi-fi network? Is it password protected? Try resetting your router so the settings will be changed back to default.
Aug 15, 2011 | LG Prada KF900 Cell Phone
Hi I'm trying to use my desktop pc with ASUS P5Q3 Deluxe Wifi AP @n motherboards onboard WLAN as an Access Point to my Nokia X3-02 phone for WLAN. Would be nice to use same internet connection through...
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect to your phone
hope this helps
May 10, 2011 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
Connection wifi
dear try this..hope u will be helped
1. Go to Settings > Connections > Connections > advanced tab >
On the top half, for select networks to automatically used, click "select networks"
For top half, for programs that automatically connect to the internet should connect using "My Work Network , and then
continue by clicking "edit", go to proxy settings tab... just tick "this network connects to the internet" box only....
leaving the proxy server box unchecked, as well as advanced ( these would be set automatically ) and click ok on top..
This will return you to the network management settings,
On the bottom half, for program to that automatically connect to a private network should connect using ...
select "My Work Network" as well, then click "edit", go to proxy settings, and just tick same as above procedure....
Note: Besides the above steps to select networks, you can ignore the "dialing rules" and "exceptions" boxes alone...
2. Go to Settings > Connections > Wi-fi
Under configure wireless networks, you should be able to see the list of your wifi networks...
First, go to Network Adapters tab and then for my network card connects to.... select " The Internet" ( not Work )..
Secondly, go back to Wireless tab, scroll down to your house wifi...and click on Menu > Edit. select connect to the internet ( not Work),
click Next ....For Authentication box ,select "Open" and for data encryption box, select "disabled".
Other boxes can be left blank, and click "Next" and then "Finish".
Nov 08, 2010 | Samsung Star GT-S5233 Cell Phone
How to connect samsung handphone to wifi
Feb 28, 2010 | Cell Phones
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
See all ASUS Eee PC 1001PX 10.1 Netbook 1.66GHz 1GB 250GB Questions
ASUS Eee PC 1001PX 10.1 Netbook 1.66GHz 1GB 250GB WiFi Logo
137 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
