Question about Bosch HBN 7052 GB Stainless Steel Electric Double Oven
Is there an alternative version as mine is 10 years old
Thinking of getting a new cooker is this one still in production or have they updated it to another model
I need to change the sponge filter but cannot seem to buy one
go to the place u bought the unit. if that does not exist, then git 2 homie depot,lowes, or sears,who ever. and take u r filter with you. there r replacement filters, or alternatives. lol.
Apr 13, 2014 | Baumatic Ovens
Viking replacement decals / stickers: Has anyone found a reputable source of replacement decals for oven and cooktop - mine rubbed off after a few years' use, and from cleaning....)
Try www.ovenlettering.co.uk. Mark the owner will find accurate decals of your cooker confirm it with you and send you two sets plus degreaser. Follow the simple steps from the sites video instructions and voila. It is so easy and I highly recommend Mark and his product. Tell him Shaun sent you.
Jan 08, 2014 | Ovens
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
Need a new main oven door spring
You can get a new spring from Airedale Springs Telephone - 0845 4754201
Apr 20, 2010 | Ovens
My GE Profile is about 10 years old. Everything
cheapest attempt would be replacing temp. sensor....other component if still not functioning,would be the main computer board,which can be very pricey
Nov 27, 2009 | GE Ovens
Zanussi Electric Cooker and Hob don't work properly
it will have nothing to do with the supply, although it does sound as though he could have done a better job. if the appliances are brand new get Zanussi out to it. shame on the guy for not checking that they worked as they should. hope this helps.
Feb 17, 2009 | Zanussi ZHQ575 Electric Double Oven
Cooker
HI THERE SKI IS THE GLASS DOOR PANEL THE INSIDE DOOR GLASS OR THE OUTER DOOR GLASS PANEL AND IS IT THE MAIN OR TOP OVEN.
THE GLASS PANELS INTERNALLY ARE HEAT BONDED IN THE FACTORY AND CANNOT BE REPAIRED YOU WILL NEED A NEW DOOR GLASS.
IF INTERNAL ONE COME AWAY THEN U WILL HAVE TO HAVE A COMPLETE INNER PANEL.
Feb 13, 2008 | Ovens
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 | Ovens
Bosch HBN 7052 GB Stainless Steel Electric Double Oven Logo
24 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
