Sansui Leader 400 power supply circuit - Televison & Video
No power sansui plasma 42 sty0342
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 04, 2017 | Sansui Televison & Video
Sansui sled2800 power supply circuit board location
It's the board that the power cord is connected to. Follow the wires from where the power cord enters the cabinet up to the board.
Oct 17, 2016 | Sansui Televison & Video
I have a sansui PDP42TD1, and i can't adjust the brightness. the whole colour setting is ghosted, can you help?
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 26, 2015 | Sansui Televison & Video
I have a sansui model sv29a41 does not switch on
Check and replace the damaged component/s at its SMPS {power supply regulator} section circuit. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 08, 2015 | Sansui Televison & Video
Sir i have sansui leader 500 main iv no tda 12135 Vertical ic ok vertical not open
Check and replace the vertical scan output IC. Check related capacitors, and solder terminals at the vertical scan output section circuit for any loose soldering. Check the voltages at the vertical scan output IC. Refer its circuit diagram [schematic] for more details. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 03, 2015 | Sansui Televison & Video
Sansui sv 2918
Aug 26, 2014 | Sansui Televison & Video
Sansui tv won't turn on
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
Jan 10, 2013 | Sansui 32" TV
Sansui 27 inch clicks on and off repeatedly and will not stay on
There seems to be power supply circuit problem. If any short present the SMPS will switch off automatically.
Apr 02, 2010 | Sansui DTV1300 TV
Sansui 3618 tv
that seems to be a 3.15amp fuse. if it blolws then there is a short circuit
Mar 03, 2008 | Televison & Video
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
