I have replaced all of the rollers. It doesn't happen all teh time. It is not the paper for have another printer in the same room using the same paper and not ahveing the problem.
Frankly speaking, this problem exists and printer companies always have denied this. What I think from my experience that there is some engineering problem with all these printer, in the way paper is fed in.Still I give some solution which HP's site suggests. See if it works in your case:
Issue
Multiple pages feed through the printer when printing.
Solution
If the printer is picking up multiple sheets of paper, follow the recommendations below:
If the printer continues to pick up multiple sheets of paper, follow the following troubleshooting steps below:
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=gb&dlc=en&docname=c00190540
NOTE:
Not all HP Deskjet printers have rear access doors. Skip this step if your printer does not have a rear-access door.
Remove
the rear-access door (if applicable) and clean the internal rubber
rollers with a soft lintfree cloth moistened with distilled water. Wait
until the rubber rollers dry and replace the rear access door.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
